6 pin fan header pinout for Palit/Gainward 40xx?
Arakon
1 (0.01/day)
Hi.
I recently got a Gainward 4080 Phantom GS that was deshrouded due to defective fans. It's currently running in a Fractal Ridge case, with the GPU case fans very close to the heatsink, so it is working great. However, I'm considering moving the setup to a larger case and would like to install a set of 92mm slim fans to it so it can be used independantly of case fans again.
Only snag: I can't find the pinout of the 6 pin fan connector on these cards. Apparently Palit and Gainward share the exact same fan pinouts.
Does someone have more info? Or a clear photo of the fan adapter board that comes with these cards (6-pin plug to a rectangular PCB, which in turn has 3 4-pin outputs) so I can trace them back from there?
