Adapters for Lian Li ARGB fans
33 (0.03/day)
Hi
Having fun with Lian Li and certain fans not being compatible with each other. (of their own brand)
I have 9 (needed 10 but only sold in packs of 3) Lian ST fans. The hub cable ends with the normal 3 pin argb fitting but it's housed differently meaning a normal argb 3 pin will not fit. So does anyone know of an adapter that will turn a normal 3 pin to a Lian li 3 pin.
Now second option was to get a Lian Li Uni AL fan, but its argb fitting is different yet again. It has a different 3 pin fitting. So, second question is does anyone know of an adapter to make Lian Li Uni AL fans fit Lian Li ST connections.
1st pic is the Lian Li ST argb fitting that no normal 3 pin argb will fit because of the shape of the housing.
2nd pic is the Lian Li Uni AL argb fitting which also does not fit the ST fitting.
3rd pic is the standard 3 pin argb.
Thanks
