A slightly strange problem with a GPU
HMSharrow
1 (0.25/day)
Hi! Recently, while looking into the driver options for an RX 580 I installed in a test bench, it indicated that it was running at x8,i tried on GPU Z and it shows the same thing
This was disconcerting, as I hadn't noticed. I tried several things to correct it: changing the drivers, cleaning the PCIe port (which is x16), and testing the GPU on another bench, and it indicated that it was running at x16.
The CPU on the bench is an Asus m5a97 r1, with an fx6100. I know that the motherboard should run at PCIe gen 2. However, from what I've found, the mobo and the processor shouldn't be a problem for it to run at x16.
If anyone has any advice for this particular case, I'd appreciate it :)
(I apologize in advance if the writing is bad; this is the first time I've decided to post a question on a forum.)
80 (0.05/day)
Does the motherboard have anythong connected to other PCIe ports (including smaller x8/x4/x1)?
Also, sometimes the PCIe lanes are really damaged in motherboard/CPU leading to similar effect. The PCIe version is irrelevent here.
3,138 (6.47/day)
System Name The Workhorse
Processor AMD Ryzen R9 5900X
Storage Adata SX8200Pro
Display(s) LG 32GK850G
Software Windows 11 Pro (24H2)
See the question mark near the PCI-e reading? Click it, it will launch a light GPU load from within GPU-Z. Does it change anything? Does the version go to Gen 2, but the lanes stay at 8x?
8x is weird on the M5A97, if memory serves, the slot config on that is 16+4. So something obviously isn’t working correctly. Might be that the board itself is damaged, as stated above, yeah. In that case, there isn’t much to be done.
Ruru
S.T.A.R.S.
13,595 (3.03/day)
Jyväskylä, Finland
VR HMD Oculus Rift CV1
Could be a motherboard issue if reinstalling the card firmly doesn't bump the lanes to x16. There shouldn't be any performance hit, though I know that it's annoying if it doesn't run at its full potential, even if it doesn't affect in performance.
839 (1.87/day)
Seattle
System Name DevKit
Processor AMD Ryzen 5 3600 ↗4.0GHz
Motherboard Asus TUF Gaming X570-Plus WiFi
Cooling Koolance CPU-300-H06, Koolance GPU-180-L06, SC800 Pump
Memory 4x16GB Ballistix 3200MT/s ↗3800
Video Card(s) PowerColor RX 580 Red Devil 8GB ↗1380MHz ↘1105mV, PowerColor RX 7900 XT Hellhound 20GB
Storage 240GB Corsair MP510, 120GB KingDian S280
Display(s) Nixeus VUE-24 (1080p144)
Case Koolance PC2-601BLW + Koolance EHX1020CUV Radiator Kit
Audio Device(s) Oculus CV-1
Power Supply Antec Earthwatts EA-750 Semi-Modular
Mouse Easterntimes Tech X-08, Zelotes C-12
Keyboard Logitech 106-key, Romoral 15-Key Macro, Royal Kludge RK84
VR HMD Oculus CV-1
Software Windows 10 Pro Workstation, VMware Workstation 16 Pro, MS SQL Server 2016, Fan Control v120, Blender
Benchmark Scores Cinebench R15: 1590cb Cinebench R20: 3530cb (7.83x451cb) CPU-Z 17.01.64: 481.2/3896.8 VRMark: 8009
CPU isn't an issue but the board probably doesn't like it. That weird era of Asus M4A/M5A boards didn't exactly agree with a lot of hardware.
I remember abandoning mine for a Biostar TA970 just to get VR equipment to behave. There were also voltage control issues with my RX580.
Went to another board after that too. Jumping ship to Ryzen eventually revealed the nature of the problem but I was so lost just getting there.
154 (0.13/day)
Processor Intel i5 9400f
Motherboard MSI Z390 Gaming Plus
Cooling SilentiumPC Fera 3
Memory 2x 8GB Corsair Vengeance LPX 3200 16-18-18-36
Video Card(s) MSI GTX 1660 Super Ventus XS OC
Storage 500 GB Kingston A2000; 1 TB Kingston A2000; 1 TB HGST Travelstar
Display(s) AOC 24G2U
Case SilentiumPC Signum SG1
Audio Device(s) Creative Pebble Plus; Logitech G533
Power Supply beQuiet Systempower 9 500W
Mouse Logitech G403 Hero
Keyboard HyperX Alloy Origins (Red)
Do you have another card to test in this system to check if any card gets the full 16 lanes? Also maybe check for bent pins on the CPU.
609 (2.78/day)
Texas, USA
System Name Obliterator
Processor Ryzen 7 7700x PBO
Motherboard ASRock x670e Steel Legend
Cooling Noctua NH-D15 G2 LBC
Memory G.skill Trident Z5 Neo 6000@CL30
Video Card(s) ASRock rx7900 GRE Steel Legend
Storage 2 x 2TB Samsung 990 pro nmve ssd 2 X 4TB Samsung 870 evo sata ssd 1 X 18TB WD Gold sata hdd
Display(s) LG 27GN750-B
Case Fractal Torrent
Audio Device(s) Klipsch promedia heritage 2.1
Power Supply FSP Hydro TI 1000w
Mouse SteelSeries Prime+
Keyboard Lenovo SK-8825 (L)
Software Windows 10 Enterprise LTSC 21H2 / Windows 11 Enterprise LTSC 24H2 with multiple flavors of VM
Well, pci-e 2.0 16x and pci-e 3.0 8x are pretty much the same bandwidth-wise, so you aren't missing anything.
I fired up my fx rig (8370, 970x, rx590) and it reports as pci-e 3.0 16x right there......so idk.
It could be any number of things, but probably just some kind of issue with how the info is being reported to or collected by the software. it happens.
It's a 2048sp rx580, so it is entirely possible that it has had it's bios jacked with at some point in time.
If it is working to your satisfaction, i'd ignore it.
5,636 (1.02/day)
Gougeland (NZ)
System Name Cumquat 2021
+1 CLICK the ? mark next to the PCIe lane/speed box
when a GPU isn't doing much it will down clock the PCIe to 1.1 x8/x16 to save power under windows default power settings (which is usually set to Balanced)
