A-DATA Releases Industry Fastest CF633X Memory Card
47,442 (7.50/day)
A-DATA Technology Co., Ltd., the worldwide leader in DRAM memory and Flash application products, released today its new compact Flash card CF633X, the ultimate memory card fast enough to keep up with your digital SLR cameras. Performing at the industry's fastest read/write speed up to 93/92 MB/s, the new A-DATA CF633X adopts the turboMLC technology and delivers the performance of SLC at the cost of MLC.
With an ECC automatic error-checking program in place, the CF633X consumes less power and extends the use of a DSLR. Capacity available in 16GB and 32GB, the CF633X is the perfect storage device for users to store more high resolution images and high definition video clips.
Lower power consumption and RoHS compliant, the CF633X extends the average lifespan of a CF card by utilizing interleaves technology. With which, bad blocks in the flash are pre-labeled and closed for data entry to prevent data-loss.
UDMA 6 enabled, the new A-DATA CF633X supports quad channel and performs up to 93 MB/s in read and 92MB/s in write. Backed by rigorous stress-testing procedures and a product life time warranty, this is indeed a perfect match for your advanced DSLR.
Mussels
Freshwater Moderator
58,413 (7.87/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
CF to IDE adaptors are sounding pretty good right now...
2,261 (0.38/day)
System Name Budget AMD System
Processor Threadripper 1900X @ 4.1Ghz (100x41 @ 1.3250V)
Motherboard Gigabyte X399 Aorus Gaming 7
Cooling EKWB X399 Monoblock
Memory 4x8GB GSkill TridentZ RGB 14-14-14-32 CR1 @ 3266
Video Card(s) XFX Radeon RX Vega₆⁴ Liquid @ 1,800Mhz Core, 1025Mhz HBM2
Storage 1x ADATA SX8200 NVMe, 1x Segate 2.5" FireCuda 2TB SATA, 1x 500GB HGST SATA
Display(s) Vizio 22" 1080p 60hz TV (Samsung Panel)
Case Corsair 570X
Power Supply Seasonic X Series 850W KM3
Why yes they are....
1,193 (0.18/day)
Bellevue, WA
System Name 0BL1V10N
Processor Intel Core i7 11700K @ 5.1GHz all-core turbo
Motherboard ASRock Z590 Taichi
Cooling Cooler Master MasterLiquid 360 (with stock CM fans), 12x Pccooler Moonlight Series ARGB 120mm fans
Memory (4x16GB) 64GB Mushkin Redline Lumina 3600MHz 16-19-19-39 XMP
Video Card(s) MSI RTX 4090 SUPRIM LIQUID 24G (not using stock fans) (+150MHz core, +1000MHz memory)
Storage Western Digital Black SN850X 2TB Gen4 NVMe
Display(s) 1x Alienware AW3821DW (3840x1600@144Hz), 2x Dell SE2717H (1080p@75Hz)
Case Phanteks Enthoo 719 Anthracite Grey
Audio Device(s) Schiit Modius + Drop THX AAA 789 + Custom Planar Magnetic Headphones
Power Supply Thermaltake Toughpower GF3 1200W (12VHPWR)
Mouse Logitech G502 X Plus
Keyboard Too many custom mechanical builds to list...
Software Windows 10 Pro 22H2
What about random r/w? It might be the bomb in sequential but terrible in random.
Mussels
58,413 (7.87/day)
Oystralia
1,193 (0.18/day)
Bellevue, WA
My only point was a 32GB 633x CF card isn't going to be very cost effective.
My 8GB 300x Lexar was not cheap and it isn't very old.
224 (0.04/day)
it needs USB3
you just need a desent USB 3 card reader, then you are laughing.
My worry is if the camera is going to get the most of the card, i would guess that it had its own bottlenecks inside the camera or the bus that writes to the card rather than the card itself.
