Accurately Determining Hardware Supported DirectX Level?
rcmaehl
2 (0.00/day)
Hi all,
I was hoping that GPU-Z could share a reliable way to query the Hardware Supported DirectX Level via DXDiag or a DLL call.
I know that I can't rely on "DirectX Version" as even a 8600 GT will report DirectX Version 12
I was previously using DDI version, however I have reports of people having that not much up to what their card supports.
For Example, this UHD 730 which supports DirectX 12.1 reports DDI 11.1:
Will I just end up having to create a database of edge cases, or is there someway to poll DirectX or WIndows to get this accurately?
Thanks in advance!
2,950 (1.14/day)
System Name System V
Processor AMD Ryzen 5 3600
Motherboard Asus Prime X570-P
Cooling Cooler Master Hyper 212 // a bunch of 120 mm Xigmatek 1500 RPM fans (2 ins, 3 outs)
Memory 2x8GB Ballistix Sport LT 3200 MHz (BLS8G4D32AESCK.M8FE) (CL16-18-18-36)
Case NZXT Source 210
Power Supply Corsair CX650M
Benchmark Scores Corona 1.3: 3120620 r/s Cinebench R20: 3355 FireStrike: 12490 TimeSpy: 4624
You'd definitely have to wait until someone with programming experience comes by, but aren't you supposed to query the feature level instead of DDI?
rcmaehl
2 (0.00/day)
I just checked and I'm pretty sure you're right. The 8600M only went to Feature Level 10 which would be DX10.
Thanks
W1zzard
Administrator
27,988 (3.71/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
Create a context and check feature levels. This will give you what the current system supports, not what the underlying hardware supports.
For GPU-Z I'm using a lookup table. No other way to report "DX12 capable: Yes" on Windows XP or Windows 7
qubit
Overclocked quantum bit
17,865 (2.86/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
Unbelievable that something as simple as hardware version support should be so impossible to determine. I wonder if it's obfuscated like this deliberately.
2,950 (1.14/day)
From what I read, DDI is the driver interface. So, I suppose the DDI version is simply an indication of which DirectX version the driver was compiled/built for. Doesn't necessarily mean the driver supports all DX features.
