8pin cpu connector -cracked plastic on a pin
571 (1.21/day)
a psu thats a backup. I noticed the plastic flaking off the edge. picked at it and as you see pin is exposed. its a 2x4pin cpu connector
I was thinking of getting an extension 8pin cable and soldering all wired in.
this is the 2nd antec psu ive had issues with. looks like no more antec for me
2,957 (2.07/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~2000 Video Games
there is even wire exposed... that looks cheaper and worse than these 30 dollar 850W marsgaming PSUs.
571 (1.21/day)
as im looking closer I can see 2 wires that were supposed to be colored yellow have turned to brown and are crispy-ish/stiff. it did work though.
those 2x4 pins are awkward to use. could be I didnt insert them together inside properly and thus a bad connection? the last pc that used it had no issues. could be it had overheated but didnt fail?
2nd antec that has had issues and now on my never buy brand. corsair is on that too.
im thinking maybe ill just get an 8pin to 2 molex adapter cable instead.
2,957 (2.07/day)
Germany
i would send this PSU directly to antec and demand an answer about the absolute trash that they are selling.
3,115 (2.34/day)
Processor Ryzen 5 5700x
Motherboard B550 Elite
Power Supply MSI 750w
Mouse G502
is it worth the risk to burn down the house or take some components with it?
was it you that exposed the wire?
571 (1.21/day)
no, I saw it immediately on the picture when posting here. then looked at the wire/connector and saw it.
if you look on amazon "psu tester" there is 50 sellers selling the same tester. it is absolute garbage. worthless. it said a corsair psu was good when it wasnt.
so not sure how I can test if its good. but dual molex to 8 pin will be fine.....
BOOM!!!! get the fire extinguisher!!!!! :laugh:
2,584 (6.38/day)
System Name The Workhorse
Processor AMD Ryzen R9 5900X
Storage Adata SX8200Pro
Display(s) LG 32GK850G
Software Windows 11 Pro (24H2)
I wouldn’t risk it unless you really like to live dangerously.
Then again, what can possibly go wrong?
2,583 (0.38/day)
People's Republic of America
Processor i9-14900K Direct Die
Motherboard MSI Z790 ACE MAX
Cooling 4X D5T Vario, 2X HK Res, 3X Nemesis GTR560, NF-A14-iPPC3000PWM, NF-A14-iPPC2000PWM, IceMan DD
Memory TEAMGROUP FFXD548G8000HC38EDC01
Video Card(s) MSI 4070 Ti Super w/Alphacool Eisblock Aurora RTX 4070TI Ventus with Backplate :13724
Storage Samsung 990 PRO 1TB M.2
Display(s) LG 32GK650F
Case Custom open frame chassis
Mouse Logitech MX700
Keyboard Logitech LX700
Software Win11PRO
Or, you could buy the connector, terminals, and a crimp tool and replace them.
Ruru
S.T.A.R.S.
13,122 (2.98/day)
Jyväskylä, Finland
Processor AMD Ryzen 7 5800X / Intel Core i7-6700K
Motherboard Asus ROG Crosshair VII Hero / Asus Z170-K
VR HMD Oculus Rift CV1
Life is boring without some excitement :rolleyes:
....yeah, I wouldn't use that myself.
3,115 (2.34/day)
Mouse G502
the plastic seems shit quality, exposed wires, i can only imagine the rest, i would just e-waste that thing.
571 (1.21/day)
I still want to use my 8320fx pc. so will get a used mb, then use the psu there, the mb only needs a 4pin connector. the other 4 pin connector on psu looks mint so will be fine. ill make sure to only power it when im home so it doesnt blow up hahaha
3,115 (2.34/day)
Mouse G502
not sure that's how bombs work, at least buy a fire extinguisher :D
571 (1.21/day)
Check to make sure the contacts in the unused connector are in good condition and not loose.The other connector probably overheated because the contacts were not a tight fit.
yes I think thats what happened. those connectors like 2+6 pcie connectors are a pita to get in and this 4+4 isnt different and in the corner when you dont have proper reach.
42,914 (6.71/day)
Ok replace the psu and move forward.
If I had a crack in a psu connector and no signs of melting or smoked wires I would replace the cable or the connector shell itself
