6900XT Toxic hitting 91C in Warzone 2.0
1,773 (1.00/day)
Over the Hill UK
System Name AMDWeapon
Case Montech 903 MAX AIR
VR HMD -
Software Windows 11 Pro 24H2
Its as I said really. Doesn't make sense to me.
1,764 (0.32/day)
Azalea City
System Name Main
Processor Ryzen 5950x
Motherboard B550 PG Velocita
Cooling Water
Memory Ballistix
Video Card(s) RX 6900XT
Display(s) MAG401QR
Case QUBE 500
Audio Device(s) Logitech Z623
Power Supply LEADEX V 1KW
Mouse Cooler Master MM710
Keyboard Huntsman Elite
Software 11 Pro
91C on the GPU or the hot spot?
895 (0.49/day)
Hits what in Timespy extreme or other 4k games or bench? Why the surprise?
Alt R, check fan profile, voltage curve and power limit in AMD software.
9,666 (3.46/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
Make sure you turn off the zero fan feature. Download AMD software it is very different from Nvidia settings so prepared to be blown away. The zero fan feature is set to have the fans not turn on until the GPU hits 50 C. When you then have the GPU turn up in frequency the fans will have to work that much harder. The toxic is a serious card and should not be that high in temp if you have configured it properly.
18,584 (2.67/day)
System Name AlderLake
Thought you bought it as "B stock"
1,773 (1.00/day)
Over the Hill UK
VR HMD -
5,931 (0.81/day)
Ikenai borderline!
System Name Firelance.
Processor Threadripper 3960X
Mouse Logitech G604
Keyboard Razer Pro Type Ultra
Post GPU-Z screenshot.
3x0
973 (1.15/day)
Processor AMD Ryzen 7 5800X3D
Motherboard MSI MPG B550I Gaming Edge Wi-Fi ITX
Cooling Scythe Fuma 2 rev. B Noctua NF-A12x25 Edition
Memory 2x16GiB G.Skill TridentZ DDR4 3200Mb/s CL14 F4-3200C14D-32GTZKW
Video Card(s) PowerColor Radeon RX7800 XT Hellhound 16GiB
Storage Western Digital Black SN850 WDS100T1X0E-00AFY0 1TiB, Western Digital Blue 3D WDS200T2B0A 2TiB
Display(s) Dell G2724D 27" IPS 1440P 165Hz, ASUS VG259QM 25” IPS 1080P 240Hz
Case Cooler Master NR200P ITX
Audio Device(s) Altec Lansing 220, HyperX Cloud II
Power Supply Corsair SF750 Platinum 750W SFX
Mouse Lamzu Atlantis Mini Wireless
Keyboard HyperX Alloy Origins Aqua
RDNA2 don't throttle until 110+°C hotspot, so it's fine from that standpoint. The only thing you can try is use a new thermal paste that's more suited for GPU use (high viscosity, like Thermalright TFX) and don't exhibit pump-out issues.
9,666 (3.46/day)
Cooling In Win SR36
I would not take a GPU apart for the first time unless I was technically proficient enough. It is straight forward but still really easy to do something to hurt the card.
I swear the best thing I like about you is how you always try to help people with GPU problems.
2,975 (2.05/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~2000 Video Games
pretty normal temps for RDNA2... (can only be hotspot)
1,773 (1.00/day)
Over the Hill UK
VR HMD -
Just messed about with fan curves so got the heat under control with 100% fan speed.
18,584 (2.67/day)
1,773 (1.00/day)
Over the Hill UK
VR HMD -
Erm... Okay. How?
2,975 (2.05/day)
Germany
18,584 (2.67/day)
Erm... Okay. How?
Let the sensor tab run in the background while you play warzone, then alt tab and take a screenshot of the sensor tab.
And/or Aterburner/RTSS OSD.
1,773 (1.00/day)
Over the Hill UK
VR HMD -
I'll do that. Just going to have some "medication" and I'll report back.
17,503 (4.66/day)
Motherboard B650 Steel Legend
Cooling Frost Commander 140
Case NZXT H710 (Red/Black)
Just fyi, 91 celsius hotspot temperature is normal, its also called Junction temperature. - my 6800 xt hits 89 celsius junction/hotspot and 62 celsius core temps all the time in gaming, it is very normal, don't let a hot spot/junction temp upset you, pretend it doesn't exist, in years past, the only temp you saw was core, and your hotspot was probably the same as it is now.
also sidenote, I was in England this year for awhile, would have been neat to get a TPU meetup done for a few of us, maybe in the future
1,773 (1.00/day)
Over the Hill UK
VR HMD -
17,503 (4.66/day)
play a game with gpu-z running. then after 5 minutes of playing the game or so, close the game, then go to gpu z and double click the temp area next to gpu temp and gpu temp hot spot, that will give you the max temp readout, then screenshot that and return to us
1,773 (1.00/day)
Over the Hill UK
VR HMD -
Well it scares me...
I have severe anxiety, so I won't be going...
1,773 (1.00/day)
Over the Hill UK
VR HMD -
I've seen temps of 96C, I'm sending it back.
9,340 (5.18/day)
Louisiana
Keyboard G710+x3
Yeah seems silly hot to me frankly.
This hotpot nonsense doesn't give me any good feelings for amd gpu products.
18,584 (2.67/day)
1,773 (1.00/day)
Over the Hill UK
VR HMD -
Can you make a screenshot where you see that.
In warzone whilst dropping in.
Scared to even play a game in case it goes bang. This is only 87 but it can't be right with the fans at 100%?
