775 board, help choosing :)
Mussels
Freshwater Moderator
58,412 (7.80/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Short version: i'm starting a new job, and looking at upgrading my storage system.
I'd still like to stay 775 and most of the hardware, with one change - i need more SATA ports!
Does anyone know of an OCing (400FSB) 775 board thats not insanely expensive with 8 or more sata ports? if not, any reccomendations on decently priced PCI-E SATA cards?
I'm looking around 12-16 drives total, WITHOUT running RAID.
47,614 (7.45/day)
Why do you need a new board? Can't you just add PCI-Express based SATA cards to your current storage system? Since you're not doing RAID, you can even get PCI based SATA cards.
I doubt if you have desktop boards with 12 SATA boards. I'd recommend you take the Gigabyte GA-EP35-DS3R or the GA-P35-DS3R (Rev. 2.0) they come with six ports from the ICH9R southbrige plus two from the GA SATA II controller (8 in all) + take a four port SATA card.
If you're using a P35 based board, I'd suggest you not to use the PATA/IDE for connecting your optical drive(s). The IDE controller has been disintegrated from the southbridge and runs from the GA controller. I am facing erratic operation with it.
Mussels
58,412 (7.80/day)
Oystralia
its P965 and someones asked to buy it off me - so i'm looking if theres better alternatives to the PCI-E cards (i wont go PCI, too slow)
The problem i'm facing is that its only got two PCI-E slots free and they're only 1x. That would let me buy 2x cards for an additional 4 drives, but no more.
If you know of any PCI-E 1x cards with 4 sata II ports, that would be a big bonus :)
King Wookie
1,197 (0.19/day)
Johannesburg, South Africa
System Name Blackbox
Processor Intel i5 750 @ stock for now
Motherboard EVGA P55 LE
Cooling Corsair H50 with 2 x Zalman ZM-F3 push/pull
Memory 2 x 2g team extreem DDR3 2000
Video Card(s) Asus GTX 460 Top
Storage Seagate 500.12, Seagate 320.11
Display(s) BenQ FP222W - 22 inches
Case CM 590 with 5x various fans (Thermalright/Noctua)
Power Supply Corsair HX620
Software XP home SP3
Umm, check out the Sunix cards.
I'm pretty sure they do 3 way SATA cards.
They're quite cheap and seem to be reliable.
Mussels
58,412 (7.80/day)
Oystralia
thanks but they seem rare in Australia - i can only find a single store with one, and its a two port.
Just to clarify - the current mobo has 7x SATA-II and 1x E-sata. 3x PCI-E 1x slots means i can add another 6 drives total - making 13 my max. all 4 port cards i find, need a 4x slot :(
The cost of that would add up to 100-150, which is in the ranges of an entirely new motherboard, hence the idea of looking for a new one.
I am definately up for suggestions at this point, as i want to add more storage to the system soon and SATA ports are the limiting factor.
OnBoard
3,033 (0.45/day)
Finland
Processor Core i5-750 @ 3.6GHz 1.136V 24/7
Motherboard Gigabyte P55A-UD3, SATA 6Gbit/s & USB3.0 baby!
Cooling Alpenföhn Brocken HeatpipeDirectTouch
Memory Geil Ultra Series 4GB 2133MHz DDR3 @ 1440MHz 7-7-7-24
Video Card(s) Gigabyte GTX 460 1GB OC (mostly stock speeds)
Storage OS: Samsung F3 500GB Games: Samsung F1 640GB
Display(s) new! Samsung P2350 23" FullHD 2ms / Mirai DTL-632E500 32" LCD
Case new! Xigmatek Midgard/Utgard side window with red cathodes, 1x140mm & 3x120mm fans
Audio Device(s) new! ASUS Xonar DG & JVC HA-RX700 headphones
Power Supply Cougar CM 700W Modular
Benchmark Scores Logitech UltraX Premium & G5 laser v2 + Ulti-mat Breathe X2 for fragging
Mine has one PCI-e 4x slot if it would help, other than that it's pretty close to yours, being only the Plus version. http://pics.computerbase.de/1/7/6/8/1/22.jpg
Surely there has to be one with 8 sata too, I remember seeing one sometime last year and wondering who'd ever need them all ;)
Mussels
58,412 (7.80/day)
Oystralia
your board is quite different!
7th sata II is in the top left of the board - above the USB plugs. Its black and a very weird location.
The problem isnt needing just a board with 8 sata (As i DO use the E-sata) its finding one with at LEAST 8 sata (hopefully e-sata too) _AND_ more PCI-E slots. I'd want 2 16x slots, or 1 16x and 2 4x.
with a 16x card i can fork out a lot of dough, but get a card that takes at least 8 drives.
King Wookie
1,197 (0.19/day)
The only boards I've seen with 8 x SATA, are the more expensive boards.
Would it not be more cost effective to simply consolidate on a few high capacity drives?
Terabyte drives go a long way.:rockout:
G0DZLR
32 (0.00/day)
Aus
Processor Intel C2D E6600 @ 2.97GHz 1.3V
Motherboard ASUS P5W DH DLX
Cooling Thermalright Ultra 120
Memory 4GB Veritech PC-6400 DDR2 800 @ 825MHz 5-5-5-12
Video Card(s) EVGA 8800GTS 640MB @ 675/2100
Storage x4 Samsung 500GB
Display(s) Samsung 204B + Viewsonic VA903B
Case Lian-Li PC-B25B
Audio Device(s) Creative X-Fi
Power Supply OCZ GameXstream 600W (fan modded)
Software Windows 7 RC1
i was about to suggest that just as you posted lol ^
im finding that to be the way to go. a billion small drives is just aiming toward a heavier system thatl break your back imo. a few big drives could solve that prob
Mussels
58,412 (7.80/day)
Oystralia
two problems: most tera drives are having reliability issues right now, and i already have 6x500GB drives in the system. I've got various other drives around the place (consolidating them)
Its a tricky situation, as the only solution seems to be ditch the video card and get a 8 port SATA card in the 16x slot, or buy an actual server system.
King Wookie
1,197 (0.19/day)
Do you actually need to have all the drives connected at the same time?
If not, a decent caddy system would go a long way.
Icybox make some nice ones.(or Icebox, can't remember off hand)
I'll be looking for boards for you in the meantime.
King Wookie
1,197 (0.19/day)
MSI P965 Platinum
Gigabyte GA-P35C-DS3R
Asus P5K Deluxe/WiFi-AP
The Asus is probably your best bet, as a dual slot gfx card will be covering only a pci slot, and the black pci-e x 16 slot runs at pci-e x 4.
As I don't know any supplier sites in your neck of the woods, you would have to check on pricing.
There's probably alot more options, but I'll leave it to you to go digging.
OnBoard
3,033 (0.45/day)
Finland
Mussels
58,412 (7.80/day)
Oystralia
the asus is the one in my main rig :D i know the board well.
pondering this board with the 8600GT in the 4x slot, leaving the 16x slot free.
Might be a good option. Its looks better thinking about it - doing that would give me a 16x slot and 2 1x slots all in the same location - easier for cable management too.
10x SATA ports if i use the PCI-E 1x first, and depending on my needs i can get a 4/8 port PCI-E card for the big slot.
Thanks for the ideas, i originally was just looking for more onboard SATA.
GA-P35-DS3R is better option than GA-P35C-DS3R, still 8xSata, but no DDR3 support to raise price. 114€ here, propably cheaper there.
http://www.links.co.jp/html/press2/image/gag33ds3r7.jpg
good points/suggestions. I think the P5K-E might be the winnar due to the second '16x' slot - the PCI-E/sata capabilites of that giga match the one already in the system/
King Wookie
1,197 (0.19/day)
Don't forget that an external on the firewire works well.:rockout:
They're pretty much a standard in the recording industry, and their data throughput is quite good. (we record multi channel 24 bit audio straight to them.)
OnBoard
3,033 (0.45/day)
Finland
Mussels
58,412 (7.80/day)
Oystralia
the problem is that its mostly for media storage, not backups. Its quite a chore to connect/disconnect multiple drives, and the amount of power bricks would be much excessive.
The other concern is overheating - i've got a an E-sata cage, and unless i open the cage and direct a fan at it, every drive in its overheated to some extent.
That fits the needs too, but its only $25 cheaper than the P35 asus board.
Wile E
Power User
24,318 (3.59/day)
System Name The ClusterF**k
Processor 980X @ 4Ghz
Video Card(s) Evga GTX 580
What cpu do you plan to put in it? If you don't need more than fsb 1066 support, a 975X board might be an option. Like the P5W DH Deluxe.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131025R
6 sata ports, and you can use the the gfx slots at 8x. Running your card at 8x, and a SATA controller at 8x.
Alternatively, have you considered getting an eSATA HDD tower?
Mussels
58,412 (7.80/day)
Oystralia
Could you describe this HDD tower? I'm not sure what you mean (more than one drive in the same cage??)
Wile E
Power User
24,318 (3.59/day)
2,228 (0.35/day)
Larisa, Greece
System Name StarCruiser Dark Knight v.2
Processor Intel® Core™ i5-3570K
Motherboard P8Z77-V LX
Cooling 1x custom W/C loop/ inflow:6x120 /outflow:4x120, 2x200
Memory Viper 3 Black Mamba (4x4GB)
Video Card(s) Powercolor LCS 5870
Storage 1X 128GB OCZ, 2 x 1.500 Gb Seagate
Display(s) Samsung 24" LC24F396
Case custom MDF case (I BUILT IT) check sig.....NOW
Power Supply Tagan 900 watt
Software Win 7 RC / Open office / Games
QUOTE]
price grabber:-
Strengths: Solid Capacitors, Great overclocking, No fans, lower temps than Asus P35.
Weaknesses: IDE/SATA connectors are a bit low, this may lead to some annoying cabling around the graphics card. Audio connectors are far back near the audio ports which would be tricky for front audio.
Summary: This motherboard was specifically purchased due to a number of features that the Gigabyte P35 board has. One is Ultra-Durable 2 which combines solid capacitors, low rds mosfets, and ferrite core chokes. Another is the great layout of the board where all 8 sata connectors are easily available. Also there are no bulky heatpipe structures on the motherboard and no fans that block heatsink installation.
This is not quite a budget board, but for a P35 motherboard, it's a pretty good deal. The non-visible feature is that this board can hit 450-500mhz when overclocking. It also handles memory up to around 1150mhz. The bios has many overclocking features and can both overvolt and undervolt the cpu core.
The board also held up well under pressure when installing a very challenging heatsink mount. Now installed, it has been very stable and doesn't run too hot. Highly recommended.
check details....
http://computers.pricegrabber.com/motherboards/m/38519572/details/
Mussels
58,412 (7.80/day)
Oystralia
Something like this, tho if you hunt, there are cheaper alternatives. Many of them come with a controller card already, so that drives the price up a little.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817332017
i. like. that. cage.
This is even better than a storage system, E-sata ftw.
The only concern is that it ONLY seems to run RAID - what about individual drives? Also cant find it for sale in aus :(
http://www.eyo.com.au/prod_E-VPMA-7...m_5_Bay_VPMA-75511R_SATA_HDD_eSATA_Black.html
Found this one - mentions "1x5 port Multiplier Functionality or JBOD mode"
http://en.vipower.com/products01_01.php?ID=166
Manufacturers link.
manf said:
* 1-to-5 Intelligent, native SATA II storage processor
* Compatible with today's SATA Gen1 and Gen2 host controllers
* OS independent, Driverless, Auto Configuration
* RAID 0, 1, support
* Embedded fast SteelVine Storage Processor
* Virtualization engine to simplify and improve utilization of storage devices
* Ultra-fast 3Gbps host and device port capability
* Compliant to SATA 1.0a specification, and the following SATA II specifications: Extensions to SATA 1.0a, Phy specification; Cable and Connectors Volume 1 and 2: and port Multiplier Specification
* 1x5 port Multiplier Functionality or JBOD mode
This seems almost exactly what i wanted - 5x SATA-II drives using one e-sata port. The P5B-E on the system now has 2x e-sata, thats 10x drives already :)
The only concern is the price - can anyone reccomend other models with 4-5 drives, especially if they're available in aus?
Wile E
Power User
24,318 (3.59/day)
Manufacturers link.
The one I recommend does Jbod as well. But it's a moot point really, considering you can't find one in Aussie land. lol.
Give some good places to hunt for them online that are for Aus, and I'll try to help you find one.
Mussels
58,412 (7.80/day)
Oystralia
i dont want JBOD - i want each drive available seperately. in JBOD, if one drive goes it, it can contain partial files from other drives, making it more risky.
mostly i just use www.staticice.com.au and www.shopbot.com.au
Two requirements after reading up: it mustnt need a specific E-sata (the one you linked only worked with sil image chipsets) and it must support NON raid mode. JBOD isnt good enough.
Hot swap would be great too - eventually i'll get more than one of these, and it'd be awesome to have an anime dedicated one :D
Wile E
Power User
24,318 (3.59/day)
Lifted this from wiki. I know my DFI mobo does this too.
wiki said:
Some RAID controllers use JBOD to refer to configuring drives without RAID features. Each drive shows up separately in the OS. This JBOD is not the same as concatenation
But at any rate, I'll get to lookin around. lol.
