5900X Curve Optimizer (Ryzen Master vs. BIOS) and findings?
55 (0.04/day)
Hi
I tried setting undervolt manually in BIOS through the curve optimizer there, took a lot of trial and error and never really found a stable setup. Alas, I decided to give the auto-optimizer in Ryzen Master a try. And to my surprise, it gave a completely different set of values, I put them in the CO in BIOS manually, and voilĂ ! PC runs stable, with highest cinebench score yet.
I decided to run Ryzen Master again ("Start Over"), and this time it gave a different result, with different values across every core. Ran benchmarks again, tested stability, and what do you know, it runs 100% stable with same cinebench score as previous auto-values.
My question is: How does this work? If I run the auto-optimizer a third time, it will most likely give another set of different values, and it will most likely work just as good. And as you can see, the clocks run about the same on average.
I put values from the auto-optimizer together with Cinebench and HWinfo stats (effective core clocks etc). And bonus stats from 30 min OCCT.
(Values, tests and stats)
System and config:
5900X - PBO Advanced - Motherboard - Auto limits (PPT 550W/TDC 210A/EDC 220A) - Global C-states + PSU current Auto
X570 Unify
3200mhz 14cl gskill
Seasonic 1000W
RTX 3080 Gaming X Trio
