3600MHz CL20 or 3200MHz CL16 to pair with R5 3500?
151 (0.05/day)
INDIA
System Name QARTS PC
Processor Ryzen 3500
Motherboard MSI B450 PRO VDH MAX
Cooling Stock
Memory XPG Adata 8GB 2800MHz
Video Card(s) MSI RX 580 8GB Gaming X
Storage WD 7TB(4+3)
Display(s) Sony Bravia 46
Case Ant Esports Ice 511MT
Power Supply Coolermaster 550W 80+
Mouse Logitech G300
Keyboard Dell Generic
Hello,
Can you suggest me which will be best for my build-
Ryzen 3500
MSI B450 Gaming plus
CM 550W MWE
128GB SSD
Ice 511MT
RAM1-8*2 G.Skill Sniper X 3600MHz CL20
OR
RAM2-8*2 XPG Adata D30 3200MHz CL16?
Thanks
1,194 (0.27/day)
Denmark
Processor R9 5950x/i5 6400
Video Card(s) 7900XTX/6900XT
Case Custom builds
Audio Device(s) -
I would throw in my own kit the Patriot Viper 4400MHz in Denmark its almost same price and its samsung B-die, I think the Sniper X could be as well but you have to look that up your self. The Patriot runs great on the MSI B450 Tomahawk
I do believe in 1:1 match with Infinity is better than low latency - but with the Patriot Viper I am running 1866 Infinity and CL 14 with these setting
508 (0.26/day)
When I built my recent computer almost 9 months ago I had a similar problem However mine was choosing a PC3200 with CL14 over a PC3600 CL16. It is pretty close to equal performance. But I chose the PC 3200 because was compatible (on the preferred list from the MB manufacture) with my mother board and it had some very tight timings. G.Skill Flair X PC 3200 CL14. 14-14-14-34
Now in the youtube video you do see 3 Gskill ram sticks. The PC3600 with the tight timings also cost $190 The Flare X costs $100, and the Trident Z is $69. I have the Flare X on my current computer.
My suggestion to you is to see what your motherboard will take without any headaches.
Next how much money are you willing to spend and can you hold off for a few more months... The Ram prices are continuing to decline.
Next could not find CL20 Sniper X
Did Find this.
And this one.
If I had to choose I go with G.skill as I have never had an issue with their memory.
I never had an issue with G.Skill in using them in my computers or the computers I build/built for my client base There are plenty of good Ram manufactures but I stay with what works for me. Also because of G'skill Reputation of quality Ram there is a good resale value as well.
In ending really do your homework for everything you build. Check your MB for which Company that makes their ram that will work easily with it and how much money you are willing to spend? And do you really have to have the Ram now?
These are just suggestions... however good luck with your build regardless.
151 (0.05/day)
INDIA
Cooling Stock
Storage WD 7TB(4+3)
Mouse Logitech G300
Did Find this.
And this one.
Thank you so much for this proper explaination.
Am getting both the XPG and GSkill one for nearly the same price around thus was in dilemma about which to get.
I guess I'll stick with the G.Skill one for now neglecting its higher frequency.
9,340 (5.16/day)
Louisiana
Keyboard G710+x3
Hello,
Ryzen 3500
CM 550W MWE
128GB SSD
Ice 511MT
OR
Thanks
C20 at 3600 ? no c20 this is actually way higher than the rated frequency meaning it's a very poor bin.
C16 at 3200 well better but no price winner for sure
Deal usually is CL x 2 = hopefully lower than the first two numbers of the rated frequency
So c16 at 3200 is mediocre at best and 3200c14 would be optimum c14 x 2 = 28.
3600c16 x 2 = 32 this would be optimum
151 (0.05/day)
INDIA
Cooling Stock
Storage WD 7TB(4+3)
Mouse Logitech G300
Thanks for the reply, but am not a techie guy so can you please simplify a bit?
Or instead guide me which will b better for me off the two i mentioned!
9,340 (5.16/day)
Louisiana
Keyboard G710+x3
Thought I was pretty clear but from the two you listed 3200c16 is better than 3600c20
Want better than 3200c16 look for 3200c14 or 3600c16.
B-Die Finder
6,190 (2.85/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
Take a look at Crucial kits - ballistix or sport lt's. You could easily land yourself a 3200 CL16 kit that can pull of at least 3600 cl16.
Out of two you mentioned:
is better, that CL20 is probably a really bad bin.
508 (0.26/day)
My reason for going with G.skill is that they are reliable. Secondly I have not seen a CL20 on a G.Skill Sniper Memory stick in my region. CL 19 yea. Your Sniper X is CL 19-20-20-40. Again I would choose G.Skill because of being Reliable, but that's me. If your motherboard will take the A-data Memory then go that way.
For the same amount of money you could get this with better Timings IF your motherboard will take it.
But I do recommend to check on what companies that they recommend to use on their mother board first. This will avoid the major headache of ram compatibility issues.
A lot of people just buy ram thinking that RAM is RAM and when they put it on their computer and wonder why it does not work.
It comes down to what you want to spend.
Just go to Newegg and find what you need and LOOK at all of the CAS timings on memory stick not just the first number.
191 (0.09/day)
The Heart of Dixie
System Name Forgal
Processor Ryzen 7 5800X
Motherboard Asus RoG Strix X570-E Gaming
Cooling Arctic Liquid Freezer II 280
Memory 4x16 GiB Crucial Ballistix PC4-28800, 16-18-18-38
Video Card(s) MSI Suprim Liquid GeForce RTX 4090
Storage 2 TB ADATA XPG SX8200Pro + 4 TB S860 + NAS
Display(s) Asus RoG Swift PG42UQ + LG 32UD99-W
Case Fractal Design Define 7 Compact
Audio Device(s) Audioengine HD3 + S8
Power Supply Super Flower SF-1000F14TP Leadex V P130X-1000 Pro
Mouse Razer DeathAdder 2
Keyboard Leopold FC900R OE mx-brown
508 (0.26/day)
Here's some reasonably priced DDR4-3600 (PC4-28800) with decent latency. Both work well with Ryzen 5 3600X and a 1:1 infinity fabric ratio.
G.Skill Ripjaws DDR4-3600, 16-19-19-39, SK Hynix chips: https://www.newegg.com/g-skill-16gb-288-pin-ddr4-sdram/p/N82E16820232880
Crucial Ballistix DDR4-3600, 16-18-18-38, Micron chips: https://www.newegg.com/ballistix-16gb-288-pin-ddr4-sdram/p/N82E16820164173
Agree. Crucial I've not had an issue in one of my client's computer. And you bring up a good point about bringing up the 1.1 fabric ratio.
151 (0.05/day)
INDIA
Cooling Stock
Storage WD 7TB(4+3)
Mouse Logitech G300
NOTE-The CL of G.Skill Sniper X is CL-19.
Does
You're right,
The CL of G.skill is Cl19.
And yes i will check my MSI B450 Gaming plus mobo RAM compatibility first.
Thanks
9,340 (5.16/day)
Louisiana
Keyboard G710+x3
