3060ti 0% Usage
Shaconior
9 (0.01/day)
Good night, I have been facing some problems with my 3060ti, the gpu usage goes to 0% causing fast freezing in several games like apex and warzone cod, causing micro stutter, a few times on Albion online the game crashed and the screen went black.
config: 3060ti gigabyte
i5 10400f
16gb t-force ram
psu: azza 650w bronze
18,584 (2.66/day)
System Name AlderLake
3,059 (0.43/day)
Baltimore MD
Processor Ryzen 5900X
Motherboard ASUS Prime X470 Pro
Cooling Arctic liquid freezer II 240
Memory 2 x 16 Gb Gskill Trident Z 3600 Mhz
Video Card(s) MSI Ventus 3060 Ti OC
Storage Samsung 960 EVO 500 Gb / 860 EVO 1 Tb
Display(s) Dell S2719DGF
Case Lian Li Lancool II Mesh
Mouse Logitech G703
Keyboard Logitech G513
Software Win 11
check event viewer
pauses that long look like the display driver hanging and restarting
43,538 (6.77/day)
Never heard of this, better buy a PSU of a well-known reputable brand.
They are trash for sure
Would you help me? I want to test to see if the video card is ok, which program do you recommend?
Give us complete detailed specific system specs, to include room temperature and hwinfo64 screenshot of cpu and gpu temperatures.
Shaconior
9 (0.01/day)
Eles são lixo com certeza
Forneça-nos especificações completas e detalhadas do sistema, incluindo a temperatura ambiente e a captura de tela hwinfo64 das temperaturas da CPU e da GPU.
temperatura do quarto: 19c
check event viewer
sorry i couldn't understand what to do
1,398 (0.81/day)
Looks like (from the screenshot) the driver for NVIDIA RTX 3060 Ti is off or not installed. Look at device manager under display adapter what it says and install/start the driver.
Driver location, just choose your card and windows: _here_ .
Shaconior
9 (0.01/day)
I installed the drivers by geforce experience
1,398 (0.81/day)
Oh ok then, update HWInfo64, 7.06 is out and better suited for newer systems and cards...
If we go by the known rule for cheap/unknown power supplies, it's advertised wattage divided by two. So it just might be the power supply.
Can you test your system with another power supply?
Ruru
S.T.A.R.S.
13,334 (3.00/day)
Jyväskylä, Finland
VR HMD Oculus Rift CV1
Try 3DMark (Time Spy of its benchmarks) so we can have some reference to similar systems.
Shaconior
9 (0.01/day)
Experimente o 3DMark (Time Spy de seus benchmarks) para que possamos ter alguma referência a sistemas semelhantes.
Ok então, atualize HWInfo64, 7.06 está disponível e é mais adequado para novos sistemas e placas ...
Se seguirmos a regra conhecida para fontes de alimentação baratas / desconhecidas, é a potência anunciada dividida por dois. Portanto, pode ser apenas a fonte de alimentação.
Você pode testar seu sistema com outra fonte de alimentação?
eso, I don't have a source for reference, as I bought the assembled computer, I will trigger the warranty...
Ruru
S.T.A.R.S.
13,334 (3.00/day)
Jyväskylä, Finland
At least the 3dmark score is exactly what it should be.
1,398 (0.81/day)
At least ask the people at the place you bought your computer why this is happening to you on their configuration, perhaps they can test it and find out the reason?
Shaconior
9 (0.01/day)
Pergunte pelo menos às pessoas no lugar onde você comprou seu computador por que isso está acontecendo com você na configuração deles, talvez eles possam testá-lo e descobrir o motivo?I did it, go get the computer to do tests, the bad thing is having to go a month without the computer :(
Pelo menos a pontuação de 3dmark é exatamente o que deveria ser.
OLook, um exemplo do problema Geralmente ocorre em todos os jogos, Apex, cod, bf5, até em Albion, em Albion era pior, a tela piscava preta e fechava o jogo
Once restarted and gave nvlddmkm.sys
1,398 (0.81/day)
That's tough; but it's either that or constant nagging errors in your favourite games... quite unfortunate. You can tell them exactly where it happens and they should be quick to test it with different power supplies and then it'll be solved hopefully.
Shaconior
9 (0.01/day)
Isso é difícil; mas é isso ou erros irritantes constantes em seus jogos favoritos ... lamentável. Você pode dizer a eles exatamente onde isso acontece e eles devem ser rápidos em testá-lo com fontes de alimentação diferentes e, então, esperamos que seja resolvido.
MThank you very much for your help, it helped a lot
Shaconior
9 (0.01/day)
1,398 (0.81/day)
Interesting; it could mean that either the connection to the PSU isn't good or the voltage isn't in spec (PSU's fault); could be too much electrical noise on the line...
