3 way furyx crossfire possible?
593 (0.29/day)
Hungary
System Name Detox sleeper
Processor Intel i9-7980XE@4,5Ghz
Motherboard Asrock x299 Taichi XE (custom bios with ecc reg support, old microcode)
Cooling Custom water: Alphacool XT45 1080 + 9xArctic P12, EK-D5 pump combo, EK Velocity D-RGB block
Memory 8x16Gb Hynix DJR ECC REG 3200@4000
Video Card(s) Sapphire RX7900XT - NITRO+ Vapor-X 20GB
Storage Samsung PM9A1 1Tb + 2x PM981 512Gb + Kingston HyperX 480Gb + Samsung Evo 860 500Gb
Display(s) HP ZR30W (30" 2560x1600 10 bit)
Case Chieftec 1E0-500A-CT04 + AMD Sempron sticker
Mouse Logitech G400
Keyboard IBM Model M122 (boltmod, micro pro usbc)
Software Windows 11 Pro x64
I have 3 Fiji GPU-s in my rig. Two GPU on a Radeon Pro Duo and one on an Radeon Mi8 (R9 Nano bios modded but it is the same)
I have tried stock drivers, nimez modded drivers but there is no enable crossfire option on the Mi8 card.
They are same GPU, same clocks, same voltages, same memory size, pcie3 real 16x slot. The only difference is that the Mi8 is not a fury card but a nano so different VRM and cooling and it is working with games, bencmarks alone.
I know that CF is a dead thing but i only need it for experimenting, testing. For gaming i use an M40 card (TitanX)
So how can i force enable 3 way crossfire? Regedit?
639 (0.12/day)
St. Louis, MO
System Name Desktop
Processor AMD Ryzen 7800X3D
Motherboard MSI X670E MEG ACE
Cooling Corsair XC7 Block / Corsair XG7 Block EK 360PE Radiator EK 120XE Radiator 8x EK Vadar Furious Fans
Memory 64GB TeamGroup T-Create Expert DDR5-6000
Video Card(s) MSI RTX 4090 Gaming X Trio
Storage 1TB WD Black SN850 / 4TB Inland Premium / 8TB WD Black HDD
Display(s) Alienware AW3821DW / ASUS TUF VG279QM
Case Lian-Li Dynamic 011 XL ROG
Audio Device(s) Razer Nommo Pro Speakers / Audio-Technica ATH-R70X
Power Supply EVGA P2 1200W Platinum
Mouse Razer Viper, Logitech G600
Keyboard Razer Huntsman Elite
I could be wrong, but due to my understanding of CrossfireX, you can only go up to 4 GPUs...... With the two Pro Duos, you are at 4 GPUs, so you will not be able to use the Nano as that would count as the 5th GPU.
593 (0.29/day)
Hungary
Mouse Logitech G400
I have only one pro duo that appears as two Fury series (nimez driver) or FuryX X2 (AMD stock driver) or Pro Duo (AMD stock Pro driver) in the device manager and i have one mi8 that appears as Nano or Fury series depending on the driver.
593 (0.29/day)
Hungary
Mouse Logitech G400
You can have more GPUs working, but it's not gonna be as Crossfire then.
Crossfire is no longer supported anyways.
It is working with 2 gpu-s, the benchmarks is better, and in games i see the crossfire logo.
Toothless
Tech, Games, and TPU!
9,746 (2.45/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Harpoon
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
593 (0.29/day)
Hungary
Mouse Logitech G400
I sold the MI8 card thanks all!
