8+4 pin EATX connectors
841 (0.16/day)
Edmonton, AB, Canada
System Name Project Neverending
Processor i9 9900K @ 5.0GHz
Motherboard Asus Maximus Formula XI
Cooling Corsair HX 150i Pro, Corsair ML 120/QL 120 fans
Memory 32 GB Corsair Vengeance Pro RGB 3200
Video Card(s) Asus RTX 2080Ti
Storage Samsung 970 Evo NVMe, 2 Samsung 860 Evo 1TB
Display(s) Acer Predator X34 (3440X1440), Samsung U28D590 (3840X2160)
Case Lian Li 011 Dynamic XL
Audio Device(s) Supreme FX X-Fi, Logitech 5.1 speaker system
Power Supply Corsair HX 1000i
Mouse Logitech G703
Keyboard Logitech G105
Benchmark Scores Updates coming soon ®
The new mobo I bought, Asus Crosshair VII, has an additional 4 pin CPU power connector. Does it have to be used, I don't have a single 4 pin cable, only the 8 pin style. An 8 pin cable will fit, but only in one orientation, would it matter which set of 4 pins is used?
phill
16,705 (3.43/day)
Somerset, UK
Power Supply EVGA 1600W T2
Mouse Corsair thingy
VR HMD No headset yet
You can use with just the 8 pin but personally I wouldn't. Depending on your PSU, you will be able to split the 8 pin CPU connectors or if it's a modular model, you'd be able to swap it out. The CPU plugs can only go in one way, so you shouldn't be able to plug something in that doesn't fit....
What PSU do you have? :) If it's the 860i in your system specs, I'm pretty darn sure, that you'll be able to split the 8 pin apart into 2 4 pin connectors :) That's how it is on my AX1200 :)
hat
Enthusiast
21,744 (3.33/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
So it has an 8 pin and a 4 pin? Must be one beefy board. Anyway, if you have two 8 pin CPU power connectors, the 8 pin will work just fine in the 4 pin slot. The 4 pin part of the 8 pin connector is physically and electrically the same as the 4 pin connector, with the only difference here being the additional 4 pins just hang over the port and plug into nothing. Similarly, you could even plug a 4 pin connector into an 8 pin port and it would work, unless you draw too much current with a crazy CPU/overclock. These things are designed to work this way - it's highly compatible.
841 (0.16/day)
Mouse Logitech G703
It is the 860, I did put that in the post, somehow the last line went poof.:confused:
It came with two 8 pin cable, but both a solid pieces. And thanks to Corsair changing pinouts between models none of the other cables I have will work.
Edit to add: Ya, first board I've seen with 8+4, caught me by complete surprise. Build came to a sudden halt lol.
8,083 (1.36/day)
Hillsboro, OR
System Name Main/DC
Processor i7-3770K/i7-2600K
Audio Device(s) on board
No, as long as the latch on the cable is oriented towards the catch on the motherboard connector. (and then it will only fit one way)
21 (0.01/day)
Processor AMD Ryzen 7 5800X
Cooling ARCTIC Liquid Freezer III 420 A-RGB (Black)
Memory 32GB Corsair Vengeance RGB Pro 3200 MHz
Video Card(s) MSI RTX 3080 Suprim X
Storage PNY CS3140 1TB SSD/Samsung SSD 970 EVO Plus 1TB/INTEL SSD 750/Samsung SSD 860 QVO 1TB
Display(s) Asus ROG XG32AQ
Case Corsair Obsidian 900D
Audio Device(s) Onboard audio
Power Supply Corsair AX860
Mouse Corsair M65 RGB Ultra
Keyboard Corsair Strafe RGB
Software Microsoft Windows 11 Pro
Hi there I have a corsair 860 not 860i and a asus rampage v extreme with 1 8pins and 1 4pins and the power supply have 2 split 4pins + 4 pins identify with CPU. If yours does not, complain with Corsair.
newtekie1
Semi-Retired Folder
28,473 (4.13/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
No, it doesn't have to be used, and it won't make any difference unless you are doing some serious overclocking.
6,844 (1.48/day)
Florida
System Name natr0n-PC
Video Card(s) EVGA 3070ti FTW
Storage Various
Display(s) Pixio PX279 Prime
Software XP/7/8.1/10
If you get a splitter or adapter make sure its thick gauge wire or it will burn in the socket when under load.
5,523 (1.03/day)
Gougeland (NZ)
System Name Cumquat 2021
Are you able to chuck up a pic with both ends of the 8 pin cable close up please
841 (0.16/day)
Mouse Logitech G703
Pain in the butt trying to hold it and the phone lol
1,386 (0.36/day)
Alabama, USA
Processor 5900x
Motherboard MSI MEG UNIFY
Cooling Arctic Liquid Freezer 2 360mm
Memory 4x8GB 3600c16 Ballistix
Video Card(s) EVGA 3080 FTW3 Ultra
Storage 1TB SX8200 Pro, 2TB SanDisk Ultra 3D, 6TB WD Red Pro
Display(s) Acer XV272U
Case Fractal Design Meshify 2
Keyboard Ducky One 2
I'm pretty sure the one on the right splits into a 4+4
2,707 (0.76/day)
On The Highway To Hell \m/
Like he says ^^^.
You can see where the one on the right can be split into 2 separate 4 pin connectors.
21 (0.01/day)
They got it. The one on the right got a longer clip. One for each 4pins conector.
5,523 (1.03/day)
Gougeland (NZ)
The left plug goes into the PSU the right plug will split into 2x4 pin plugs so use the one that fits the 4pin socket
841 (0.16/day)
Mouse Logitech G703
It doesn't split, believe me I tried. I just plugged in the one half that fit and powered on. None of the magic smoke got away lol
Edit: just to clarify the pic was on a single cable, just both ends. One goes to the PSU. But neither cable was capable of being split with anything short of a dremel.
phill
16,705 (3.43/day)
Somerset, UK
The one on the right is the CPU connector, the other looks like a PCIe connector?? One my AX units, there's normally some writing on the sides of them and they definitely split...
9,340 (3.30/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
If you look closer the clip on the left corresponds to the leftmost 2 pins. That's an 2+6 pin PCIe connector.
To me the left one looks like it can split, possibly. Looks like an 8 pin PCIe connector too.
2,963 (0.85/day)
Long Island
The manual should explain this in detail. Use Asus a lot less than we used to but their documentation has always been tops with this point adequately addressed on each board we've used. Typically the 8 pin is for the overclocker and you add the 4 pin if into LN2 and stuff.
EDIT: Are we talking Crosshaue VII Hero ?
https://dlcdnets.asus.com/pub/ASUS/...HERO/E13835_ROG_CROSSHAIR_VII_HERO_UM_WEB.pdf
Locations shown on 1-20 ... see 2nd note at bottom of page
Installation page 2-7 ...connect 8 pin or 8 + 4 pin ... never 4 pin only
Given what it says in the manual, Id say the 8 pin is needed, the 4 pin is optional. However, if you got it no reason it can't be plugged in.
11,878 (2.23/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
Reading the Handbook and it's fine , might effect max oc but likely not.
My psu has cables for both but it works with just the 8pin.
841 (0.16/day)
Mouse Logitech G703
That second note is kinda vague, easy to interpret as needing the 8 and 4, and as I'd never had a mobo with the second plug I wanted to ask first. I never actually saw the diagram on 2-7. I was focused on chapter 1 lol.
