A D3D11-compatible GPU (Feature Level 11.0, Shader Model 5.0) is required to run the engine.
Togepi
1 (1.00/day)
Hello!
Im having some trouble here, and i don´t know if someone can help me. This warning "A D3D11-compatible GPU (Feature Level 11.0, Shader Model 5.0) is required to run the engine." Is appearing to me when i try to play the game "Path of Titans". I already tried to update all my drivers, update direct x, update vc c++, and a bunch of other stuff that i saw online. I don´t think its my machine, here is my configs: AMD Ryzen 7 5700x 8core 16CPUs. NVIDIA GeForce RTX 4060ti. Anyone had this trouble before? I can play Avatar Frontiers of Pandora, Planet Zoo, Red Dead 2, and heavier games than Path of Titans. Thanks for reading!
Solaris17
Super Dainty Moderator
26,560 (3.81/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
Display(s) Odyssey OLED G9 (G95SC)
Audio Device(s) Moondrop S8's on schitt Modi+ & Valhalla 2
Keyboard Monsgeek M3 Lavender, Akko Crystal Blues
VR HMD Quest 3
Does GPU-Z show all the fields? To me this reads like an Nvidia driver issue, or the engine itself. Other possibility I can think of off the top of my head would maybe be an iGPU that the game somehow detected before the discrete; but that isn’t an issue in your case. I’m just speaking out loud. Try DDU.
40 (1.33/day)
Michigan, United States
Processor Intel i7-13700K
Motherboard Asus ROG Strix Z690-E Gaming
Cooling NZXT Kraken Elite 360
Memory G.Skill Trident Z DDR5-6400
Video Card(s) MSI RTX 4090 Suprim X Liquid
Storage Western Digital SN850X 4Tb x 4
Case Corsair 5000D Airflow
Audio Device(s) Creative AE-5 Plus
Power Supply Corsair HX-1200
Software Windows 11 Pro 23H2
Should probably check with Alderon Games, if they have a discussion community for the game (I looked, and couldn't find one, but I don't own the game) -- there is a chance that someone else besides you has run into this issue before you, and someone might have suggested a fix. Or submit a support request directly.
Other than that, potentially check your C++ distributables to make sure they're up to date. You could also try and clean uninstall (DDU in Safe Mode) and reinstall of the GPU drivers, just to rule them out if nothing else.
5,986 (4.42/day)
São Paulo, Brazil
Motherboard ASUS ROG MAXIMUS Z790 APEX ENCORE
Display(s) 55-inch LG G3 OLED
Keyboard Galax Stealth STL-03
RTX 4060 Ti definitely supports that. I'd reinstall the drivers if I were you. If problem is not solved check device manager for an error code.
