- Nov 4, 2019
- 19 (0.01/day)
Processor | Ryzen 5800X3D |
Motherboard | MSI B450 TOMAHAWK MAX |
Cooling | Noctua NH-D15S |
Memory | Crucial Ballistix 32GB DDR4 3600MHZ |
Video Card(s) | Gigabyte GeForce 4070 Ti Gaming OC |
Display(s) | Gigabyte G24F-2 |
Case | BeQuiet 500DX |
Audio Device(s) | Creative Sound BlasterX AE-5 Plus |
Power Supply | Seasonic Focus GX 750W |
Mouse | Razer Mamba Elite Optical |
Keyboard | Razer Huntsman |
I own a Gigabyte 4070Ti Gaming OC and when GPU Temp stays within the range of 50-60 degrees, the delta between the GPU temp and Hotspot usually stays within 20 degrees (see screenshots)
As soon as my GPU temp reaches 65-70+ , the hotspot can get as high as 100degrees and sometimes 105 degrees (see screenshot), which is more than 25 delta difference.
I tried to tighten a bit more the backplate screws (without removing the warranty sticker on one screw) and the result remain the same.
My case is a BeQuiet 500DX, well ventilated and ambient temp is around 21 degrees. Idle temps of GPU never exceed 34degrees with hotspot being around 42degrees. I have also installed the anti-sag provided from Gigabyte.
Is 100 degrees still considered a safe temp for the GPU hotspot ?
NB : RMA procedure is a nightmare with Gigabyte in my country, so should i consider re-pasting the gpu, even if i have to remove the warranty sticker on one screw ? Do i also have to apply new thermal pads in case of repasting the gpu ?
