3DMark Updated with New CPU Benchmarks for Gamers and Overclockers
47,218 (7.55/day)
UL Benchmarks is expanding 3DMark today by adding a set of dedicated CPU benchmarks. The 3DMark CPU Profile introduces a new approach to CPU benchmarking that shows how CPU performance scales with the number of cores and threads used. The new CPU Profile benchmark tests are available now in 3DMark Advanced Edition and 3DMark Professional Edition.
The 3DMark CPU Profile introduces a new approach to CPU benchmarking. Instead of producing a single number, the 3DMark CPU Profile shows how CPU performance scales and changes with the number of cores and threads used. The CPU Profile has six tests, each of which uses a different number of threads. The benchmark starts by using all available threads. It then repeats using 16 threads, 8 threads, 4 threads, 2 threads, and ends with a single-threaded test. These six tests help you benchmark and compare CPU performance for a range of threading levels. They also provide a better way to compare different CPU models by looking at the results from thread levels they have in common.
The 3DMark CPU Profile shows you how your CPU scores compare with other results from the same CPU model. It's a great way to check if your CPU is performing as expected. For overclockers, the 3DMark CPU Profile shows the overclocking potential of your CPU and provides more ways to track and measure the gains from overclocking.
More cores, more threads
The trend in processor development is towards an increasing number of cores. More cores mean more work can be performed at the same time.
Simultaneous multithreading (SMT) enables each core to run multiple threads. The more threads you have, the greater the throughput of work.
However, core counts are increasing faster than the ability of popular applications to make use of them. Some tasks are more suited to multithreading and multiple cores than others.
A modern CPU benchmark should demonstrate the benefits of having many cores and threads by scaling beyond 16 threads. It should also show how a processor performs for gaming and other real-world activities where performance rarely scales beyond a modest number of cores and threads.
It is not possible to represent both these aspects of CPU performance with a single number. A different type of benchmark is needed.
3DMark CPU Profile benchmarks
The 3DMark CPU Profile includes six tests that feature a combination of physics computations and custom simulations. All six tests use the same workload; it is only the amount of threading that changes, with tests limited to using either 1, 2, 4, 8, 16, or the maximum number of available threads.
Each of the six tests produces a score. Scores are comparable across tests. You can compare the 8-thread score with the 4-thread score, for example. A higher score means the CPU performed the work faster.
A hardware monitoring chart shows you how the CPU clock frequency and CPU temperature changed while the tests were running.
How to benchmark and compare CPU performance
The 3DMark CPU Profile shows you how your CPU scores compare with other results from the same processor.
The green bars on the 3DMark CPU Profile result screen show you how your scores compare with the best scores for your CPU. The longer the green bar, the closer your score is to the best result for your CPU model.
The median score, shown by the marker, shows the performance level you should expect for your CPU. In most cases, the median represents performance with stock settings. If your score is below the median, it may indicate a problem with cooling or background processes. Check the hardware monitoring chart to see how the CPU temperature changed during the run.
The distance from the median marker to the end of the bar represents the overclocking potential of the CPU. For overclockers, the 3DMark CPU Profile provides more ways to measure the effects of overclocking and more ways to compete for the highest scores!
Please note that these features are powered by benchmark results from 3DMark users. These insights may be unavailable for some CPU models until enough results are submitted.
Your 3DMark CPU Profile scores should increase up to the number of threads supported by your CPU. In this screenshot from a CPU with 4 cores and 8 threads, you can see that the scores for 8 threads, 16 threads and Max threads are the same within the usual 3% accuracy range for UL benchmarks. For CPUs with SMT, which have more threads than cores, the benefit of having more threads decreases beyond the number of CPU cores.
Six levels of CPU performance
The 3DMark CPU Profile includes six tests. These six levels make it easier to compare the performance of different CPU models by looking at the results from thread levels they have in common.
Max threads
The Max-threads score represents the full performance potential of your CPU when using all available threads. The practical use cases for this score lie outside of gaming in extremely heavy, multithreading workloads such as movie-quality rendering, simulations, and scientific analysis.
16 threads
Computationally intensive tasks such as digital content creation and 3D rendering benefit from more threads, but the 16-threads score is less relevant for estimating practical gaming performance.
8 threads
Modern DirectX 12 games make better use of multithreaded performance beyond 4 cores. The gaming performance of a CPU usually correlates most closely with the 8-threads score. This score also has a high correlation with the 3DMark Time Spy CPU score.
4 threads and 2 threads
Older games developed for DirectX 9 are often bottlenecked by the CPU on modern gaming PCs. The frame rates of popular esports titles, such as DotA 2, League of Legends, and Counter-Strike: Global Offensive, usually correlate most closely with the 2-threads and 4-threads scores.
1 thread
The 1-thread score is a fundamental measure of the processor's performance. For games and real-world use cases, however, the multithreaded scores are usually a better indicator of practical performance.
14,078 (3.82/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
What's the point of linking the TPU main site if it's exactly the same shit shown here?
Give us a download link for the benchmark.
3,328 (0.81/day)
Athens, Greece
Memory 32GB - 16GB G.Skill RIPJAWS 3600+16GB G.Skill Aegis 3200 / 16GB JUHOR / 16GB Kingston 2400MHz (DDR3)
Storage NVMes, ONLY NVMes/ NVMes, SATA Storage / NVMe boot(Clover), SATA storage
MAX 16 threads because .... Intel.
3,328 (0.81/day)
Athens, Greece
"1, 2, 4, 8, 16, or the maximum number of available threads." Because... reading comprehension.
Someone can feel confident without being rude. Think about it.
It seems you are right here, checked a score with a ThreadRipper. But, you have to improve your manners.
599 (0.15/day)
Germany
System Name Main Machine
Processor Intel i9-13900KS
Motherboard ASUS ROG Maximus Z790 Apex
Cooling Water cooling, 2x EK-DDC 3.2 PWM, 1x360mm+1x240mm+1x120mm EK, Mora 360 Pro, EK-Quantum Velocity 2
Memory G.SKILL 32GB DDR5-7200, 7200J3445G16GX2-TZ5RS
Video Card(s) ASRock RX 7900 XTX Aqua
Storage 2x WD_BLACK SN850X 1TB und 2TB, 2x8TB Seagate Ironwolf
Display(s) ASUS ROG Strix XG27WQ 27inch 165Hz FreeSync Premium Pro
Case Cooler Master COSMOS C700P
Audio Device(s) Turtle Beach Elite Pro Tournament + Elite Pro TAC
Power Supply Corsair AX1600i 1600W Titanium
Mouse Logitech G903 LIGHTSPEED Wireless
Keyboard ROCCAT Ryos MK Pro
Software Win 11
Thank for the info.
I will check it out to see where my 5900X is on this scale in comparison to other 5900X's with the Curve Tuning that I applied.
9,340 (5.38/day)
Louisiana
Keyboard G710+x3
Was looking for available for win-11 only lol
5,545 (0.96/day)
System Name Cyberline
Mouse Elecom EX-G
Keyboard Rapoo V700
Well post some results people
9,340 (5.38/day)
Louisiana
Keyboard G710+x3
Not sure what these editions are so unlikely anyone would buy yet another 3dmark just for this test.
1,260 (0.30/day)
Artem S. Tashkinov
What does it test?
Why does it cost money?
Sorry, GeekBench5 looks like a whole better idea.
167 (0.06/day)
Funny how a 7980XE at 5.2Ghz barely beats a stock 5950x in the 16 and Max thread test. At consuming 10x more power
freeagent
8,498 (3.77/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
Thank for the info.
You can check on hwbot too :toast:
1,638 (0.30/day)
Azalea City
System Name Main
Processor Ryzen 5950x
Motherboard B550 PG Velocita
Cooling Water
Memory Ballistix
Video Card(s) RX 6900XT
Display(s) MAG401QR
Case QUBE 500
Audio Device(s) Logitech Z623
Power Supply LEADEX V 1KW
Mouse Cooler Master MM710
Keyboard Huntsman Elite
Software 11 Pro
meh...
The whole suite is on sale on steam for $5.
1,897 (0.46/day)
There is no "download link". You have to have 3DMark installed and activated with either the Advanced or Pro key. Then you can install this benchmark as DLC from settings. It does not exist as a standalone program.
There is the free (demo) version that has restrictions and does not include this CPU test. Then the Advanced version that unlocks nearly everything most people could ever want and costs (last i checked) under $5 and the Pro version that is used by companies for mass testing (hence its much more expensive). Anyone who is passionate about benchmarking likely already has the Advanced edition as it's relatively cheap.
9,340 (5.38/day)
Louisiana
Keyboard G710+x3
I did get the steam version of 3dmark for 4.99 long ago whether this is included or not I have no idea doubt I'd pay for this addition.
1,897 (0.46/day)
Not included by default. You need to download and install 3Dmark via Steam first (if you do not have it already). After that you start it and go to options from where you can install the CPU Profile 1.0 DLC. It's a free DLC so you dont have to pay extra for it. Infact i think all DLC's for the Advanced edition are free. I know Steam lists some like Port Royal as paid but i think that only applies to basic edition users who want to buy one specific DLC.
2,541 (0.38/day)
People's Republic of America
Processor i9-14900K Direct Die
Motherboard MSI Z790 ACE MAX
Cooling 2X D5T Vario, XSPC BayRes, 3X Nemesis GTR560, NF-A14-iPPC3000PWM, NF-A14-iPPC2000PWM, IceMan DD
Memory TEAMGROUP FFXD548G8000HC38EDC01
Video Card(s) MSI 4070 Ti Super w/Alphacool Eisblock Aurora RTX 4070TI Ventus with Backplate :13724
Storage Samsung 990 PRO 1TB M.2
Display(s) LG 32GK650F
Case Thermaltake Xaser VI
Mouse Logitech
Keyboard Logitech
Software Win11PRO
245 (0.11/day)
Problem is that we are in the era where people knows "everything" and make comments by just "reading the title". Just tired of that.
Nothing personal against you though.
3,328 (0.81/day)
Athens, Greece
Yes, indeed. I am in an era where keyboard fighters insult others, who they don't know, just to feel better.
So, just out of curiosity. How did you managed to know "everything" about me, and especially my problem with "reading comprehension", by just "reading one post"?
And don't worry, I am not tired of people who know "everything". So, feel free to explain.
Mussels
Freshwater Moderator
58,413 (7.95/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Look, you started this by making a troll post before even reading the content so his reply was fair game to call you out on it.
599 (0.15/day)
Germany
Software Win 11
What does it test?
It is part of the 3DMARK suite for example it is in 3DMark Advanced Edition.
I bought this suite some years ago directly from their website and I received this update yesterday.
This suite contained until now mostly Graphic card tests and now they added this CPU oriented test.
The famous benchmark tools like Time Spy, Fire Strike and Port Royal are all contained in this suite.
It also contains stress tests like Fire Strike Extreme stress test which are used to test the stability of GPU OC:
Many enthusiast like me :D who like to OC their GPU to the limits uses these benchmarks to compare in the online database how good they are compared to others with similar card or competitors card and also to do Stress test to check if OC will be at all stable in games.
There are even challenges like on HWBOT to reach the Ultimate OC to be on the top of the chart on 3DMARK website.:p
I am not part of that community. My target is to get best daily gaming OC setting but not getting an OC that will be stable for one run in order to reach top of the chart. :laugh:
So for me personally, it was worth to buy this suite to find good and stable OC conditions on my GPU in the past. I have been using it since the days of Vega 64 card.
3,328 (0.81/day)
Athens, Greece
And I said he was right. I misinterpreted what I read about maximum threads and he was right. That first post was 100% wrong. At least in this case.
But, was it a fair game and something "I started", coming to conclusions about the other person based on a mistake?
Do you say that every person who posts something inaccurate or just wrong in this forum, should accept personal judgement in the boundaries of insults without reacting because "he/she started"?
As I said, he was right. But he posted, TWICE, with the wrong, in my opinion, attitude. I did it ONCE with the importand difference that I was not targeting someone, I was corrected.
PS I don't try to start a flame war here. You may delete whatever you find off topic, just delete everything, not some.
MxPhenom 216
ASIC Engineer
13,006 (2.50/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27AQM 240Hz G-Sync Fast-IPS | Gigabyte M27Q-P 165Hz 1440P IPS | Asus 24" IPS (portrait mode)
Mouse Razer Viper v2 Pro
