Ageia Physx ?
1,042 (0.17/day)
Transylvania (RO) working in Barcelona (ES)
System Name Rzyen X
Processor Ryzen 7 7800X3D ^ PBO -30 ECO mode 1.15v SOC
Motherboard Gigabyte B650 Gaming X AX
Cooling Arctic Liquid Freezer II 420 A-RGB
Memory 32Gb Adata Lancer XPG 6000Mhz CL30 EXPO 1.260v
Video Card(s) Sapphire RX 7900 GRE Nitro+ OC - core 2800Mhz / mem 2600Mhz
Storage 1TB WD SN850X + 2TB WD SN770 + 2TB Adata Legend 850
Display(s) ViewSonic ColorPRO VP2776 - 27" 1440p^165Hz
Case Phanteks P600S White
Audio Device(s) Logitech Z2300 + Skullcandy Crusher Evo
Power Supply EVGA T2 1000W Titanium
Mouse RedDragon M686 RGB
Keyboard SPC GK630K Tournament
Software Windows 11 PRO
Benchmark Scores CB R23 - 18.703 pct / CB 2024 - 1.159 pct
Hello all... I changed my GPU from GTX560Ti to 6970 and i wanna buy an AGEIA PHYSX (BFG) dedicated card for the upcoming BATMAN game... The question is that this card it's supported by the new PHYSX software ???? I got one card that i can buy for cheap (like 15 Euros)...
1,877 (0.32/day)
UK Warwickshire
System Name PC-Chips
Processor AMD Ryzen 7 5700x3D
Motherboard Asus ROG Strix B550-F Gaming.
Cooling White arctic liquid freezer iii 360 a-rgb AIO.
Memory Patriot Viper 32gig dual channel 3600mhz
Video Card(s) PowerColor HellHound RX 7900 GRE OC.
Storage 2 Samsung 860 EVO's 500gig / 2TB crucial P3-NVME / WD-BLUE SN550 1TB M.2 / SP A55 512gig / 8TB HDD
Display(s) TCL 50-inch 4k TV freesync HDR
Case White NZXT H9 Flow Dual-Chamber
Audio Device(s) Realtek S1220A - Yamaha A-S501 AMP - Wharfedale diamond 9.1 speakers - Wharfedale SW150 sub
Power Supply EVGA SuperNOVA G6 750W 80+ Gold
Mouse Some cheap wireless thing
Keyboard Razer Cynosa lite
VR HMD Oculus Quest 2 128gig version
Software Windows 11 pro 64bit
As far as i remember support for that was stoped not long after nvidia bought them.
690 (0.11/day)
System Name Pegasus
Processor AMD Ryzen Threadripper 1950X @ 4GHz
Motherboard ASUS ROG Zenith Extreme
Cooling Custom 480mm EK Loop
Memory 4 x 8GB G.Skill TridentZ RGB 3000MHz @ 3000MHz
Video Card(s) ASUS ROG Nvidia GTX 1080 Ti
Storage Samsung 960 EVO M.2 500GB / Samsung 850 EVO 500GB / Samsung 840 EVO 250GB
Display(s) 2 x 25" Dell Ultrasharp U2515H / 1 x 15" ASUS MB169+
Case Corsair 900D
Audio Device(s) 2 x Tannoy Reveal 502 / Beyerdynamic DT 990 PRO 250 Ohm / Behringer Xenyx X1204 USB / MXL 770
Power Supply EVGA SuperNova G3 1000W
Keyboard HyperX Alloy FPS / Corsair K95 RGB / Anne Pro 2 / 2 x Elgato Stream Deck
Software Windows 10 Professional 64-Bit
You'd have to use an nvidia card along with your card to run physx.
1,042 (0.17/day)
System Name Rzyen X
Then AGEIA isn't good anymore ?!
5,226 (0.83/day)
System Name Addison Clark
Processor Ryzen 9 7950x3D delid
Motherboard Asus X670E Hero
Cooling Custom Bykski loop CPU, GPU, 2x 360 rads, and 1x 280 rad with Arctic P12 and P14 ARGB fans
Memory G.Skill DDR5-6000 64GB CL30
Video Card(s) Gigabyte 4090 Aorus Master
Storage Kingston Fury 2TB and 4TB NVME
Display(s) Samsung 57"
Case Lian Li O11 mini
Power Supply Thermaltake 1000w SFX-L
Keyboard Corsair K95 Platnium
Software Win 11 Pro
I'd recommend you buy a used GT 240/430/440, GTS 250/450, or a new one of the already listed at one heck of a price. Check out the hybrid mod page @ ngohq.com to help get you setup.
690 (0.11/day)
System Name Pegasus
Case Corsair 900D
Well, no, it's been dead since 2008. It's nvidia now.
1,042 (0.17/day)
System Name Rzyen X
A GT220 1GB DDR3 any good ?
5,226 (0.83/day)
Software Win 11 Pro
No, just because of its 48 shader count. Look for the above cards I mentioned, they all have atleast 96 shaders.
4,015 (0.75/day)
UK
System Name PC
Processor AMD Ryzen 3600
Motherboard MSI B450 Mortar Max
Cooling Phanteks PH-TC12DX, 3 x NZXT FN 140mm, 1x NZXT FV V2 120mm
Memory 32gb DDR4 3200mhz
Video Card(s) ASUS R9 290 DCII-OC 4GB
Storage corsair mp600 1TB
Display(s) LG 27MB85Z 27" 1440p
Case NZXT Source 340
Power Supply Thermaltake 675w
Mouse Logitech G500S
Keyboard Logitech G510S
Software Windows 8.1 64 bit
Yeah, should work perfectly
EDIT:According to kenkickr it won't, he probably knows more about it then i do so i'd listen to him
1,042 (0.17/day)
System Name Rzyen X
THANKS... but i have a another problem... my Mb doesn't have a second full pci-express slot, so i'm limited to regular PCI or pci-express x1... So what should i do then ?
4,357 (0.88/day)
Mexico
System Name Dell-y Driver
Processor Core i5-10400
Motherboard Asrock H410M-HVS
Cooling Intel 95w stock cooler
Memory 2x8 A-DATA 2999Mhz DDR4
Video Card(s) UHD 630
Storage 1TB WD Green M.2 - 4TB Seagate Barracuda
Display(s) Asus PA248 1920x1200 IPS
Case Dell Vostro 270S case
Power Supply Dell 220w
Software Windows 10 64bit
Arkham Asylum used an old version of the Physx SDK and worked fine with the PPU cards but the new one uses updated libraries. The PPU cards support up to 2.8.1
I think that nVidia are being jerks about this. The old PPUs can handle both CPU and GPU physics but nVidia says that the PPUs don't have the performance level required for current games, an statement to which I agree (the Ageia PPU is similar in physx performance to an 8600GT) but they could port the newer SDKs to the PPUs and let the user choose "lowest" physx settings if they desire to keep using them. Or if that isn't possible for some reason, let the game use them for the calculations they support (akin to using a DX10 card with a DX11 game).
Heck, if they put their minds to it I bet they could allow for the PPUs to work in tandem with a GPU in some sort of SLI physx but, sadly, they choose not to. They just simply left PPU users out in the cold.
861 (0.16/day)
System Name FragBox
Processor Intel Core i7 2600K @ 5.0GHz/1.45 volts
Motherboard Asus P8Z77 WS
Cooling Custom CPU loop
Memory Kingston 12GB DDR3 1600
Video Card(s) Galaxy GTX 680/Zotac GTX 680 in SLi/EVGA GTX 650Ti
Storage 2 Vertex 3 120's, raid 0, 2 Seagate Momentus XT 500GB's in raid 0, 1 Hitatchi 2TB for backup
Display(s) 3 Acer S232HLX2 in nvidia surround
Case Corsair C70 White
Power Supply Corsair AX1200
Software Win 7 x64 Pro
Those dedicated physx cards only had something equivalent to 12 or 16 shader cores, if it did work, it wouldn't be enough muscle for modern games, you need 92 or more.
1,042 (0.17/day)
System Name Rzyen X
I need this card... A ZOTAC GeForce GT 520 PCIe x1 card...
690 (0.11/day)
System Name Pegasus
Case Corsair 900D
It has 48 shaders, won't do any good. As others stated above you'll want 96 or more shaders on the card.
1,042 (0.17/day)
System Name Rzyen X
In the end if i want a good physx capable card (96 shaders minimum) i must change my mobo with at least 2x full pcie slots...
861 (0.16/day)
System Name FragBox
in all honesty, play the game without physx, and see if you still want it... keep in mind that if you do, you'll need to switch out that MB for one with more 16x slots.
1,042 (0.17/day)
System Name Rzyen X
Fair enough... but i can change my mobo with an ECS A890GXM-A and buy a cheap KFA2 9600GSO (96SP)... but i think that isn't worth it, no ?!
4,015 (0.75/day)
UK
System Name PC
http://www.techpowerup.com/img/10-03-01/3b.jpg
http://i1002.photobucket.com/albums/af141/linkdarkmx/PC/Galaxy9600GSO.jpg
Is this new Batman just really heavy on the physx or is there something else going on?
i mean Arkham Asylum said it needed a GTX260 + Dedicated 9800GTX+, using my GTS 250 Alone(Same specs as a 9800GTX+) setting the physx to highest didn't have too bad of an effect on the framerate, and the game still ran at a playable framerate at 1440x900
are you sure the new Batman's not the same where the requirements for physx's are just massively Exaggerated?
In all the Games using Physx i own, the Extra load caused by the Physx effect made a bigger difference then the Physx effects themselves
5,226 (0.83/day)
Software Win 11 Pro
If you still have that 560 and have thought of a board update then get a board and use the 560 for physx. It's a bit of overkill for dedicated physx but you can put it to use while it sits and get yourself a board.
8,523 (1.36/day)
Kansas City
System Name The Dove Box Rev 5.0
Processor 9800x3D
Motherboard Asus 870E STRIX
Cooling Custom Water
Memory 32 GB 6400 MTs
Video Card(s) Asus 3080 TUF
Storage 2TB Crucial T705
Display(s) 32" LG 1440p 180hz
Case Lian Li O11 Dynamic
Audio Device(s) ON BOARD FTW
Power Supply Corsair 1000W
Mouse Corsair something
Keyboard Steelseries
Software Win 10 64x
Dude, don't fall into the Physx trap. Your board would only take a second video card only in a 1x pci slot. Short of cutting half of the pci bus off of an older card, I don't think you have much else to work with.
Is all this worth extra foggy hallways and papers fluttering? Think about what your getting in return.
1,042 (0.17/day)
System Name Rzyen X
The GTX560Ti will be gone monday... i got a buyer today... so i'm thinking to leave the Physx card and upgrade with that SSD that i'm planing to buy for a few weeks...
8,523 (1.36/day)
Kansas City
Processor 9800x3D
Software Win 10 64x
Much better upgrade choice.
qubit
Overclocked quantum bit
17,865 (2.85/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
PhysX seems to have been one of those features that has a lot of technical merit, but for various reasons has never made the big time, so is hardly supported. In particular, I wouldn't go changing your PC round and spending lots of money just to see those PhysX effects in one game.
In particular, the way PhysX is implemented, it doesn't actually affect the gameplay at all and is simply a nice bit of eye candy. If you really have to play with it, get a GTX 570/580 or something (I see you've got the HD6970 and are selling the GTX 560 Ti) and enjoy PhysX on that. If nothing else, you can pick up some uber cool PhysX demos from the nvidia website.
