3D Printed GPU Stand?
95 (0.06/day)
Berlin
System Name Desktop
Processor Ryzen 7 5800x
Motherboard Aorus B550 Elite V2
Cooling Cooler Master Hyper 212X Dual Fan 82.9 CFM CPU Cooler / 5x 140mm Case Fans
Memory G.Skill Trident Z RGB 16 GB (2 x 8 GB) DDR4-3000 CL16 Memory
Video Card(s) Gigabyte GeForce RTX 3070 8 GB GAMING OC Video Card
Storage Western Digital Blue SN570 / Samsung 850 EVO-Series 500 SSD / 2x HDD
Display(s) HP Omen 27i / Samsung S24F356FHU 23.5" 1080p
Case Phanteks Eclipse P350X ATX Mid Tower Case
Power Supply Corsair RMx 850 W 80+ Gold
Mouse Razer Basilisk V2
Keyboard Razer BlackWidow Elite RGB Wired Gaming Keyboard
Does anyone use a 3D print as a GPU stand? I've been needing one and have seen a lot of people using a PLA bracket or stand. Happened to have this little guy around, but the heat has always concerned me. Obviously the housing isn't getting up to the 90+ degree some hot GPUs can hit (R9 390 pictured) but with softening points of around 60- degrees I'm still a bit concerned. Any experiences?
3,652 (0.88/day)
GMT +2
System Name Red Radiance l under construction
Processor 5800x
Motherboard x470 taichi
Cooling stock wrath
Memory TridentZ Neo rgb 3600mhz (2x8 kit)
Video Card(s) Sapphire Vega 64 nitro+
Storage 970 evo nvme
Display(s) lc27g75tq
Case tt core x5 tge
Audio Device(s) sennheiser's pc323d usb soundcard
Power Supply corsair AX860i
Mouse roccat burst pro
Keyboard roccat ryos mk fx
Software windows 10
use thermocouple of multimeter to get what is the surface temp of contact point between card and the figure.
i doubt the shroud of the card goes close to 60°.
120 (0.09/day)
System Name Howling_Fjord
Processor Intel Xeon E5 2640 v3 @ 3398.39 MHz
Motherboard Huananzhi X99-F8
Cooling Cooler Master MasterAir MA410P, Fans Corsair AF120
Memory 16Gb (2x8) Micron Technology + 32Gb (2x16Gb) P/N: atermiter
Video Card(s) AMD Sapphire TOXIC R9 280X OC, EVGA GTX 1070 SC ACX 3.0
Storage SSD NVMe 250Gb +NVMe 1Tb + 2x 2Tb HDD+ SSD 1TB KingDian +SSD 240Gb
Display(s) Samsung 7.2 inches (18.3 cm) / 1280 x 720 pixels @ 23-60 Hz
Case Mymax Full Tower Horus black
Audio Device(s) -
Power Supply Cougar Gx 800W 80Plus Gold
Mouse -
Keyboard -
Software Microsoft Windows 10 (10.0) Enterprise LTSB 64-bit
Benchmark Scores https://valid.x86.fr/h7nzby https://gpuscore.top/furmark/show.php?id=328097
I was literally thinking about this yesterday, my gpu is on the first pcie channel so I'll need a taller stand, I'm looking for a cool art but I suck at 3d modelling.
Honestly, I wouldn't be concerned that much about the heat, if the inside of your case is hot enough for melt down some 3d printed support, then you have problems bigger then losing the support
95 (0.06/day)
Berlin
System Name Desktop
Reassuring, thanks! I was thinking it's probably fine, but obviously if I'm not totally sure I have concerns about potential disasters.
@SenditMakine check out Thingiverse! Here's the model I used: https://www.thingiverse.com/thing:2717606
UPDATE: Just came across this post on another forum going over some component modding FAQs. Seems heat is definitely not that much of an issue and they're recommending lots of plastic vinyl and regular ol' paints. The author also responded to a similar question saying it really doesn't get that hot. Helpful.
3,652 (0.88/day)
GMT +2
Processor 5800x
Cooling stock wrath
Case tt core x5 tge
Software windows 10
i have water heater with thermometer and at about 42-44° i cant hold my hands under the water.
run some benchmark for about 15mins so card can heat up and touch the shroud next to the figurine. if you can hold it more then 2-3 sec temp is less then 40-42
120 (0.09/day)
Audio Device(s) -
Mouse -
Keyboard -
95 (0.06/day)
Berlin
System Name Desktop
Man...
Now I'm addicted to it...
I'm so sorry to have ruined you like this. Feel free to DM me if you want advice or anything, I work in 3D printing.
13,630 (3.82/day)
Sunshine Coast
Processor AMD 5650GE
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
Software W11 Pro 64 bit
That's not really a good way to assess temperatures as heat is relative to your environment.
If you live in a cold region and are acclimatized, 42C will feel hotter to you than a person that lives in a hot region and is used to daily temps around 42C.
3,652 (0.88/day)
GMT +2
Processor 5800x
Cooling stock wrath
Case tt core x5 tge
Software windows 10
The skin also contains thermally sensitive receptors leading to pain sensation known as thermal nociceptors that respond to noxious or harmful temperatures. Nociceptors that are responsive to temperature signal to the central nervous system that tissue damage is imminent and that the affected body part should be withdrawn immediately from the thermal source (e.g. a finger on a hot plate). These receptors are active when the temperature of the skin falls below 15-18 °C or rises above 45 °C. When they are activated, the sensation is one of pain. Although the thresholds for activating heat and cold-sensitive nociceptors are usually described as being greater than 45 °C and less than 15°C, in some individuals mild cooling (25-31 °C) and warming (34-40 °C) of the skin can evoke sensations of burning and stinging as well as innocuous sensations of cold and warmth (Green, 2002).
95 (0.06/day)
Berlin
System Name Desktop
I did some benchmarking with my heat beast R9 390 last night. 94C on full load. No deformation to the model, so I'm fairly confident it's fine. A longer session that hot is the only thing I might keep an eye on. Switching that GPU out for my 3070 that arrived yesterday, so I don't expect I'll have any issues with that much cooler card.
Thanks for the help!
