Adding 2 more sticks of DDR5 Ram 64gb for a total of 4
weagudelo
1 (0.04/day)
Colombia
I am currently using two sticks of CORSAIR DOMINATOR PLATINUM RGB DDR5 RAM 64 GB, on a MSI Z790 Ace Meg Motherboard, but would like to fill in the empty ram gaps and buy two more memory sticks of Corsair Dominator Platinum RGB DDR5 Ram sticks. The additional 2 sticks of Ram cost around $300 us dollars. They are kind of expensive. The thing is that I will no be able to get a refund, if they do not work well on my rig, since I live overseas. What should I do? Any recommendations or suggestions?, please!
7,473 (1.04/day)
Video Card(s) Sapphire PURE AMD Radeon™ RX 9070 Gaming OC 16GB | Intel® Iris® Xe Graphics
There can be issues running 4 sticks but it all depends on what the memory controller in your CPU can do.
4 sticks can lead to not running XMP/EXPO, needs manual tuning and can overall bring a lower speed with them.
What do you need 4x64GB for? If it's for workstation and server related things you shouldn't care about the speed that much more stability if it's for gaming keep what you have.
2,159 (0.80/day)
Ibiza, Spain.
System Name Main
Processor R7 5950x
Storage six M.2 pcie gen 4
Display(s) Sony 50X90J
Case Tt Level 20 HT
Power Supply Corsair RMx 750w
Mouse Logitech G903
Keyboard GSKILL Ripjaws
VR HMD NA
Software win 10 pro x64
will work fine, as long as they are identical not just in spec, but chip used.
as long as you can get the seller to confirm what dies are used on them, and confirm (they are identical to yours)...
206 (0.13/day)
Processor 265K (running stock until more Intel updates land)
Motherboard MPG Z890 Carbon WIFI
Cooling Peerless Assassin 140
Memory 48GB DDR5-7200 CL34
Video Card(s) RTX 3080 12GB FTW3 Ultra Hybrid
Storage 1.5TB 905P and 2x 2TB P44 Pro
Display(s) CU34G2X and U2724D
Case Dark Base 901
Audio Device(s) Sound Blaster X4
Power Supply Toughpower PF3 850
Mouse G502 HERO/G700s
Keyboard Ducky One 3 Pro Nazca
Depends on a lot unfortunately, because you can rapidly run into timing and stability issues when using 2DPC. What speed is the DRAM that you're using?
824 (1.17/day)
Brazil
Processor 5950x
Motherboard B550 ProArt
Cooling Fuma 2
Memory 4x32GB 3200MHz Corsair LPX
Video Card(s) 2x RTX 3090
Display(s) LG 42" C2 4k OLED
Power Supply XPG Core Reactor 850W
Software I use Arch btw
Don't you mean you have 2x32GB sticks and plan to add another 2x32GB sticks?
If so, there's a high chance you won't be able to reach the current frequency you have now, and may need to drop down to 3600~4800MHz.
2,213 (4.32/day)
Nowhere
Processor 14700K
Motherboard Asus TUF Z790
Cooling Air/water/DryIce
Video Card(s) RTX 4070 Super
Storage 980 Pro
Display(s) 1080P 144hz
Case Open bench
Keyboard Logitech G910
VR HMD Quest 2
Software Windows
Why not try the Corsair Dummy sticks? Lighting kit or something it's called.
1,842 (0.33/day)
Azalea City
System Name Test Bench #3
Processor Ryzen 5 8600G delidded, +200PBO -30CO
Motherboard B650M-HDV M.2
Cooling Water, liquid metal
Memory TRIDENT Z5 @8400CL36
Video Card(s) 760M @3300MHz
Storage Samsung PM981
Display(s) MAG401QR
Case Open Frame
Audio Device(s) Logitech Z623
Power Supply EVGA P5
Mouse Cooler Master MM710
Keyboard Huntsman Elite
Software 10 Pro
Benchmark Scores https://hwbot.org/user/luke
There should be more 2 slot mid-high end boards to discourage this behavior
freeagent
10,260 (4.28/day)
Winnipeg, Canada
System Name Step_sis Rodeo
Display(s) LG 50UP7100
Case Asus ProArt PA602
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
I just bought 2 more sticks to see if this is true :D
I saw that Corsair and Kingston have 4x 16GB kits of 6000 and 6400 validated for my board and CPU series.. I am not running either of those brands, but with the new AGESA updates I think it might be ok.. if not then oops..
For science!
ir_cow
4,947 (0.82/day)
USA
I bought the dummy sticks for DDR4 a few years ago. Would not boot all the time. $20 wasn't so bad to find out.
freeagent
10,260 (4.28/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
Maybe I can tame the beast.. maybe I cant.. find out Monday :ohwell:
8,166 (5.21/day)
São Paulo, Brazil
Video Card(s) NVIDIA RTX A2000 (5090 shipping to me soon™)
Display(s) 55-inch LG G3 OLED
Software Windows 10 Pro 22H2
As long as they are the same type and same revision (important with Corsair sticks), should work. 4x sticks will significantly lower your attainable memory speed, though. Expect no more than 6000 with 4, 5600 is more realistic but could be as low as 4800-5200 depending on CPU
freeagent
10,260 (4.28/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
If I can nail down 6000-6400 I will let me buy me a coffee :)
freeagent
10,260 (4.28/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
824 (1.17/day)
Brazil
Processor 5950x
Cooling Fuma 2
Sweet, next time I will let you pay for the hardware :)
I already paid for 4x that amount, will report how it goes once I have it in hands :p
2,159 (0.80/day)
Ibiza, Spain.
System Name Main
Processor R7 5950x
Case Tt Level 20 HT
Mouse Logitech G903
VR HMD NA
@damric
no, anytime a board has 4 slots and you can buy kits with 4 sticks that fit, companies need to make it work.
forcing +90% of users to know detailed things like this, prior to buying just to get stuff to work is a joke, anything else sold that way and ppl would be on the barricades.
freeagent
10,260 (4.28/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
If I cant get it to work the way I want it to, I have a guy at work who will buy a kit from me. So either way its for science, and I lose nothing.
134 (0.07/day)
update the BIOS and do a ClearMOS with just 1 stick
Then you install the other 3 sticks
But you will have to work at a fixed frequency of 5600Mhz.
1,842 (0.33/day)
Azalea City
Display(s) MAG401QR
Case Open Frame
Software 10 Pro
@damric
Yeah but just don't expect to run 8700CL36 like my $99 2 slot board
2,159 (0.80/day)
Ibiza, Spain.
System Name Main
Processor R7 5950x
Case Tt Level 20 HT
Mouse Logitech G903
VR HMD NA
oh sure, just the common stuff around the systems sweetspot range should "always" work.
freeagent
10,260 (4.28/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
Either my ram sucks, or my OC skill sucks because I cannot nail down 6400 with 2 sticks lol. So at this point just running a tweaked EXPO is good enough. I can bench and stuff at 8200 but I cant get anything to be stable lol.
*Glances fondly to AM4 sitting in a box*
:ohwell:
Solaris17
Super Dainty Moderator
27,546 (3.84/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
3x 7950x servers with 128gb ram and the best I can manage is 5200. Which is fine because they are servers and I don’t fuck with the clocks but when I was testing 1 (before I bought the other 2) it absolutely would not do it.
