9800X3D Waterblock Question
611 (0.10/day)
DFW, Texas, USA
System Name Built By Me
Processor Intel Core i9 9900K @ 5.1 GHz
Motherboard Gigabyte Z390 Aorus Ultra
Cooling Custom Water Cooling - CPU Only
Memory 32GB (2 x 16) GSkill Ripjaws V DDR4
Video Card(s) RTX 4080 - ASUS ROG Strix 16GB OC - P Mode
Storage 1TB Samsung 970 Evo NVMe
Display(s) Alienware AW2723DF @ 280 Hz @ 1440P
Case Fractal Design Define S2
Audio Device(s) Corsair Virtuoso Pro
Power Supply 850W Seasonic Platinum
Mouse Razer Viper V2 Pro @ 2k Hz
Keyboard Asus ROG Strix Scope II 96 Wireless - ROG NX Snow Switches
I have been using Intel for many years and have recently purchased a 9800X3D to use. I have been out of the AMD loop for many years.
I purchased a Heatkiller IV Pro waterblock. I am planning on using it with the CPU on an Aorus X870 Elite mobo. I am planning on using the stock IHS, no de-lidding or die-contact going on.
Do I also need the Thermal Grizzle AM5 Adapter & Offset Mounting Kit: https://www.thermal-grizzly.com/en/adapter-offset-mounting-kit/s-tg-mk
The Thermal Grizzly AM5 Contact Sealing Frame: https://www.thermal-grizzly.com/en/contact-sealing-frame/s-tg-csf
598 (0.12/day)
St. Louis, MO
System Name Desktop
Processor AMD Ryzen 7800X3D
Motherboard MSI X670E MEG ACE
Cooling Corsair XC7 Block / Corsair XG7 Block EK 360PE Radiator EK 120XE Radiator 8x EK Vadar Furious Fans
Memory 64GB TeamGroup T-Create Expert DDR5-6000
Video Card(s) MSI RTX 4090 Gaming X Trio
Storage 1TB WD Black SN850 / 4TB Inland Premium / 8TB WD Black HDD
Display(s) Alienware AW3821DW / ASUS TUF VG279QM
Case Lian-Li Dynamic 011 XL ROG
Audio Device(s) Razer Nommo Pro Speakers / Audio-Technica ATH-R70X
Power Supply EVGA P2 1200W Platinum
Mouse Razer Viper, Logitech G600
Keyboard Razer Huntsman Elite
I can't speak to the offset mounting. I know AM4 had some benefits from using an offset.
I have a 7800X3D and am using a Corsair block. I have had zero issues.
Amazon.com: Thermalright ASF-Black AM5 CPU Holder, Corrective Anti-Bending Fixing Frame, AM5 Full-fit Fixed Non-Marking Mounter, AM5 Anti-Bending Contact Frame, CPU Cooler Standard : Thermalright: Electronics
Thermalright makes contact frames as well. They are usually half the price and do the same thing. I have used them for AM5 and LGA1700.
3,379 (1.09/day)
Cooling Noctua NH-D15 Chromax
Memory 32GB DDR5 6000 CL30
Case Thermaltake Core X9
Mouse PMM P-305
Keyboard Wooting HE60
VR HMD Valve Index
Software Win 10
The contact frame is entirely unnecessary on AMD. There is no ILM pressure issue on AMD like there is on Intel.
In regards to offset mounting, it is not required but may help performance. I have seem some people getting good results from it but I've also seem some people report compatibility issues as well.
3,370 (1.70/day)
Power Supply Corsair RM750x
Mouse Logitech M575
Offset mounting with AM5 socket can be problematic from 2 issues.
1) the AMD socket getting in the way preventing the full 7mm offset
2) the first NVMe heatsink getting in the way
See here https://www.techpowerup.com/forums/threads/thoughts-for-a-new-am5-waterblock.326811/post-5340394
I got lucky on #2 with my water block and was able to continue using the motherboard heatsink.
Depending on your motherboard, heatsink, and water block, you may have to make adjustments to make the offset work.
Note some AM5 water blocks might already include offset in the cold plate so research that.
Your challenges if any will depend on your motherboard. Overall the offset mounting is better but not required.
Looking at your motherboard choice it looks like you will be limited in the same way I am because that socket tab prevents the offset from rotating completely downward using the Thermal Grizzly offset mounting kit.
If you decide to air cool using Noctua instead, their offset kit will be fine.
598 (0.12/day)
St. Louis, MO
System Name Desktop
I prefer the contact frame just from the standpoint it keeps the thermal paste from getting all over the CPU SMDs and under the IHS.
611 (0.10/day)
DFW, Texas, USA
Thanks for all of the responses!
I think I will just run the waterblock as is, no contact frame, and no alignment kit.
I have reached that age :laugh: where if it runs, and it is cool enough during gaming, there is no reason for me to try and chase a couple more C's cooler.
I am lucky enough to live in a city that has a Microcenter, and one of the staff members talked me into buying the TG PhaseSheet PTM to use as my TIM between the CPU IHS and the waterblock. I will see how that works out.
3,370 (1.70/day)
Mouse Logitech M575
Post some build pictures if you can. I'd like to see how well that water block fits. Good luck.
9,455 (3.41/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
The Thermalright Kit works fine too and is the cheapest.
7,151 (4.86/day)
São Paulo, Brazil
Display(s) 55-inch LG G3 OLED
Audio Device(s) Apple USB-C + Sony MDR-V7 headphones
Software Windows 10 Pro 22H2
The frame is a nice thing to have but it's not absolutely mandatory. I like how it works and would spend the couple of bucks for it, since you're already going custom, it wouldn't hurt.
It's all covered well in the thread, I wish you luck and a lot of enjoyment from your new machine. Awaiting build pics :toast:
611 (0.10/day)
DFW, Texas, USA
Will do. I just received the waterblock today, which should be the last thing that I need to get this thing up and running.
