Processor | INTEL CORE I9-9900K @ 5Ghz all core 4.7Ghz Cache @1.305 volts |
Motherboard | ASUS PRIME Z390-P ATX |
Cooling | CORSAIR HYDRO H150I PRO RGB 360MM 6x120mm fans push pull |
Memory | CRUCIAL BALLISTIX 3000Mhz 4x8 32gb @ 4000Mhz |
Video Card(s) | EVGA GEFORECE RTX 2080 SUPER XC HYBRID GAMING |
Storage | ADATA XPG SX8200 Pro 1TB 3D NAND NVMe,Intel 660p 1TB m.2 ,1TB WD Blue 3D NAND,500GB WD Blue 3D NAND, |
Display(s) | 50" Sharp Roku TV 8ms responce time and Philips 75Hz 328E9QJAB 32" curved |
Case | BLACK LIAN LI O11 DYNAMIC XL FULL-TOWER GAMING CASE, |
Power Supply | 1600 Watt |
Software | Windows 10 |
select your OS and down load all the mobo drivers starting with the chipset first and reboot ...install the rest of your mobo drivers...reboot retest.Asrock a770de+
Amd athlon phenom 2 x6
8gb ddr2
Nvidia gforce gtx 650
Sound card on board
Sory, i am 12 years old and i am noob for this
Ty you very very much,yo are the best.select your OS and down load all the mobo drivers starting with the chipset first and reboot ...install the rest of your mobo drivers...reboot retest.
https://www.asrock.com/mb/AMD/A770DE+/index.asp#Download
this first>>> AMD all in 1 driver ver:8.631_W7_logoTy you very very much,yo are the best.
System Name | PCGOD |
Processor | AMD FX 8350@ 5.0GHz |
Motherboard | Asus TUF 990FX Sabertooth R2 2901 Bios |
Cooling | Scythe Ashura, 2×BitFenix 230mm Spectre Pro LED (Blue,Green), 2x BitFenix 140mm Spectre Pro LED |
Memory | 16 GB Gskill Ripjaws X 2133 (2400 OC, 10-10-12-20-20, 1T, 1.65V) |
Video Card(s) | AMD Radeon 290 Sapphire Vapor-X |
Storage | Samsung 840 Pro 256GB, WD Velociraptor 1TB |
Display(s) | NEC Multisync LCD 1700V (Display Port Adapter) |
Case | AeroCool Xpredator Evil Blue Edition |
Audio Device(s) | Creative Labs Sound Blaster ZxR |
Power Supply | Seasonic 1250 XM2 Series (XP3) |
Mouse | Roccat Kone XTD |
Keyboard | Roccat Ryos MK Pro |
Software | Windows 7 Pro 64 |
System Name | Americas cure is the death of Social Justice & Political Correctness |
Processor | i7-11700K |
Motherboard | Asrock Z590 Extreme wifi 6E |
Cooling | Noctua NH-U12A |
Memory | 32GB Corsair RGB fancy boi 5000 |
Video Card(s) | RTX 3090 Reference |
Storage | Samsung 970 Evo 1Tb + Samsung 970 Evo 500Gb |
Display(s) | Dell - 27" LED QHD G-SYNC x2 |
Case | Fractal Design Meshify-C |
Audio Device(s) | on board |
Power Supply | Seasonic Focus+ Gold 1000 Watt |
Mouse | Logitech G502 spectrum |
Keyboard | AZIO MGK-1 RGB (Kaith Blue) |
Software | Win 10 Professional 64 bit |
Benchmark Scores | the MLGeesiest |
i just noticed now my left front speaker is almost totally inaudible since a recent win10 install, i can JUST barely hear sound from it. I tried checking if it was the speaker or the plug that was broken, switched the plugs and speakers around, STILL only the left, no matter what speaker, so it isnt the speaker, it isnt the plugs, there is no audio enhancements, nothing.im totally stumped.
Remove and Reinstall the driver, check bios settings too, hopefully an OS update or hardware failure did not occur. I just use Soundcards myself lol
System Name | Windows 10 64-bit Core i7 6700 |
Processor | Intel Core i7 6700 |
Motherboard | Asus Z170M-PLUS |
Cooling | Corsair AIO |
Memory | 2 x 8 GB Kingston DDR4 2666 |
Video Card(s) | Gigabyte NVIDIA GeForce GTX 1060 6GB |
Storage | Western Digital Caviar Blue 1 TB, Seagate Baracuda 1 TB |
Display(s) | Dell P2414H |
Case | Corsair Carbide Air 540 |
Audio Device(s) | Realtek HD Audio |
Power Supply | Corsair TX v2 650W |
Mouse | Steelseries Sensei |
Keyboard | CM Storm Quickfire Pro, Cherry MX Reds |
Software | MS Windows 10 Pro 64-bit |
Happened to me once with potentiometer for volume control, it got a little dirty/rusty inside and contacts wasn't picking up both channels at all volume positions ... that's one more thing for you to checkI tried checking if it was the speaker or the plug that was broken, switched the plugs and speakers around, STILL only the left, no matter what speaker, so it isnt the speaker, it isnt the plugs, there is no audio enhancements, nothing.im totally stumped.
plug your speakers into your smartphone and test to see if it is a plug issueIve tried that, no luck. Ill have to go at it again tomorrow, i was watching Dexter on netflix, and lost track of time, its 0130 and im tired aF.
I dis notice a new bios Ver for my MoBo, but iirc there was no mention of audio adjustments, & i usually only update a bios to fix a issue the update is intended for, but ill likely try it if nothing pans out. I also noticed an audio update in the Asrock driver app, but the install doesnt take, it shows a newer Ver, it does the install, but once it successfully completes, the same update remains available & my starting older Ver of RT driver remains. Ill get fresh eyes on after some sleep.
Good night man
first.
Yes Sir that's what I figured, now to track down the fault....maybe the plug maybe the wire...maybe the internal amp...maybe maybe maybe....AT least you don't have to poke around Windows now tho ...Issue is present on phone. Ill have to yank the whole system out & check the wiring now. I just don't get it because I switched the speakers, I switched the plugs the speakers are plugged into, I switched everything around last night ,and although the issue was replicated ,it wasn't specific to a speaker ,it was specific to the left channel .
Yeah sorry man, but you could probably just order the part and solder it faster than their RMA process, but any ways good luck!im pissed, it seems to be at the Plug or further in the woofer. its a Z333 Logitech. the problem port is the blue one. I plugged the "working" right side speaker into that port and Nothing, i tried the other way around, and the left side speaker works. Im a bit Grumpy, when i bought the speakers, they are listed as having a 2 year warranty , but after submitting a claim with Logitech, it shows a 1 year warranty on the logitech site, which would put them Just out of warranty. i just dont get it, these thnigs are NEVER moved, or touched...how in the F@ck did the port get guffed up!
Some component in the left channel circuit burned out ... quite possibly part of the amp since you do hear the left channel very very quietlyhow in the F@ck did the port get guffed up!
Hold newegg accountable for the false information, show them that page. Have them give you another. After that do not shop through newegg, they are being ran by communists anyway.
they screwed up a few years back, i used to buy SO much from NE that i had a Support assistant girl that I could call or email whenever i had a issue, i didnt need to go through the motions ,etc, just straight pipeline to the supervisor girl. Then their support, and practices went to Sh!t, and I actually warned them it was happening, and then told them i was taking my business elsewhere, they are aware of the sh!t show they are running, but apparently couldnt care less. I no longer buy from them unless it suites me , or is a item i dont need quickly. Mainly amazon, B&H photo, SuperBiz, are my current stores, but now i buy much less, and only rarely need items. but i do avoid them like the plague. I found it SO funny when i found out your not allowed to use words like "Amazon" in the product reviews on newegg , they treat it like a terroristic threat, and flag your post, that shows their awareness, and lack of concern.
I just hope i can get out of having to buy a new speaker setup, ad this one is barely 1&1/2 years old, and in perfect shape other than the faulty components.
I'm currently waiting in line with chat support on Newegg hopefully they'll take responsibility for the false advertising , & help me out, but i have a feeling this one isnt gonna go my way
