Access to path is denied
AsterixenObelix
8 (0.01/day)
Using the latest version of NVCleanstall. after selecting the NVIDIA driver version and the desired components, NVCleanstall starts preparing sources by copying installer files. When this is almost finished, I get an error message, stating "Copy failed for .nvc/Display.Driver.nvc
Access to the path
'C:\Users\Roger\AppData\Local\Temp\NVcleanstall\.nvc\Display.Driver.nvc' is denied."
Tried several versions of the NVIDIA driver. always the same error. seems strange to me that all other files can be copied, except this one. I found one previous posting regarding a similar message, using an earlier version of NVCleanstall. that one was solved after a new version of the app was made.
So, anybody any idea??
W1zzard
Administrator
28,154 (3.72/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
Hmm... disk full?
2,570 (0.53/day)
Springfield, Vermont
System Name KHR-1
Processor Ryzen 9 5900X
Case Corsair 275R
Mouse Logitech G Pro (Hero)
Looks like the Windows permissions are screwed and you need to wipe the drive and do a clean install of Windows 10.
AsterixenObelix
8 (0.01/day)
Sorry, can't imagine that that's the cause of this problem. None of the programs I install, none of the programs I'm running have a problem with permissions. Windows 10 runs very smooth, as does every program I use. The cause has to be something else. Where does NVCleanstall puts its temporary files? Or where can I find the extracted NVidia driver? Maybe the file above has wrong properties?
W1zzard
Administrator
28,154 (3.72/day)
Memory 48 GB
In your Temp folder, which is "C:\Users\Roger\AppData\Local\Temp" on your system, the standard location
8,226 (2.13/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
Download and do a clean install (but use DDU first), the driver from the nvdia's website. If install completes without a hitch, your all set.
W1zzard
Administrator
28,154 (3.72/day)
Memory 48 GB
Does this happen every single time or just rarely? What antivirus are you using? Any difference if you turn it off?
97 (0.05/day)
System Name Dark Flash Phantom
Processor i9-9900KS @ 5.3Ghz
Motherboard Z390 AORUS MASTER
Cooling RBG 2000 to 6000 rpm Fans
Memory 64Gb DDR4 3800Mhz
Video Card(s) RTX 4070 Super
Storage 5 Sabrent 2TB Rocket NVMe PCIe M.2 SSD Drives
Display(s) 55 inch Sony
Case Darkflash Phantom
Power Supply 1300 Watt
VR HMD Quest 3
Software Windows 11 / Linux Duel Boot
Benchmark Scores https://www.gpumagick.com/scores/show.php?id=34679 https://valid.x86.fr/cs4dc6
Access to the path
'C:\Users\Roger\AppData\Local\Temp\sNVcleantall\.nvc\Display.Driver.nvc' is denied."
Take ownership of that folder
To remove sNVcleantall folder open command as admin type
cd C:\Users\Roger\AppData\Local\Temp
then
takeown /r /d y /f sNVcleantall
then to take ownership of the folder type
icacls sNVcleantall /reset /t
you can now delete folder
Try to reinstall once the folder is gone
97 (0.05/day)
VR HMD Quest 3
Why would that be needed?
Sometime folders get trusted installer locked and won't allow you to remove them thus access denied errors just a suggestion to try
W1zzard
Administrator
28,154 (3.72/day)
Memory 48 GB
AsterixenObelix
8 (0.01/day)
Happens every single time I run NVCleanstall, whatever driver version I choose. I use Bitdefender Total Security. Turning it off makes no difference. What seems strange to me is that every folder in the location where NVCleanstall stores its files, is read only. That obviously has no effect on the files that are copied in there, except for the one mentioned in my opening post. Changing the read only status during the copying phase, has no effect. Can that be a cause for the error message?
When the error shows up, below the green progress bar it says "Dsiplay Driver (decompress)". Copying of the files is almost finished.
I can install the NVidia driver without a hitch. Minimum options selected, but that seems to be more than NVCleanstall will install when choosing Minimum.
You write that when the driver installs without a hitch, I'm all set. What do you mean with this?
8,226 (2.13/day)
SE Michigan
System Name Dumbass
W1zzard
Administrator
28,154 (3.72/day)
Memory 48 GB
read only
When you get the error message, don't close the error window. Go to the Display.Driver.nvc file in Explorer, is it read-only? Remove read-only status and click on retry
AsterixenObelix
8 (0.01/day)
I’ve looked into that. what seems strange to me is that the folder \.nvc is read-only, but the file Display.Driver.nvc isn’t, no check boxes are marked. All the directories are read-only, BTW.
Although I tried removing the read-only status of the folders, without any positive effect, I’ll give it another try. Keep you informed.
W1zzard
Administrator
28,154 (3.72/day)
Memory 48 GB
The square "readonly" checkbox on the folder seems normal, same on my system. The checkmark checkbox on a file is actually what makes it readonly. Folders themselves can't be readonly on Windows.
7 (0.00/day)
There's your problem: BitDefender.
It is a colossal pain in the rear. Picks a fight with every file, locks them down until you deal with them and even then, you have to reboot. Worst of all, "disabled" doesn't actually do bugger all, including disabling anything. It will just carry on, happy as Larry, blocking files. For which it'll notify you of at some point, ten minutes after the fact.
I learned this the hard way after 2 days of Battlefield 2042 errors, which left my Windows install borked, my BIOS corrupt and my boot sector nuked. The culprit? BitDefender. Why and how it caused all of that I still do not know.
You will need to create exceptions out the wazoo and fight it constantly. Just assume every error you get is BitDefender and start there, you'll be better off.
AsterixenObelix
8 (0.01/day)
Wow, you seem very clear about your opinion regarding Bitdefender. So even when I switch off any protection, Bitdefender will still have influence, do I understand this correct? I don’t understand why any other file is written to the directory, nit this particular one isn’t. When Bitdefender causes this problem, it should do that right from the beginning, right?
Anyway, I will turn Bitdefender off and give it a try.
