990 Evo reporting 90C+ temps
390 (0.08/day)
Processor AMD Ryzen 9 5900X
Motherboard Gigabyte B550 Aorus Pro
Cooling Wraith Prism
Memory Crucial Ballistix 3600Mhz 16GB (4x8GB)
Video Card(s) -
Storage Samsung 850 Evo, 860 Evo, 980 and Crucial MX500
Display(s) Samsung Neo G9 Odyssey
Case Corsair 7000D
Power Supply -
VR HMD Quest 2
In Samsung Magician, the first drive temp is reported as the SSD temp, however in hwinfo it shows 3 readings the third being the nvme controller.
Any idea why it is so high? Im using a B650E PG Riptide motherboard and the SSD even has a heatsink over it (both DRAM are touching the heatsink).
2,624 (0.38/day)
People's Republic of America
Processor i9-14900K Direct Die
Motherboard MSI Z790 ACE MAX
Cooling 4X D5T Vario, 2X HK Res, 3X Nemesis GTR560, NF-A14-iPPC3000PWM, NF-A14-iPPC2000PWM, IceMan DD
Memory TEAMGROUP FFXD548G8000HC38EDC01
Video Card(s) MSI 4070 Ti Super w/Alphacool Eisblock Aurora RTX 4070TI Ventus with Backplate :13724
Storage Samsung 990 PRO 1TB M.2
Display(s) MSI 321URX
Case Custom open frame chassis
Mouse Logitech MX700
Keyboard Logitech LX700
Software Win11PRO
Appears quite warm.
I was looking at my 990 Pro nvme drive temps in HWiNFO:
This drive is under the Frozr heatshield on the motherboard as well.
260 (0.22/day)
The controller chip and the RAM chip(s) are sometimes at slightly different heights. The controller chip is in far greater need of good cooling than the RAM. I've seen reports saying M.2 RAM benefits from being run quite warm (mid fifties/sixties Celcius). At 98C, you've hit the controller's throttle point.
It's difficult to see under the label (which might be made of Copper foil to act as a heatsink) but I think the controller chip which needs the most cooling is on the far right hand side, next to the gold-plated contacts. Don't worry too much about the RAM. Also, it's not recommended to remove the manufacturer's label. They might not honour an RMA if it's obviously been "tampered" with.
FreedomEclipse
~Technological Technocrat~
24,718 (3.77/day)
(Temporarily) London, UK
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
Problem is your controller probably isnt making good contact with the heatsink. I had this issue with one of my SN770s on my current MSI board.
Its that garbage heasink mounting system that they use that doesnt take into account that not all SSDs are the same height. NAND chips often sit a a bit higher than the controller chip. If you have a spare 1 or 2mm thermal pad. cut it to size and place it on the controller before screwing it down. Keep the stock pad on there. It will all crush down and still drop the temps by 20-30'c
If thermal pads are too expensive. Consider getting one of the 3rd party chinesium heatsinks off amazon that can be bought for around $6. Those come with thermal pads and will cool a lot better than the heasink that comes with the MB.
::EDIT::
If I have to put it into context....
This part here (in the red box) is sitting a little too high and that stops the heatsink from crushing the thermal pad down onto the controller.
::EDIT II::
If you want even more context of the context. May I refer you to my before and after results - Arctic pads are pretty good but the MB heatsinks themselves arent super awesome due to the lack of surface area for really good cooling. Still more than happy with the results and I used TP-3 pads on ALL the SSDs so its definitely worth buying a pack or two. Even if you dont use all of them. You could use them on other stuff like GPUs or VRMs on older MBs.
13,883 (2.03/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
Look at your case cooling too. Make sure you have a good "flow" of air through the case and across the drive. Ensure good, tidy cable management to minimizing impacting that flow. And make sure the interior is clean of heat trapping dust.
352 (0.06/day)
India
System Name Home
Processor Ryzen 5700X3D
Cooling Bykski Ryzen Waterblock + BlackIce Pro 360 radiator + 120mm + D5 variable pump + Corsair HD120 x 4
Memory 32 GB GSKILL ARES @ 3800Mhz 15-15-15
Video Card(s) ASUS Strix 1080Ti with Bykski Waterblock
Storage 2x 970 EVO Plus 1tb + 960GB Sandisk Extreme Pro SSD + 4TB WD Black
Display(s) Samsung 40KU6300 UHD TV
Case CoolerMaster HAF-X
Audio Device(s) Logitech Z906
Power Supply Corsair RM850
Mouse Logitech G602 + Razer Goliathus Speed mouse pad
Keyboard Razer BlackWidow Chroma RGB
VR HMD Oculus Rift CV1
Do you get any hardware errors in event log? I had similar issue with my system. Turned out it was the faulty PSU. My system used to hang randomly though, unlike yours.
2,624 (0.38/day)
Software Win11PRO
3,947 (1.93/day)
Thessaloniki, Greece
System Name PC on since March 2025, upgraded from 5900X
Processor Ryzen 7 9700X (March 2025), 150W PPT limit, 85C temp limit, CO -30, +100MHz (up to 5.65GHz)
Motherboard Asrock X870E NOVA, BIOS v3.2, AGESA PI 1.2.0.3a Patch A
Cooling Arctic Liquid Freezer II 420mm Rev7 (Jan 2024) with off-center mount for Ryzen, TIM: Kryosheet
Memory 2x32GB G.Skill Trident Z5 RGB (March2025) 6000MT/s 1.35V CL30-36-36-36-28-64 1T, tRFC:500, Hynix A-D
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (382W current) PowerLimit, 1060mV, Adrenalin v25.3.1
Storage NVMe: 990Pro 2TB(OS 25), 980Pro 1TB(22), 970Pro 512(19) / S-III: 850Pro 1TB(15) 860Evo 1TB(20)
Case Thermaltake Core P8 TG Gaming Full Tower
Software Windows 11 Home 64bit (v24H2, OSBuild 26100.3476), Install March 2025
I looks to me that Temps 1+3 is the same sensor of storage chips and temp 2 is the controller which is always warmer than the rest drive.
See both NVMe drives below (980Pro + 970Pro)
980 is OS drive next to CPU socket and 970 is buried under the 3.5 slot GPU
edit:
typo
631 (0.55/day)
Processor AMD Ryzen 7 5800X3D
Cooling Custom Watercooling
Display(s) Samsung G7 27" x2
Mouse Logitech G903
Keyboard Steelseries Apex Pro
That high temp is a strong indication that the heatsink is not properly seated. To thin a thermal pad. Or for some reason there is a heat trap at that spot. If you carefully remove the heatsink there should be an impression in the thermal pad of every chip it is properly seated on.
Unless the sticker is marked warranty void if removed, you can remove it. I have not seen any marked that way in the last few years either. So seems the manufacturers have realised people have to remove them to properly fit a heatsink in many cases.
A bendy sticker like in that picture is also very unlikely to have any worthwhile heat spreading characteristics. I would 100% remove it to mount a heatsink. If you want to keep the sticker put it on the backside of the ssd for easy access to S/N and stuff.
