adobe flash keep crashing on firefox
983 (0.21/day)
Memory 2x24gb Gskill 8800c38
Storage 1TB Samsung 860Evo,2*2tb Samsung 970Evo Plus, 1tb Intel 660p nvme
Display(s) Sammsung G7 32”
Case Dynamic XL
Power Supply Corsair AX1600i
Mouse Model O-
I have trouble with flash on firefox. Everytime I log in youtube and click a video, adobe flash crashes. I tried uninstall and reinstall but it doesn't help. I don't know what is wrong. I updated flash to the latest version and it still crashes.
43,593 (6.64/day)
Motherboard ASUS TUF x670e
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
For now, I use Chrome. IE has issues with Flash as well.
40,435 (6.51/day)
Remove firefox. Use flash removal tool from adobe. Use cc cleaner too. Use an older version of flash.
TheMailMan78
Big Member
22,599 (3.62/day)
'Merica. The Great SOUTH!
43,593 (6.64/day)
Storage WD m.2
Keyboard Tester84
HTC
4,612 (0.78/day)
Portugal
System Name HTC's System
Processor Ryzen 5 5800X3D
Motherboard Asrock Taichi X370
Cooling NH-C14, with the AM4 mounting kit
Memory G.Skill Kit 16GB DDR4 F4 - 3200 C16D - 16 GTZB
Video Card(s) Sapphire Pulse 6600 8 GB
Storage 1 Samsung NVMe 960 EVO 250 GB + 1 3.5" Seagate IronWolf Pro 6TB 7200RPM 256MB SATA III
Display(s) LG 27UD58
Case Fractal Design Define R6 USB-C
Power Supply Corsair TX 850M 80+ Gold
Mouse Razer Deathadder Elite
Software Ubuntu 20.04.6 LTS
I have had to un-install firefox and re-install it again twice to fix the problems i was having with flash (it gave me problems with about 8-10 days of intervall between them): on both occasions, it fixed the problem.
Before doing that, i tried un-installing and re-installing flash but that didn't work.
Still using firefox (latest version).
40,435 (6.51/day)
Waterfox here
6,771 (0.96/day)
Republic of Asia (a.k.a Irvine), CA
System Name ---
Processor FX 8350 @ 4.00 Ghz with 1.28v
Motherboard Gigabyte 990FX-UD3 v4.0, Hacked Bios F4.x
Cooling Silenx 4 pipe Tower cooler + 2 x Cougar 120mm fan, 3 x 120mm, 1 x 200 mm Red LED fan
Memory Kingston HyperX DDR3 1866 16GB + Patriot Memory DDR3 1866 16GB
Video Card(s) Asus R9 290 OC @ GPU - 1050, MEM - 1300
Storage Inland 256GB PCIe NVMe SSD for OS, WDC Black - 2TB + 1TB Storage, Inland 480GB SSD - Games
Display(s) 3 x 1080P LCDs - Acer 25" + Acer 23" + HP 23"
Case AeroCool XPredator X3
Audio Device(s) Built-in Realtek
Power Supply Corsair HX1000 Modular
I had similar issue, even after doing all the above things u mentioned, I occasionally get flash crash error or the computer crawls to a total stop, restart PC and the computer works fine for few weeks.
6,629 (1.46/day)
Florida
System Name natr0n-PC
Video Card(s) EVGA 3070ti FTW | Sapphire PULSE RX 590
Storage Various
Display(s) PIXIO IPS 240Hz 1080P
Software XP/7/8.1/10
HTC
4,612 (0.78/day)
Portugal
qubit
Overclocked quantum bit
17,865 (2.95/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Keyboard Yes
Firefox and Flash have been an unstable POS combination for years. The framerate is pants too - uneven and slow - especially on 60fps video where IE and Chrome have no problem.
The sooner we can move away from Flash the better.
7,023 (1.39/day)
Flash and FF didn't go well since the dawn of time, even on Linux.
Latest IE never crashes flash videos but if you scroll down while movie still playing and then scroll up back again you notice that vision and sound are asynch.
It seems that plugin and activex both suck monkey balls. Shame Silverlight or html5 didn't push flash away.
qubit
17,865 (2.95/day)
Quantum Well UK
Keyboard Yes
I'll bet this is at least part of the reason that Steve Jobs so hated Flash on his new iPad at the time.
What gets me, is that there have been periods where FF and Flash have worked properly, then one of them is updated and we're back to square one. Also, FF overall doesn't scroll as smoothly as IE, again a framerate issue which might be the same underlying problem. Once again, they solved that a few versions ago, but the problem annoyingly came back soon enough. On top of that, the profile on my FF is old and bloated which makes the problem worse and I can't be bothered to rebuild it from scratch.
1,618 (0.29/day)
flash is fine here on 570m+win7, 7850k+win7, a couple XP machines, any driver, any standard FF versions (up to 34 so far), any flash versions
dont know what to tell you other than addon conflict or gfx driver conflict, i would be interested in figuring out where it goes wrong but i would have to remote control other people's computers
FF scrolls smoothly if you use middle click or possibly addons, this actually bugs me about all browsers ever since i tried opera with its smooth scrolling a whole decade ago
twitch plays 60fps in flash, youtube is a horrible player, giantbomb almost gets 60fps but not in fullscreen, you have to f11 the browser then embiggen their player
you can enable media source extensions in FF to get the html5 version of 60fps youtube, otherwise just use the html5 version instead of flash when possible
btw, everyone should set flash to 'always ask' & never 'remember' for a site, it's an obvious security risk even if it's merely the fact that it uses different cookie storage to potentially track you (eidairaman1, cant believe you suggested to use an older flash version without a sandbox...)
consider me a heavy user, but there is little to no flash usage lately... however i have been on flash video sites before, opening ~50-100 tabs, browser nearing 2gb ram, plugin-container above 1gb, yet crashes were still rare
qubit
17,865 (2.95/day)
Quantum Well UK
Keyboard Yes
Yes, if I installed FF fresh or used the reset option it might clear up some of this Flash instability and scroll and animate more smoothly, but then my customizations and 20-60 tabs I have open at any one time are fairly critical, so I just live with it, annoying as it is.
Sucks really, when Mozilla had solved this problem previously and then went backwards. Sounds like a misfire to me, like going from Google to Yahoo as the default search engine in my opinion.
1,261 (0.31/day)
System Name Some computer stuff
Processor Mostly Intel or AMD
Motherboard ATX or mATX
Cooling Bong Cooler
Memory DDR2-4
Video Card(s) A few
Storage Plenty Platters or SSDs or USBs
Display(s) Samsung 23"
Case 5 on the floor
Audio Device(s) There's one for my M7 Gene, Oh I have 3-4 PCI 5.1 ones.Sabrent! lol
Power Supply 750-1000W
Mouse cheap
Keyboard Used ps2 from garage sales
Software Yeah
Benchmark Scores http://hwbot.org/user/schmuckley/#Hardware_Library http://valid.canardpc.com/rbjpbg
you can find a slow-loading video..and really quick you have to right-click the video and untick "enable hardware acceleration"
it might take a few tries..
idk..it'll work fine for a while and then firefox or flash will update and it be scuttled again
the last version of flash and firefox 28 work fine.
Why do those 2 things auto-update and break themselves all the time?
Do they not realize what they're doing or what?
At least give people the choice to NOT update.
7,023 (1.39/day)
Yup, there seem to be some sorta loophole in their code so sooner or later it always shows its ugly head. Just like Windows Tuesday patches, they fix one thing but break something else. I'm sure after gazillions of updates nobody can get their head around the code so they just left it unfixed. Logical conclusion: maybe it's time to write something new.
719 (0.15/day)
coventry UK
System Name Gwafwar
Processor Ryzen 5 3600
Motherboard Msi MPG X570 Gaming Plus
Memory 16Gb Adata Spectrix 3600 Cl18
Video Card(s) Palit GTX970 SLI
Storage Adata 512Gb SX8200 pro
Display(s) 3x 27" 1080p Lg's
Case Coolermaster 690 II pure black
Power Supply Coolermaster 750W Masterwatt
Mouse Saitek X65-f HOTAS
Software Win10 Pro
A new version of firefox came out this week. Seems to have fixed some of the bugs that the last version was suffering from.
9,854 (1.89/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
now i just run portable chrome or portable based from chrome engine
7,023 (1.39/day)
Youtube videos don't lag anymore on IE. This recent flash update seems to be really good.
qubit
17,865 (2.95/day)
Quantum Well UK
Keyboard Yes
Yup, youtube videos don't lag anymore on IE. This recent update seems to be really good.
How would an FF update affect IE? Could it be something else changed at about the same time to make it seem like they're connected?
7,023 (1.39/day)
My bad. I was talking about recent flash update for ie. I thought they talked about flash lol
61 (0.02/day)
HK
System Name I read I watch I listen but I don't game (2013 Sep build)
Processor Intel Core i7 4770K
Motherboard Asrock Fatal1ty Z87 Killer
Cooling Cooler Master Hyper 212X
Memory Transcend DDR3-1600 16GB
Video Card(s) Inno3D GTX 660
Storage Transcend TS128GSSD340, Western Digital WD3000FYYZ, Hitachi HDS722020ALA330, Seagate ST2000DM001
Display(s) Eizo EV2455 24.1" 1920x1200
Case Cooler Master CM 690 III
Audio Device(s) Arcam irDAC + Harmon Kardon HK980 + Q Acoustics 3020 / Shure SRH1540 / Aurisonics ASG-1.5
Power Supply Corsair AX750
Mouse Roccat Kone Pure Optical / CM Storm Xornet II
Keyboard Varmilo VA87MR
Same here. Flash seldom crashed before that 16.0.0.296 update. Now it crashes every time I play video it's crazy. I need flash to watch sports livestream, damn...
6,629 (1.46/day)
Florida
Storage Various
use the firefox beta as html5 is the default player, its up there with chrome already in advancements.
