4K Dell S2721QS for $200
4,996 (3.85/day)
Colorado, U.S.A.
Software Windows 11 Home
Any opinions on the
  • Dell S2721QS
which is a UHD (3840 x 2160) monitor for $200 (on Amazon)
I like small, and am happy with 60Hz
12,906 (1.94/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
I like small
27" is small?
I personally am not crazy about the silver case. I would rather it be black. But that's just me and means nothing in terms of image quality, or your preference.
Before buying from Amazon, verify what you are getting. I note the specs published on Amazon say "240 volts". They also say, "1 A batteries required"! ??? Assuming seems to be getting me into trouble more often these days, but I assume Amazon is wrong - again.
4,996 (3.85/day)
Colorado, U.S.A.
I see the
  • Sceptre U275W-UPT is 4K ($180 on Amazon)
  • KOORUI 4K/N07 is 4K ($161 after the Amazon coupon)
but I trust Dell more when it comes to monitors.
580 (0.30/day)
Moscow, Russia
Processor Intel 12600K
Video Card(s) Palit RTX 4080
Display(s) Dell S2721qs
Case Phanteks P300A Mesh
Mouse Glorious Model D-
It's alright, just don't watch movies on it. But while on every count it's not great, it's still better than the cheap AOC 4K panel I also had in contrast and colors. Also there's a weird "temporary burn-in" effect: pictures that have been static on the screen for a while remain as slowly fading silhouettes for around 10-15 seconds, depending on the color and time they've been on screen. Response time is okay but it's still a cheap 60hz IPS.
tabascosauz
8,034 (2.37/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
Image retention is nothing new to all LCD panel types. Mild cases should always fix themselves in short order. Even if it's not OLED, it's not the greatest idea to leave static images up on a monitor with high brightness for long periods.
Any opinions on the
  • Dell S2721QS
As long as you aren't a picky or serious gamer, it looks fine. I'm not sure who makes the panel, but it has decent contrast for IPS and a normal RGB subpixel layout, no problems there. Between the 2721QS and 2722QS, the uniformity looks generally okay too.
Dell S2721QS Review - RTINGS.com
