9800X3D OC Limits?
ir_cow
4,736 (0.79/day)
USA
Call me lazy but can anyone give me the quick and dirty details of max Core / SoC voltage, clocks and temperature since these 9000 X3Ds are now overclockable.
Thanks.
dgianstefani
TPU Proofreader
5,260 (2.02/day)
Swansea, Wales
Benchmark Scores Legendary
I'm doing 5.575 GHz on 1.24 V. Temps are fine under 60.
10,984 (1.74/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Memory 64GB DDR5 6000 1:1 CL30-36-36-96 FCLK 2000
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply RIP Corsair SF750... Waiting for SF1000
Keyboard 65% HE Keyboard
I can run at 5.6 ghz at 1.26v - aircooled so temps get spicy @90C... 5.45 with PBO offset is much cooler.
My chip is actually unstable at 6000 1:1 - it will hard lock in POE2, but is rock stable at 2200 FCLK 6600 with 1:2 ram divider o_O
ir_cow
4,736 (0.79/day)
USA
I assume nothing is different with the SoC?
That would be cool if I was able to do 6600 1:1.
10,984 (1.74/day)
Austin Texas
Case Jonsbo Z20
Audio Device(s) Yes
SOC 1.21v @ 2000 FCLK / 6000 1:1, 1.29v @2133FCLK and 6400 1:1, 1.29v @2200FCLK / 6600 1:2 - no post at 2266 FCLK / 6800
ir_cow
4,736 (0.79/day)
USA
I am mostly looking for core voltage so I dont kill the CPU lol.
Seems like SoC and IMC are the same as the none-x3d
freeagent
9,717 (4.15/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
For me I find the max the socket will allow the CPU to have with PBO enabled, that means running heavy shit. When you figure out how much power you can use, set your curve to that with boost override maxed. Then do it again to see if it uses moar power, then set your limit to that and do it again.
Different people will give you different ways to test for stability, but this setup has been stable for like 4 years running like this.
ir_cow
4,736 (0.79/day)
USA
@freeagent I'm just going to set a fix frequency and voltage for the test bench. No PBO for me :)
Anyways thanks everyone for the replies. I'll stick with 1.25v for now
freeagent
9,717 (4.15/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
Well.. in that case.. I would go until it reboots pretty much..
Edit:
Just like old Intel..
Solaris17
Super Dainty Moderator
27,249 (3.83/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
Mind following up with settings and process? Im in it for curiosities sake.
Or anyone else for that matter. Looks like max out is around 5.6.
