3-way Crossfire
ShadowFold
16,918 (2.71/day)
Omaha, NE
System Name The ShadowFold Draconis (Ordering soon)
Processor AMD Phenom II X6 1055T 2.8ghz
Motherboard ASUS M4A87TD EVO AM3 AMD 870
Cooling Stock
Memory Kingston ValueRAM 4GB DDR3-1333
Video Card(s) XFX ATi Radeon HD 5850 1gb
Storage Western Digital 640gb
Display(s) Acer 21.5" 5ms Full HD 1920x1080P
Case Antec Nine-Hundred
Audio Device(s) Onboard + Creative "Fatal1ty" Headset
Power Supply Antec Earthwatts 650w
Software Windows 7 Home Premium 64bit
Benchmark Scores -❶-❸-❸-❼-
Anyone else running a 3-way Crossfire setup? If everything goes right, I should a 4850 1gb bought next Monday for some 3 way Crossfire action :toast:
1,644 (0.27/day)
System Name Black Killing Machine
Processor Delidded NO IHS mount Intel i7-4770k
Motherboard Gigabyte Z87X-OC
Cooling Swiftech DIR655 pump, Watercool HEATKILLER® GPU-X³ 79X0 Ni-Bl gpu, DT SNIPER CPU block, UT60 420 RAD
Memory Gskill Trident 2400mhz CL9 Samsung IC9
Video Card(s) SAPPHIRE HD7950 OC 950mhz Edition, VaporX HD7950
Storage 2xM4 Crucial 64GB RAID 0, 1 OCZ AGILILITY 3 60GB, WDCB 500GB x2RAID0, WD Green, Hitachi 1TB
Display(s) Samsung SyncMaster 226BW and 24" 120hz BenQ gamer
Case SilverStone Raven rv-02
Audio Device(s) Audio Technica ATH-AD900 headphones, Topping D2 DAC/Headphone AMP
Power Supply Seasonic Platinum 860
Software Windows 7 Pro 64bit
Benchmark Scores http://hwbot.org/user/sonda5/ Delidding is magic. http://valid.canardpc.com/2878462
That seems like a great set up.
Hope it works well for you. Keep us posted.
8,523 (1.36/day)
Kansas City
System Name The Dove Box Rev 5.0
Processor 9800x3D
Motherboard Asus 870E STRIX
Cooling Custom Water
Memory 32 GB 6400 MTs
Video Card(s) Asus 3080 TUF
Storage 2TB Crucial T705
Display(s) 32" LG 1440p 180hz
Case Lian Li O11 Dynamic
Audio Device(s) ON BOARD FTW
Power Supply Corsair 1000W
Mouse Corsair something
Keyboard Steelseries
Software Win 10 64x
Not many folks Trifire around here. I debated the idea a while back but couldn't find a single sloted 4830, too bad I ran across one just a few weeks ago(XFX single slotted 4830).
ShadowFold
16,918 (2.71/day)
Omaha, NE
Cooling Stock
anyone know of a good single slot cooler? I would have to take my PhysX card out for the 2nd GPU to fit :ohwell: If not I wont miss the damn thing lol
DOM
7,628 (1.12/day)
TX, USA
Processor Intel i7 4770K
Motherboard Asrock
Cooling Water
Memory Team Xtreem LV 16GB (2x8GB)
Video Card(s) EK Full WB HD7970
Display(s) CROSSOVER 27Q LED-P 27"
Case Danger Den Torture Rack
Power Supply CORSAIR Professional Series Gold AX1200
Software W 10 Pro
why not a q core ? dont think your going to get alot out of another card in benches with that cpu
ShadowFold
16,918 (2.71/day)
Omaha, NE
Cooling Stock
Not interested in benches honestly
3,210 (0.54/day)
System Name White Custom Loop Fractal North XL
Processor Intel Ultra 7 265K Overclocked 5.6Ghz P-Core / 5.1Ghz E-Core / 4.2Ghz Ring / 3.2Ghz D2D & NGU
Motherboard ASUS STRIX Z890-A GAMING WIFI
Cooling AlphaCool Core 1 White CPU Block - 2x Heatkiller 360-L - Alphacool Core 120mm Resevoir
Memory 48GB 7200Mhz Corsair Dominator DDR5 - Overclocked to 8000Mhz
Video Card(s) RTX 5090 32GB Palit Gamerock - Alphacool Waterblock Incoming
Storage 4TB WD Black NVME Gen 4
Display(s) Alienware 38" 3840x1600 (165Hz)
Case Fractal North XL Chalk White Mesh
Audio Device(s) 2i2 Scarlett Solo + Schiit Magni 3 AMP
Power Supply Corsair RM1200x Shift White
DavyGT
I do.
Installing each card was a snap, drivers installed and worked as they should, overclocks worked as they were single cards and the cards were from mismatched manufacturers (2xGigabyte custom PCBs and 1xPowerColour Reference). :rockout:
The only thing that didn't go well was a dual monitor setup with the other monitor on a secondary adapter.
Plus it surprised me that it ran on a HX620 :eek:
3,210 (0.54/day)
I do.
Oooo cheers for the heads up looks like this hx 620 will last me quite a while considering the setup you have.
crtecha
2,407 (0.41/day)
ipsay meechigan
System Name Coolin Runnings
Processor AMD X4 Phenom 9950 B.E. @ 3.3ghz
Motherboard Gigabyte GA-MA790x-DS4 BIOS Ver. F6
Cooling CM Vortex 752
Memory apacer PC6400 800mhz x 2
Video Card(s) Two ATI Radeon 4850's in xfire
Storage Seagate 7200.9 320gig+250gigx2
Display(s) Acer P191w 19' wide
Case Antec 900
Power Supply Antec Power trio 550watts
Software Windows 7 x64 Build 7100
As soon as I find a good mobo that supports quad im going for quad 4850's
Weer
1,417 (0.22/day)
New York / Israel
System Name //////////////////////////////////////Crunching/Folding Builds\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
Processor Q8400@ 4.0Ghz | Q6600 @ 3.6Ghz | E7300 @ 3.8Ghz | E5300 @ 4.3Ghz | E5300 @ 3.9Ghz | E2180 @ 2.0Ghz |
Motherboard ASUS P5Q-E | Asus P5Q Pro | Gigabyte EG45-DS2H | Gigabyte EP35-DS3H | Gigabyte NV73 | E-Sonic P35-G
Cooling TRUE [Lapped] | TRUE | Thermalright SI-128 | Stock | Stock | Stock
Memory G.Skill 8192MB @ 1066Mhz | G.Skill 4096MB | OCZ 2048MB | G.Skill 2048MB | PNY 2048MB | OCZ 1024MB
Video Card(s) GTX 280 + 8800 GTS 512 | 9800 GX2 + 8800 GTS 512 | 6600 GT | 8800 GS | 9600 GSO 512
Storage G.Skill 64GB SSD (OS) | Segate 750GB [Downloads] | 5TB JBOD [Movies] | 3TB JBOD [Else] | 1.5TB [Ex]
Display(s) QUAD Monitors: Dell 2007FP [20"] + Dell 3007WFP-HC [30"] + Dell 2007FP [20"] | Dell 2407WFP-HC [24"]
Case Antec P190 | Antec Three-Hundred | Antec NSK2400 | Thermaltake Strike MX | HEC 6T10 | HEC 8K01
Audio Device(s) Creative X-Fi XtremeGamer PCI + [Audiophile HD600] + [Creative G500 + Logitech X-530 = 10 speakers]
Power Supply OCZ 750w [62A] | OCZ 750w [62A] | Antec 380w [31A] | Antec 650w [54A] | OCZ 400w [33A] | GeN [20A]
Software Windows 7 Ultimate 64-bit + Windows XP 64-bit | Windows Vista SP2 64-bit | Windows 7 RTM 64-bit
Benchmark Scores ////////////////////////////////66,666 [Crunching] + 45,455 [Folding]\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\
You'd probably be a lot better off buying dual-4850 X2's, and selling your 4850's. Of course, for the money, you could probably get a GTX 295.
NGD
23 (0.00/day)
Processor E8400 @ 3.8Ghz
Motherboard GA-EP45-DS4
Cooling Arctic Freezer 7 Pro
Memory 4Gb Corsair Dominator @ 950Mhz
Video Card(s) Sapphire HD4850 512MB @ 700/1100
Storage Seagate barracuda 500Gb
Display(s) Acer H233H
Case CM590
Power Supply Chieftec 450W
Software Vista Ultimate 64bit
Why not go for 2x 4850x2?
crtecha
2,407 (0.41/day)
ipsay meechigan
Case Antec 900
I could and its been considered if I was going to touch a 4800 x 2 card I would most likely wait for the 5 series and pick up some 4870x2 or maybe a 4890x2. I really just wanna to see how well they perform being in quad xfire and to boost the E-peen ya know :roll: Im kidding I'm just interested in playing around with different configurations and seeing what performs the best.
Weer
1,417 (0.22/day)
New York / Israel
But there are so many things that you need to do before getting Quad-Rv770.
You absolutely need to get a bigger monitor. Preferably a 24-incher.
crtecha
2,407 (0.41/day)
ipsay meechigan
Case Antec 900
I know that I cant just throw a new mobo in a go. I need new psu and a bigger monitor and I'd like to be under water if I'm going to try out quad xfire. These are just idea's I should be getting the other two sometime this month soo Ill worry about all that once I get them. In the mean time Ill have 3 pretty decent gaming rigs :). One running xfire and two lighter pc's running a single 4850. Should be fun :)
Edit:hahahah I remembered that I have a 4830 to play with two :)
8,523 (1.36/day)
Kansas City
Processor 9800x3D
Software Win 10 64x
If there was one out it would be all over the market, too bad there isn't. :( Guess it would be to hard to incorporate heat pipes into a single slotted cooler.
ShadowFold
16,918 (2.71/day)
Omaha, NE
Cooling Stock
I know Crysis doesn't use a 3rd card at all. I know STALKER and Call of Duty do! Modern Warfare 2 and Call of Pripyat are my two top wanted games ATM. I think this will be worth it for me in the long run.
crtecha
2,407 (0.41/day)
ipsay meechigan
Case Antec 900
You should be able to set it to run that third card with r_multigpu = 1 in console
that should set it to run all three.
3,516 (0.60/day)
System Name Money Hole
Processor Core i7 970
Motherboard Asus P6T6 WS Revolution
Cooling Noctua UH-D14
Memory 2133Mhz 12GB (3x4GB) Mushkin 998991
Video Card(s) Sapphire Tri-X OC R9 290X
Storage Samsung 1TB 850 Evo
Display(s) 3x Acer KG240A 144hz
Case CM HAF 932
Audio Device(s) ADI (onboard)
Power Supply Enermax Revolution 85+ 1050w
Keyboard Logitech G710+
If everything goes right for me, I'll be broke by the time I get done with my i7 build.:laugh:
Let us know how that goes since I'm really interested in picking up another 4870 to throw in with my X2 right now.
MKmods
Case Mod Guru
5,697 (0.92/day)
Nevada
System Name Crossflow III
Processor AMD 965 (4.04Ghz)
Motherboard Asus Crosshair III
Cooling Air
Memory 4 gigs Mushkin 7-7-7-20@1T
Video Card(s) single 9800GT
Storage Raptor 150's in Raid0
Display(s) LG Flatron 24"
Case Custom
Audio Device(s) AuzenTech X-Raider W/OP637
Power Supply Custom modded Corsair 750HX
Software Win 7 64/Solaris Utility
Benchmark Scores 3DMark06--21963 so far
Ever since I saw this pict I have wanted to do as many cards that would fit....
I wish they would be worth it
3,625 (0.57/day)
Terra
System Name :)
Processor Intel 13700k
Motherboard Gigabyte z790 UD AC
Memory 64GB GSKILL DDR5
Video Card(s) Gigabyte RTX 4090 Gaming OC
Storage 960GB Optane 905P U.2 SSD + 4TB PCIe4 U.2 SSD
Display(s) Alienware AW3423DW 175Hz QD-OLED + AOC Agon Pro AG276QZD2 240Hz QD-OLED
Case Fractal Design Torrent
Audio Device(s) MOTU M4 - JBL 305P MKII w/2x JL Audio 10 Sealed --- X-Fi Titanium HD - Presonus Eris E5 - JBL 4412
Power Supply Silverstone 1000W
Mouse Roccat Kain 122 AIMO
Keyboard KBD67 Lite / Mammoth75
VR HMD Reverb G2 V2
Software Win 11 Pro
so who wants to buy my 4850s to complete their trifire setup?
Reventon
2,106 (0.36/day)
Sarasota, FL
System Name Black & Red
Processor AMD 64 X2 6400+ BE 3.2Ghz
Motherboard JetWay JHA06-GT 780G ATX
Cooling Xigmatek HDT SD964 92mm cooler, 5 Case Fans, PCI Slot Evercool exhaust fan
Memory 4GB DDR2 667Mhz
Video Card(s) ASUS EAH4850HD 512MB
Storage Seagate 120GB HDD 7200rpm, Samsung 160GB HDD
Display(s) 19" Enivision LCD (1280x1024), 15" HP vs15c (1024x768) dual screen
Case Cooler Master Storm Scout Mid Tower
Power Supply Corsair 400W PSU
Software Windows Vista 32-bit
So you need Crossfire in order to run a 2 GPU VGA?
ShadowFold
16,918 (2.71/day)
Omaha, NE
Cooling Stock
Reventon
2,106 (0.36/day)
Sarasota, FL
You only have 1 GPU, correct? A 4850X2?
ShadowFold
16,918 (2.71/day)
Omaha, NE
Cooling Stock
Yes but you can do 3 4850 singles too. 4850X2+4850, 4850+4850+4850, it all works..
