8800GTS problems.
1,073 (0.16/day)
System Name My Current Desktop
Processor i9 12900KF
Motherboard Asus ROG STRIX Z690-E GAMING WIFI
Cooling ARCTIC Liquid Freezer II 360
Memory G.Skill Trident Z5 RGB Series 32GB (2 x 16GB) DDR5 6400 F5-6400J3239G16GA2-TZ5RS
Video Card(s) RTX 3090 FE
Storage SAMSUNG 980 PRO SSD 1TB
Display(s) Samsung G80SD
Case Fractal Design Torrent White
Audio Device(s) Schiit Bifrost2
Power Supply Corsair HX850
Mouse Razer Basilisk v3 pro
Keyboard Keychron Q6 Max (brown)
Software Win 11 Pro
I just hooked up my new massive eVGA 8800GTS KO ACS3 and although the problems seem minimal at best but definately noticable. Whats happens is, in battlefield 2142 the meshes seems to gets randomly stretched and when its done loading a map the screen turns bright yellow before going to the character selection screen. Also the Anti-aliasing wont go up to 8X it says it has to "optimize the shaders" but even after i load a map and it optimizes the shaders then close the map and try to up the setting it wont work still with the same message.
In Rainbow six vegas it wont load the game at all. And F.E.A.R Extraction point gets 153FPS with all settings maxed out in video test but when i actually play the game it works then randomly goes to like 1FPS
Im using the latest drivers and patches.
and suggestions?
2,648 (0.41/day)
UK
System Name Ma Biatch
Processor i7 860
Motherboard Gigabyte GA-P55-UD3A
Cooling Noctua
Memory 8gb (4x2gb) G-Skill
Video Card(s) GTX 470
Storage WD5000aaks raid0
Display(s) Sony Bravia 37" 1080p
Case CM 690
Power Supply Corsair HX520
Software Windows 7 Ultimate
tbh the drivers for the 8800 series are beta anyway imo there full of bugs from what ive seen and heard, dont know wether there would be any modded ones out for the 8*** series either yet, only suggestion would be to maybe try reinstall them (also check for updates) makin sure you remove all traces of the ones your using beforehand, also listing your specs might be helpful as it will allow people to see what hardware ur running (never know could be an incompatibility problem somewhere ? ) just a couple of thoughts. ;)
1,073 (0.16/day)
Software Win 11 Pro
mobo: eVGA 680i
Proc: Core 2 E6600 @ 3.6GHz
Video card: eVGA 8800GTS KO ACS3 580 core 1700 mem
Sound card: X-FI Xtreme music
HDD: Seagate 320GB 3GB/ps 16MB cache NCQ perpendicular recording
Ram: 1GB Kingston hyperx DDR2 800 (only temporary) soon to be 2x1GB OCZ titanium DDR2 800
Current 3D Mark score: 10018
Scavar
573 (0.09/day)
Ft Lauderdale, FL
System Name ScarredWolf(Desktop), MBlackWolf(Laptop)
Processor E6600(Desktop), T7300(Laptop)
Motherboard EVGA 680i(Desktop), IFL90(Laptop)
Cooling Akasa EVO 120(Desktop), No idea(Laptop)
Memory G Skill PI 8GB 4x2gb(Desktop), G Skill 3GB 1GB/2GB(Laptop)
Video Card(s) 8800GTS 640mb(Desktop), 8600m GT(Laptop)
Storage 3x250GB 1x500GB(Desktop), 1x320GB(Laptop)
Display(s) Acer AL2216W 22"(Desktop), 15.4"(Laptop)
Case Cosmos 1000(Desktop), PowerPro J 10:15(Laptop)
Audio Device(s) CreativeX-Fi/Z-5500(Desktop), Realtek/No idea(Laptop)
Power Supply PC Power and Cooling Silencer 610w(Desptop), *shrug*(Laptop)
Software Windows Vista Ultimatex64 with tweaks(Both)
Benchmark Scores I'm too lazy to benchmark anything.
Seems pretty strange to me. I have a standard 8800GTS, the only problem I get is the BSOD nv4_disp.dll thing, which in my case I think is linked to heat on other parts of the video card.
I would suggest completely removing the drivers using Driver Cleaner, and install the ones that came with the card first. If the problem continues, remove again, try the newest drivers. If it still happens, underclock the card and try the same steps. In the end, talk to EVGA and see what they tell you.
1,073 (0.16/day)
Software Win 11 Pro
i just got STOP 0x000000EA THREAD_STUCK_IN_DEVICE_DRIVER (Q293078) for the nv_disp.dll when trying to load rainbow six vegas
1,073 (0.16/day)
Software Win 11 Pro
heres some screen shots from 2142
  • Screenshots.zip
HellasVagabond
3,376 (0.52/day)
Athens , GREECE
System Name SECONDARY RIG / PRIMARY RIG / THIRD RIG
Processor i920@3.6GHz / i920@4GHz / AMD Phenom II 955
Motherboard Gigabyte EX58-UD4P / Gigabyte EX58-UD7 / ASRock 890GX3
Cooling CoolIT Domino ALC / Thermalright Silver Arrow / Thermalright VenomousX
Memory 12GB DDR3 @ 1800MHZ / 6GB DDR3 @ 2250MHZ / 4GB DDR3 @ 1600MHZ
Video Card(s) XFX ATI RADEON 5970 / GAINWARD NVIDIA GTX 580 / 2xGEFORCE GTX295
Storage 1550GB / 6TB SAS - SSD / 160GB SSD
Display(s) NEC 26WUXi2 / NEC 3090WQXi / SONY 55A2000 (1080P 55inch)
Case COOLER MASTER HAF 932 / COOLER MASTER ATCS 840 / ANTEC DARKFLEET DF85
Audio Device(s) Soundblaster X-Fi Xtreme Music / SoundBlaster X-Fi Fatal1ty Pro / Realtek Onboard
Power Supply CWT 1200W / Enermax Revolution 85+ 1250W / Ikonik Vulcan 1200W
Software Windows 7 x64 / Windows 7 x64 / Windows 7 x64
Did you OC the card ???
If so try to lower it...If that doesnt work lower your CPU OC....Sometimes a CPU OC can cause that.
zOaib
977 (0.14/day)
FL
System Name BabaJinn's U.F.O
Processor Intel Core i7 975 Extreme @ 3.8 ghz (for now)
Motherboard Asus Rampage Xtreme II X58
Cooling ZALMAN 9900 CPU COOLER Led
Memory 12GB Crucial Ballistix Tracers (Blue Led) 1600 DDR3
Video Card(s) MSI NVIDIA GTX 480 1.5 GB DDR5 384-BIT
Storage 2 x WD Velociraptor 10k rpm 300GB sata + 2x 500GB WD Caviar Sata + 320 GB Seagate Barracuda Sata
Display(s) DELL U2711 27inch Goodness @ 2560 x 1440
Case Mountain-Mods U2-UFO Custom Case (Made in USA)
Audio Device(s) Supreme FX X-Fi MB (Creative)
Power Supply ZALMAN 1000W PSU MODULAR
Software Windows 7 Ultimate 64-bit (Retail Version)
mobo: eVGA 680i
try using the drivers that came with your card , i was having somewhat same problem , weird stuff happening ingames bf2142 and unreal 2004 ............... i cleaned my sys of the latest drivers and installed the ones with the card , and been working sweet ever since ............. my score on 3d 05 was 14144 @ stock and i also have a similar setup as u .
1,073 (0.16/day)
Software Win 11 Pro
mine was 10018 due to single channel ram though, will be getting dual channel kit soon.
also might be due to the shitty drivers. i clean em out and run the disc that came with it.
OH also NFS Carbon wont install at all, it says "Must have DirectX 0 or greater to install"
and thats after installing the directx thats on the disc.
:banghead:
im running latest 3DMark '06 BTW
SlipSlice
770 (0.11/day)
Indiana
Processor AMD ATHLON 64 SAN DIEGO 3700@2.42GHZ
Motherboard ASUS A8N5X
Cooling 1X80MM CASE FAN, 1X80MM CPU FAN, 2X120MM FANS(ONE TAKING AIR OUT..OTHER FOR HARDDRIVE
Memory 1.5 GIG, DDR400 CORSAIR
Video Card(s) eVGA 7900GS KO
Storage 160GIG WESTERN DIGITAL 7200RPM
Display(s) Acer 22' Widescreen
Case ROSEWILL CASE 5600 SERIES..2 BLUE LED CASE FANS
Audio Device(s) SOUND BLASTER LIVE 24 BIT!
Power Supply SPARKLE 400 WATT
Software WINDOWS XP HOME EDITION..its gr8/LOTS OF GAMES
Drivers.. "cough" "cough ". IMO I think it is the drivers that would be making your graphics card show textures like that out of nowhere. I would try just installing the drivers that came on the disk..They can't be that outdated considering that the 8800's just came out not to long ago.. Other than that, post your temps.. It might be getting to hot.
S1iP.
P.S. Use drivers cleaner pro to delete drivers before you reinstall..just to reasure that it isn't your drivers the next time somebody tells you to reinstall your drivers.:)
1,073 (0.16/day)
Software Win 11 Pro
GPU temp tops out at like 65 celcius and cpu gets up to 43
SlipSlice
770 (0.11/day)
Indiana
Hmm..well that is getting kind of hot for full load, but I don't think that would be your reason for those textures..It could be though never know.. what I do know is that a new cooler, or turning the fan speed up on your graphics card wouldn't hurt, should I say. Never know that might fix it.
Have you tried the new drivers yet? Remembering to run D.C.P first.
S1iP
1,073 (0.16/day)
Software Win 11 Pro
65 degrees ain't bad compared to ATI's 1950 card they get to 90+ :p
also could be worse if i didn't get the ACS3 edition.
yea i removed old drivers completely and installed ones off cd, 2142 problems are still evident. oh well guess nVidia will just have to step up and address these problems. until then guess no 2142 for me... :banghead:
Scavar
573 (0.09/day)
Ft Lauderdale, FL
Those tempertures are fine for what you are running, so even if other parts of the GPU are hot, they can't be that hot. Its not temps at all. If you haven't already uninstalled and reinstalled drivers, do that. It should help something......err I just noticed that you said you did. I suppose you could turn up the fan speed....but I don't know...its just weird...
1,073 (0.16/day)
Software Win 11 Pro
i tried turning down CPU and GPU OC to stock, same issues, at this point im certain its driver related. :cry:
Scavar
573 (0.09/day)
Ft Lauderdale, FL
This is really weird....I started testing things on my own, I was trying stuff out and well with my E6600 OCd to 3.4, even with the heat being fine, I get the BSOD...strangly enough with my CPU OCd my GTS gets hotter then it should at stock....So I went into my BIOS and lowered all of my Voltages to stock, and un OCd my CPU....I then had to go back in and rasie my memory voltage....but after that the BSOD hasnt come back...and the GTS seems to be cooler...could one of the voltages be making the GTS hotter somehow or something?
(I tested both BF2 and BF2142, they BSOD with ease. Other games would take longer. Ive never had one outside of a game, and some games have yet to give it to me.. With voltages stock no BSOD in anything its weird as hell, I still think its more driver related then heat though....)
zOaib
977 (0.14/day)
FL
DRIVERS , trust me on this ............... 65c on load is perfect temp for the gts , although mine never goes above 59c on load since i put a 120mm fan right under my card ................. runs much smoother , http://www.techpowerup.com/gallery/558 <---- is the thread where u can see the installation of the 120mm fan under my gts ................... it also blow the hot air upwards where it is blown out the back fo the case works pretty well keeps my system temps down to 27c max .......................
anyways try to do a driver clean first , then install the drivers from the cd u got with the card , and good luck. ( because if that dotn fix things , just RMA , if u still have time ).
1,073 (0.16/day)
Software Win 11 Pro
nvidia's drivers are shit right now, they just need to release new ones!
Scavar
573 (0.09/day)
Ft Lauderdale, FL
After more testing....I guess for stock voltage 3.4GHz on my processor doesn't go so well, so that was my BSOD problem. I have my GTS OC'd to 600/900 at the moment. Im using the omega drivers though.
AshenSugar
1,998 (0.30/day)
ashentech.com
Processor Athlon64 3500+(2.2gz)@2.94gz(3.03gz)
Motherboard Biostar Tforce550 (RMA) (m2n-sli delux)
Cooling PIB cooler
Memory 2gb ocz 533 +1gb samsung 533 4-4-4-12
Video Card(s) x1900xtx 512mb+zalman vf900 cooler(kicks stock coolers arse)
Storage 80gb,200gb,250gb,160gb
Display(s) 20.1 in dell 2001fp + KDS visual sensations 19"
Case Codegen briza seirse
Audio Device(s) ADI SoundMax HD audio onboard,using Ket's driver pack
Power Supply FSP 400watt SAGA seirse w/noise killer
Software Windows 2003 ent server as workstation(kills xp in perf and stab)
aint you glad you jumped on that 8800 card when you did, i mean its the best....ROFL
now u just need to get windows vista and your system will be prefect, perfectly shit!!!!
and mab1276 why dont you just set your system specs like verybody else insted of as ur sig?
Scavar
573 (0.09/day)
Ft Lauderdale, FL
Ashen I think that kind of response is out of the line. We aren't here to discuss the 8800GTS, but to try and resolve his problem, which everyone now agrees is driver. THe 8800GTS is not shit though. As benchmarks everywhere show otherwise, even if it isn't DX10 capable, or is forced to emulate like the FX series, which I highly doubt nVidia was foolish enough to repeat. I think it has more to do with working with new driver interface.
You do have a point though, mab you should put your specs in the User CP and not in your sig unless its for another computer.
1,073 (0.16/day)
Software Win 11 Pro
I didnt think they released omega drivers for the 8800, you have a link?
I got my GTS up to 626MHz and 1000MHz ram, increased my 3Dmark score 800 points from the stock ACS3 settings of 580MHz core and 850MHz ram.
Scavar
573 (0.09/day)
Ft Lauderdale, FL
Wow this is really freaking me out....I know I downloaded drivers from the Omega site, and thats what im using right now......but I can't seem to find them again....It's really freaking me out....Heres some other drivers I tried though....
http://downloads.guru3d.com/download.php?det=1547
http://www.ngohq.com/home.php?page=nvidia
I personally don't like teh NGO driver, and since I can't find the Omega one that I swear I have installed....unless it was some kind of whacked crazy dream......use teh Guru3d one.
1,073 (0.16/day)
Software Win 11 Pro
the guru 3d version is just a re-pack with no modifications made to it.
"Guru of 3D repackaged the driver from 65 MB towards a far better 36 MB. The archive has been virus and pest-checked and it came out clean. This is a beta driver so please treat and respect it as such. "
the NGO version is actually modified so im gunna give that one a try.
Since the Guru of 3D website states thats the 8800 driver is a beta driver. That answers alot of my questions as to why there is so many issues with my games.
Scavar
573 (0.09/day)
Ft Lauderdale, FL
I don't know then whats going on. I still can't find them..but from looking at someone who compared the NGO with the stock Nvidia drivers in IQ, my games match the NGO driver, eevn though i know i dont have that one installed as I tried it first. And I dont think anything it did could survive Driver Cleaner Pro....so I really just don't know. If I figure out what the hell driver I installed before new ones come out, ill let you know.
