5850 Crossfire results with Physx Enabled :)
Enmity
454 (0.08/day)
New Zealand
System Name Enmity
Processor Intel i5 3570K 4.6Ghz@1.320vcore
Motherboard Asus P8Z77-V
Cooling Corsair H100
Memory 2 x 4 GB Mushkin Frostbyte 9-9-9-24
Video Card(s) 2 x MSI 5850's
Storage 1 x 90GB OCZ Vertex2 SSD, 1 x 1TB HDD, 3 x 320GB HDD
Display(s) Samsung XL2370
Case Coolermaster Storm Stryker
Audio Device(s) Asus Xonar DG PCI + Senn HD485's
Power Supply Corsair HX850
Recently I upgraded from my old 4850's to 2x MSI 5850's and managed to squeeze a lil 9800gt inbetween them too. the 5850's actually run at pretty decent temps even while overclocked but the 9800gt gets up to about 80-90C when running physx. I guess this is ok considering the complete lack of airflow between the 5850s but looks great none the less! :)
Heres a few pics
3,779 (0.64/day)
Latin America, Uruguay
System Name The Lizard v2.4
Processor Intel Celeron G1840 (for the time being
Motherboard Gigabyte GA-H81-S2PH
Cooling Intel Stock Fan
Memory 16GB Kingston HyperX 1600
Video Card(s) MSI Gaming GTX 750Ti (For the time being)
Storage 500GB Samsung F1, 160GB Maxtor "Older than god"
Display(s) AOC 28' LCD
Case Coolermaster N200
Power Supply Antec VP500P
Benchmark Scores No crashes in the last 24 minutes.
that 9800gt is a low power, right?
4,267 (0.66/day)
Sanford, FL, USA
Processor Intel i5-6600
Motherboard ASRock H170M-ITX
Cooling Cooler Master Geminii S524
Memory G.Skill DDR4-2133 16GB (8GB x 2)
Video Card(s) Gigabyte R9-380X 4GB
Storage Samsung 950 EVO 250GB (mSATA)
Display(s) LG 29UM69G-B 2560x1080 IPS
Case Lian Li PC-Q25
Power Supply Seasonic SS-460FL2
Mouse Logitech G700s
Keyboard Logitech G110
Rockin!
Perhaps since the 9800GT is just doing PhysX, underclock/undervolt?
Enmity
454 (0.08/day)
New Zealand
System Name Enmity
thanks for your feedback and yep the 9800gt is a zotac eco edition which is low power and doesnt require an additional power connector :)
I could possibly downclock the 9800 but...i dunno...making hardware slower isn't my thing lol If it isn't burning up i'll leave it as is for the time being. Im pretty sure nvidia cards are alright until about 90 or 100c?
qamulek
184 (0.03/day)
Just add in an extra fan forcing air between the 5850's and temps should go down a decent amount. Try it~
Enmity
454 (0.08/day)
New Zealand
System Name Enmity
Ive got these cards in a HAF 932 case which has 3x 230mm fans one on top, front and on the side, plus a 140mm on the back. So airflows not really a problem. Maybe one of those PCI system cooling fans might help a little though? or I can replace the 230mm fan on the side with 4x 120's - hmmm I wonder if 4 120's will cool better than the single 230?
crazyeyesreaper
Not a Moderator
9,824 (1.69/day)
System Name Old reliable
Processor Intel 8700K @ 4.8 GHz
Motherboard MSI Z370 Gaming Pro Carbon AC
Cooling Custom Water
Memory 32 GB Crucial Ballistix 3666 MHz
Video Card(s) MSI RTX 3080 10GB Suprim X
Storage 3x SSDs 2x HDDs
Display(s) ASUS VG27AQL1A x2 2560x1440 8bit IPS
Case Thermaltake Core P3 TG
Audio Device(s) Samson Meteor Mic / Generic 2.1 / KRK KNS 6400 headset
Power Supply Zalman EBT-1000
Mouse Mionix NAOS 7000
Keyboard Mionix
yes yes it will i replaced the top 230 and side 230mm fans with 3 120mm 80cfm coolermaster red led fans and the side panel theres now 4 120mm 80cfm coolermaster fans using a positive airflow setup temps on gpus 2 5850s dropped 10'c cpu dropped 5'c and chipset mobo dropped 4'c hdd temps went up a tad bit but thats more from the switch from negative to positive :) replacing the side 230mm with 4 120mms will make a huge difference direct cooling wise i would advise it just because i hate hot running components
newfellow
314 (0.06/day)
System Name ID
Processor Q9450 ~3.74Ghz
Motherboard ASUS-P5E
Cooling Air
Memory G.Skill CL4-8GB
Video Card(s) ATI/Geforce 5850/9800
Storage A-lot
Display(s) BenQ G2400WT
Case 900
Audio Device(s) Shitty ASUS FX;P
Power Supply OCZ GXS 850W
Software -
Benchmark Scores too many machines to spec
got same setup spinning here on Antec 900. hope you got some damn good side fan there.. just ripped down all cover plates on entire box to get clean airflow. With exception that I got 5850 & 9800GTX. Trying to get this functional under Windows Vista SP2 + Platform update, atm with fake VGA display adapter I created quickly. Seems needing to connect the NV card first alone.
Damn that's a tight squeeze you got there on CPU cooled to cards and cards themselfs. That's gonna need some serious air pushed in to it. Although these 58xx cards runs quiet and cold which is nice.
roteplex
1 (0.00/day)
Hey bro, is that 9800GT on full x16 slot or on a lower slot like 4x, or would that even work? and is the 9800GT bottlenecking your setup??
43,624 (6.41/day)
Memory 64GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Case Fractal Design North
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
"Hacked" Nvidia drivers to do that?
As far as I know all that is needed is Windows 7. A little guide on what to do would be nice.
