ac power adapter polarity readings cause I'm confused...
786 (0.16/day)
UT,US
System Name Asrock 2012
Processor FX 8350 4.2Ghz no turbo
Motherboard ASRock 970 PRO3 AM3+
Cooling Corsair H70 for CPU
Memory 32GB DDR3 1960Mhz
Video Card(s) NVIDIA 1080 with stock fan
Storage 1TB GIGABYTE SSD NVME PCIE 2.0 + Samsung SSD Evo 850 250GB with Ubuntu + Samsung SSD 860 500GB win7
Display(s) LG HDR 31.5"
Case Big Black Tower
Audio Device(s) Realtek audio + Audigy 2 ZS platinum
Power Supply CORSAIR RM850X
Mouse microsoft intellimouse usb to ps/2
Keyboard Logitech
Benchmark Scores +
I bought 2 ac dapters for usb hubs and they work great however, I need a third one with 4A to increase current for the host devices from 2A currently on the hub.
I am scared now for polaritys don't wanna damage anything so, I wanna buy the right polarity one.
-I have 3 usb hubs, 1 usb 2.0 with 4A ac adapter works great, 1 usb 3.0 with 4A ac adapter works great but i want a 4.0 and, 1 usb 3.2 with 2A works great.
the pic on the left is on my usb 3.2 hub I just need the right polarity, how do i got about buying it?
2,342 (0.44/day)
Processor Intel i7 970 // Intel i7 2600K
Motherboard Asus Rampage III Formula // Asus P8P67 Deluxe
Cooling Zalman CNPS9900MaxB // Zalman CNPS11X
Memory GSkill 2133 12GB // Corsair V 2400 32GB
Video Card(s) ASUS GTX1080 // MSI GTX1070
Storage Samsung 870EVO // Samsung 840P
Display(s) HP w2207h
Case CoolerMaster Stacker 830se // Lian Li PC-9F
Power Supply Seasonic X 850w Gold // EVGA 850w G2
Mouse Logitech G502SE HERO, G9
Keyboard Dell
Software W10 Pro 22H2
Most hubs are center pin positive.
Example from your picture:
Outer barrel is negative and center pin is positive.
Always look at picture diagram.
7,074 (1.01/day)
USA
Cooling Noctua NH-D15S, 2xThermalRight TY-143, 4xNoctua NF-A12x25,3xNF-A12x15, 2xAquacomputer Splitty9Active
Case Lian Li O11 Air Mini
Mouse Zowie EC3-C
Software Win 10 LTSC 21H2
You use the symbol on the AC adapter, it will tell you if the external "sleeve/barrel" on the plug (the part that entering the device) is 'plus' or "minus" polarity.
Example:
means that the external sleeve is plus.
means that the the external sleeve is minus.
You can use a digital multimeter to check it.
786 (0.16/day)
UT,US
Keyboard Logitech
Benchmark Scores +
external sleeve? that's up or down on the tip?
807 (0.69/day)
People's Republic of Banania
Processor Threadripper 3955WX
Motherboard M12SWA-TF
Cooling Arctic Freezer 4U SP3
Memory G.Skill Trident Z DDR4-3733 (2x8GB)
Video Card(s) 5700XT + 3x RX 590
Storage A lot
Display(s) ViewSonic G225fB
Case Corsair 760T
Audio Device(s) Sound Blaster Z SE
Power Supply be quiet! DPP12 1500W
Keyboard IBM F122
Software 10 LTSC
Hi.
The diagram resembles the barrel connector viewed from the top, the outermost part or sleeve is symbolised with the semicircle and the internal contact with the dot. Most have the sleeve with a negative polarity because that's the thing you can touch.
In the two pictures you've uploaded the diagram is exactly the same, just in different positions.
13,360 (1.98/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
^^^This^^^ And for all sorts of reason too, but most significantly, safety. With the positive voltage in the center (and ground on the outer ring), that + voltage is much more protected from accidental shorts should the plug fall on to the metal case, for example.
Still it is important to verify polarity whenever attempting to combine voltage sources. The thing to remember is, with DC voltages, "parallel adds current, series adds voltage".
807 (0.69/day)
Storage A lot
Case Corsair 760T
Keyboard IBM F122
Software 10 LTSC
I'm more worried about the hubs being 'dumb' as in, internally they're just a series of ports connected in parallel.
I mean that's usually not an issue unless you want to start pulling large amounts of current, if they're connected using wires those could get too hot if there's no current limiting circuitry. I wouldn't use a hub to power something that pulls 4 amps, better power it directly.
For reference I have a lamp using about 3.5 amps and the whole wire gets hot after a while, it can take it as it's within normal operating conditions but at one point I had it on a cheapo adapter that *claimed* it was 4A and it literally melted the wire until it shorted, there was no fire or anything just a spark and smoke, and that was the end of that.... replaced it with the cable & PSU I'm using now. Don't go too cheap on adapters or that happens.
42,729 (6.69/day)
Look at the hub itself and get the required adapter
13,360 (1.98/day)
Nebraska, USA
Mouse Logitech M190
I am not following.
There are 2 separate circuits in typical USB connections; data and power. NO WAY are you going to overload the data circuits to the point heat is even remotely going to become an issue.
As for power, each hub has its own power supply. The only place excessive current (and thus heat) could become an issue is with the wall outlet. But only after you connect dozens of adapters to a single outlet.
Look at your adapters again. In terms of heat, don't worry about the DC output current. Look at the AC input. In your first image, that adapter draws a mere 0.4A. The 2nd adapter just 0.7A. Most wall outlets are rated for at least 15A (in older homes), typically 20 to 25A.
