5800X3D CO and RAM - Thoughts?
vroktylF
3 (0.27/day)
Just trying to catch the low hanging fruit here. If any of these settings isnt worth the hassle or if some is obviously "wrong", please tell.
MSI B450 GAMING PRO CARBON AC - AGESA ComboAM4v2PI 1.2.0.Cc
5800X3D with Pearless Assassin 120
4x8GB SR Crucial Ballistix DDR4 3600 16-18-18-38
PowerColor RX 7800 XT Hellhound/Red Devil (@1100mV, core@stock, mem@2514, power +15%)
Attaches pictures of
XMP profile 1 stock -
XMP profile 2 stock - (This seems to change SoC and VDDP voltages for some reason)
XMP profile 1 changes - Settings with red numbers is changed, except for tRFC, when set to 560 system didn't boot and needed a cmos reset. Everything else is set to AUTO.
XMP profile 1 tuned - Reported timings from Zentimings
mem.png - Thaiphoon burner reported memstick specs.
Curve optimizer -30 (preferred cores -25)
C-states - Enabled
CPPC - Enabled
CPPC Preferred - Disabled
SVM mode - Disabled
It was a while I looked into this and it seems that later AGESA versions have higher core clocks voltages?
dgianstefani
TPU Proofreader
5,236 (2.02/day)
Swansea, Wales
Benchmark Scores Legendary
It doesn't really matter how you tune it. Before the 9800X3D the X3D chips don't gain much if anything from tuning. Maybe 1-3 % in games at best.
At best you might reduce your power consumption slightly and improve your productivity app performance.
968 (0.42/day)
Uttar Pradesh, India
Processor AMD R7 1700X @ 4100Mhz
Motherboard MSI B450M MORTAR MAX (MS-7B89)
Cooling Phanteks PH-TC14PE
Memory Crucial Technology 16GB DR (DDR4-3600) - C9BLM:045M:E BL16G36C16U4W.M16FE1 X2 @ CL14
Video Card(s) XFX RX480 GTR 8GB @ 1408Mhz (AMD Auto OC)
Storage Samsung SSD 850 EVO 250GB
Display(s) Acer KG271 1080p @ 81Hz
Power Supply SuperFlower Leadex II 750W 80+ Gold
Keyboard Redragon Devarajas RGB
Software Microsoft Windows 10 (10.0) Professional 64-bit
Benchmark Scores https://valid.x86.fr/mvvj3a
X3D CPU you can just run XMP and call it a day but you can get some little extra performance with tuned timings.
I will post some quick screenshot of what I got with my C9BLM kits. These may work for you. the best performance for these sticks are with
GDM Disabled CL15. But be aware if you don't know how to OC RAM you can corrupt your windows installation. So please careful make a system restore point before attempting
to run GDM disabled.
C9BLM are basically the best Rev.E ICs you can get it can do well over 4000MT. However you will get WHEA errors in most cases above 1900/1967 FCLK.
If you want to learn how to OC RAM on the 5800X3D then start here.
8,681 (3.99/day)
System Name Bragging Rights
Processor Atom Z3735F 1.33GHz
Memory 2GB DDR3L-1333
Case Veddha T2
Mouse MX Anywhere 2
Software W10 21H1, barely
Tune RAM for stability with any X3D chip, since RAM speed and latencies have minimal impact on them. DDR4-3600 and 1900 1800 FCLK is very very close to peak performance already.
Yes, there's a tiny bit of performance margin if you push for a memory OC, but honestly unless you're prepared to do all the stability testing that entails, just don't bother. Your time is so much better spent on looking for the optimum offsets for curve optimiser.
X3D memory tuning is definitely not low-hanging fruit. It's the withered last leaf at the very top of the tree and almost not worth reaching for.
edit - whoops, I can't even divide by 2 today :\
2,064 (0.78/day)
Ibiza, Spain.
System Name Main
Processor R7 5950x
Storage six M.2 pcie gen 4
Display(s) Sony 50X90J
Case Tt Level 20 HT
Power Supply Corsair RMx 750w
Mouse Logitech G903
Keyboard GSKILL Ripjaws
VR HMD NA
Software win 10 pro x64
@vroktylF
unless something changed i didnt read about, C states off, and all cppc enabled.
should see if WTRL 16 gives better perf (shouldn't it be 4x WTRS ?)
vroktylF
3 (0.27/day)
Thank you for your answers!
Hmm, CPPC enabled, CPPC preferred cores disabled and C-states enabled is whats seems to be suggested here
What about the XMP profiles? Profile 1 and profile 2 differs. Hard to find any information about the difference but there is some about Profile 1 including basic timings and that the motherboard sets the rest. Profile 2 is supposed to be a full SPD profile including all the timings and nothing left for the board to decide.
I think i've always been running Profile 2 and have not noticed the difference in voltages.
Screenshot from hwinfo after Cinebench R23 been running for about 20 minutes. Its well over a year go since I tested this the last time and im pretty sure the core voltages and the power draw was lower. Any changes in AGESA lately? No problem holding 4.45ghz back then.
This is with CO -30 (-25 preferred cores) and stock XMP profile 1. Maybe its time for a repaste.
freeagent
9,635 (4.13/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
Might be, those temps are brutal for R23, I don't even see those for Linpack, unless it was summer.
Mine is air cooled, no real tune other than my curve and fclk/mclk. Stock power limits, pretty much stock. Dell territory.
vroktylF
3 (0.27/day)
Okey cpu and case fans all at 100% managed to get 15131 points. Case fans usually follows MB System sensor. Works good for gaming with <70C deg temps for both gpu and cpu and is reasonably quiet.
Maybe another fan for push-pull on the cpu would help all core workload.
Think thermal paste is OK after all.
also combined XMP profile 1 and 2. Think thats enough for now, lets see how the stability holds up over time.
8,681 (3.99/day)
Case Veddha T2
Mouse MX Anywhere 2
Dell territory.
I thought "Dell territory" was considerably under stock power limits, artificially crippled by Dell's zero-option BIOS so that they can get away with crappy cooling and the cheapest power delivery that functionally POSTs the CPU.
freeagent
9,635 (4.13/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
It feels like a Dell compared to my other CPU :D
But it plays games pretty decently..
