59.951Hz
5,137 (3.76/day)
Colorado, U.S.A.
Software Windows 11 Home
I have a 60Hz monitor and Windows runs it at 59.951 Hz
There is surely a reason, so I ask here.
Count von Schwalbe
Nocturnus Moderatus
3,154 (2.80/day)
Knoxville, TN, USA
Often there is an option for both. I have no idea why.
4,649 (0.94/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
59.94 is a TV standard, just double check your settings
9,489 (3.27/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
The reason is that's what it supports ? I have a laptop from work that says it runs at 59.99 Hz with no option for 60.0 Hz also. Does this cause any problem in particular ?
5,137 (3.76/day)
Colorado, U.S.A.
I also have no other options other than 59.951 Hz
1,237 (0.28/day)
California, unfortunately.
System Name Sierra
Processor Core i5-11600K
Motherboard Asus Prime B560M-A AC
Cooling CM 212 Black RGB Edition
Memory 64GB (2x 32GB) DDR4-3600
Video Card(s) MSI GeForce RTX 3080 10GB
Storage 4TB Samsung 990 Pro with Heatsink NVMe SSD
Display(s) 2x Dell S2721QS 4K 60Hz
Case Asus Prime AP201
Power Supply Thermaltake GF1 850W
My Dell monitor is the same way, with Vsync on I get 59-60 FPS. I wouldn’t worry about it.
13,300 (1.98/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
This has been going on for many years (see this from 2012). Some say it is a bug in Windows. It is not.
dirtyferret is correct.
The NTSC TV standard dictates a transmission spec of 29.97 frames per second "interlaced". Think of "interlaced" the same way we think of DDR RAM (double duty) or dual-channel - only real/true and not "in theory".
29.97 x 2 = 59.94
Depending on your version of Windows, your graphics solution, how the stars are aligned today (not to mention, Man cannot yet create perfection 100% of the time), that 59.94 may not be exact, or may be shown to be rounded up, or it may be rounded down.
FTR, mine says 59.950 Hz.
311 (0.22/day)
System Name Office,Home and Game PC
Processor Intel Core i5 12600k Up to 4.9 GHz
Motherboard Z690 Gaming X Gigabyte DDR4 Version
Cooling Fuma 2 Air Cooler
Memory 32GB DDR4 2x16 3600 MHz Patriot Viper Steel RAM
Video Card(s) NVIDIA GeForce GTX 1080 and RTX 3070
Storage 512 GB M2 PCI Ex 3.0 NVMe SX6000 Pro, 1TB NV2 Kingston M2 PCI Ex 4.0 and 4TB WD Blue SATA 3.0 HDD
Display(s) 27 inç 75 Hz LG
Case Cooler Master MB511
Audio Device(s) Creative 2+1
Power Supply 750W 80+ Bronze PSU High Power Element
Mouse Logitech Wireless
Keyboard Microsoft
VR HMD N/A
Software Windows 10-11
I'm having the same situation. When I looked from Windows, it was around 74.9 Hz. My monitor is 75Hz.
1,695 (0.98/day)
Over the Hill UK
System Name AMDWeapon
Case Montech 903 MAX AIR
Audio Device(s) SteelSeries Arctis Nova Pro Wireless
Mouse SteelSeries AeroX 5 l Forza Pad GameSir G7 SE l Razer Wolverine V3 TE for FPS (paddles)
Software Windows 11 Pro 24H2
Overclock your monitor to 60Hz? Can't remember what program it is to do that though...
4,649 (0.94/day)
it has has no real world impact for you, it's just how broadcast HD (both 1080i & 720p) send their signal. If you want more info on it you can check it out here
I worked in cable broadcast for a decade so I know a little about it but am hardly an expert, if you really wanted more info on it I would say check out a audio video forum
FYI, in windows 11 I believe they round it back up to 60hz
Count von Schwalbe
Nocturnus Moderatus
3,154 (2.80/day)
Knoxville, TN, USA
Monitor 1:
Monitor 2 (same model monitor, different GPU):
