AGP card with Asus A7N8X-X motherboard
ClarkColeman
10 (0.00/day)
I am considering buying a new graphics card. Old card is freezing (ATI Radeon 7000 chip, PCI card) and I cannot cure the problems.
I am considering an AGP card. Standard references to AGP online list voltages for different speeds:
Speed Voltage
1X 3.3V
2X 3.3V
4X 1.5V
8X 0.8V
However, when I check my Asus A7N8X-X motherboard manual to ensure that I buy a compatible card, it says, in more than one place, something like:
AGP 8X (1.5V only)
That does not make sense to me. Can I buy an AGP 8X card for this system? Won't it be 0.8V and maybe not work?
This old motherboard has PCI slots and I don't believe that PCI Express cards will work with it. Is that right?
Thanks for any help.
6,270 (0.92/day)
New York
Processor INTEL CORE I9-9900K @ 5Ghz all core 4.7Ghz Cache @1.305 volts
Motherboard ASUS PRIME Z390-P ATX
Cooling CORSAIR HYDRO H150I PRO RGB 360MM 6x120mm fans push pull
Memory CRUCIAL BALLISTIX 3000Mhz 4x8 32gb @ 4000Mhz
Video Card(s) EVGA GEFORECE RTX 2080 SUPER XC HYBRID GAMING
Storage ADATA XPG SX8200 Pro 1TB 3D NAND NVMe,Intel 660p 1TB m.2 ,1TB WD Blue 3D NAND,500GB WD Blue 3D NAND,
Display(s) 50" Sharp Roku TV 8ms responce time and Philips 75Hz 328E9QJAB 32" curved
Case BLACK LIAN LI O11 DYNAMIC XL FULL-TOWER GAMING CASE,
Power Supply 1600 Watt
Asus A7N8X
Processor - AMD Athlon\Athlon XP with the bus speeds 100/133/166 MHz;
- AMD Duron with the bus speed 100MHz;
- Socket 462
The nVidia nForce II Chipset - North Bridge nForce2 SPP;
- South Bridge - nForce2 MCP-T;
- Interbridge Bus - HyperTransport (800 MB/s)
System memory - Three 184-pin slots for DDR SDRAM DIMM
- Maximum memory capacity 3 GB
- Supported memory types PC1600/2100/2700/3200
- 128-bit dual-channel memory access possible
- Onboard power indicator
Graphics - AGP slot supporting the 4x/8x modes
- AGP Warning LED indicator
Expansivity options - Five 32-bit PCI Bus Master slots;
- Six USB 2.0 ports (4 integrated + 2 additional);
- Two IEEE1394 (Firewire) ports
- Integrated audio nForce2 APU;
- LAN controller nForce2;
- LAN controller 3COM.
Overclocking Options - FSB adjustable between 100MHz to 250 MHz in 1(-5) MHz increments; multiplier adjustable;
- Processor/memory, AGP voltage adjustable.
Disk subsystem - 2 channel UltraDMA133/100/66/33 Bus Master IDE (with support for up to 4 ATAPI-devices)
- Support for SerialATA (2 channels)
- Support for LS-120 / ZIP / ATAPI CD-ROM
BIOS - 4MBit Flash ROM
- Award BIOS Phoenix with support for Enhanced ACPI, DMI, Green, PnP Features and Trend Chip Away Virus
Miscellaneous - One FDD port, two serial and one parallel ports, ports for PS/2 mouse and keyboard
- STR (Suspend to RAM)
- SPDIF Out
- Asus POST Reporter
- Asus Q-Fan
Power management - Wake-up on modem, mouse, keyboard, LAN, timer and USB
- Standard 20-pin ATX (ATX-PW) power connector
Monitoring - Processor temperatures, voltages and the rotational speeds of the three fans are monitored;
- Asus PC Probe utility
Dimensions - ATX form factor, 245mm x 305mm (9.63" x 12")
From the looks of your board specs you are able to use AGP 8X and backwards compatable to 4X...SO yes get you a beastly AGP 8X card should be fine as long as your PSU is up to it.:toast:
PS. Welcome to TPU and please list your specs.
ClarkColeman
10 (0.00/day)
Thanks. Any idea why it says "1.5V only" in a couple of places?
Where did you get your info?
6,270 (0.92/day)
New York
http://www.digital-daily.com/motherboard/asus-a7n8x/
Not sure about the 1.5volts...but AGP 8X is just that so an AGP 8X card will work ..again be careful with your PSU as the Newer high end AGP will need more power and usually another molex connected to it
ClarkColeman
10 (0.00/day)
OK, thanks. I am not looking at high end cards. I am considering an XFX GeForce 6200 that I can pick up for $55 from TigerDirect.com. I guess I will have to investigate its power consumption.
6,270 (0.92/day)
New York
Namslas90
4,846 (0.73/day)
Earth
DRDNA, can you confirm this pls?:respect:
From my understanding his mobo won't support an AGP card with 3.3volt signal, so he should stay with the 1.5volt signal cards. The tabs are different, the 1.5v on top, the 3.3v on bottom.
SlipSlice
770 (0.11/day)
Indiana
Processor AMD ATHLON 64 SAN DIEGO 3700@2.42GHZ
Motherboard ASUS A8N5X
Cooling 1X80MM CASE FAN, 1X80MM CPU FAN, 2X120MM FANS(ONE TAKING AIR OUT..OTHER FOR HARDDRIVE
Memory 1.5 GIG, DDR400 CORSAIR
Video Card(s) eVGA 7900GS KO
Storage 160GIG WESTERN DIGITAL 7200RPM
Display(s) Acer 22' Widescreen
Case ROSEWILL CASE 5600 SERIES..2 BLUE LED CASE FANS
Audio Device(s) SOUND BLASTER LIVE 24 BIT!
Power Supply SPARKLE 400 WATT
Software WINDOWS XP HOME EDITION..its gr8/LOTS OF GAMES
Yea that 1650 is quite a bit faster than the 6200, thats what i'd go for, for the price.
6,270 (0.92/day)
New York
Good catch! check this out>>http://www.playtool.com/pages/agpcompat/agp.html
it may help.
PS this card should have no issue with your board>>they go for around the same $ range.($74.99)>>http://www.newegg.com/Product/Product.aspx?Item=N82E16814102086
6,270 (0.92/day)
New York
the card i recomended
Looks like a good match to me.
Namslas90
4,846 (0.73/day)
Earth
6,270 (0.92/day)
New York
The Newegg link didn't work for me, but according to the playtool link he should be able to run a 1950 Pro AGP.(it's listed at the botom as a "universal" card.)
:toast:
link fixed....problem with the 1950 Pro is they are three times as much as his price pick.
585 (0.09/day)
The Batcave
System Name Meatwad
Processor AMD Ryzen 2700
Motherboard Asrock Fatal1ty x370 itx
Cooling Noctua NH-L9x65
Memory G.Skill RipJaws 2x8GB DDR4 2666
Video Card(s) MSI Radeon RX580
Storage Mushkin 1TB SSD, Seagate Barracuda 2TB HD
Display(s) Asus 23" VC239
Case I still need one
Software Linux Mint
43,599 (6.55/day)
Motherboard ASUS TUF x670e
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
Sweet card!:D:rockout:
5,197 (0.74/day)
Kansas City, KS
System Name Dell XPS 15 9560
Processor I7-7700HQ
Memory 32GB DDR4
Video Card(s) GTX 1050/1080 Ti
Storage 1TB SSD
Display(s) 2x Dell P2715Q/4k Internal
Case Razer Core
Audio Device(s) Creative E5/Objective 2 Amp/Senn HD650
Mouse Logitech Proteus Core
Keyboard Logitech G910
Don't worry about AGP voltage/etc.
Anything marked 4x or 4x/8x will work fine.
That means anything newer than a Geforce 256 will be compatible.
So, unless you're looking for a pre-geforce 256 era card, anything should work fine. :)
I would suggest a 9700pro/xt or a 9800xt/pro, or as suggested abovce, the 1650 should do well too. An x850xt would probably cost too much, but would work too.
Namslas90
4,846 (0.73/day)
Earth
Yes, DRDNA confirmed that any of the newer AGP "universal" cards will work on his mobo.
:toast:
ClarkColeman
10 (0.00/day)
What does it mean that my motherboard manual says "AGP 8X (1.5V only)" and every online source says that AGP 8X is actually 0.8V signaling, while AGP 4X is 1.5V signaling?
Every AGP card you can buy online these days says "AGP 8X". Does that not imply 0.8V signaling? What assurance would I have that an AGP 8X 0.8V card would work in a motherboard that explicitly says "1.5V only"?
I am guessing that Asus means that their AGP slot requires 1.5V slotted cards, NOT that they have to signal at 1.5V. There is no difference in the slots for AGP 8X and AGP 4X that I can find online, so the slot/notch design and the signaling levels are (slightly) separate topics when we get to AGP 8X.
ClarkColeman
10 (0.00/day)
I guess the related question is: Should I buy a new motherboard or new video card? My problem is that playing a video file (*.wmv, *.mpg, *.mp4) on any media player freezes the system. Updating the motherboard BIOS did not help. Experimenting with every archived ATI Radeon driver available did not help. Reinstallling Windows XP from scratch does not solve it. DirectX Diagnostics (DXDIAG) says everything passes. Various downloaded video stability tests manage to rotate objects on the screen with no problem. Installing and uninstalling codecs makes no difference. Turning off 3D acceleration solves the problem, but then I will drop lots of frames if I try to capture from a camcorder, for example. Trying different media players does not prevent the freezes, which occur as soon as the video starts playing. The only differences are that some releases of ATI drivers allow you to kill the frozen media player from Task Manager, while others require you to hit the Reset button on the PC.
If you Google "ATI Radeon 7000" and "freeze" you will find lots of people asking about similar problems on forums, but never getting a solution. Lots of speculative replies from people trying to help them, but no silver bullet.
I am wondering if it is possible that I will buy a new video card and still have the problem, in which case I will now have a new video card that was not necessary. I could buy a new motherboard and transfer lots of old peripherals to the system without spending a fortune.
Namslas90
4,846 (0.73/day)
Earth
That Mobo is kinda "dated", A newer one would'nt be a bad Idea. :toast:
5,197 (0.74/day)
Kansas City, KS
Processor I7-7700HQ
Memory 32GB DDR4
Storage 1TB SSD
Case Razer Core
I would suggest *trying* a different gpu before you purchase.
If you can't obtain one, theres always the restocking fee :ohwell:
6,270 (0.92/day)
New York
Your issue is not your graphic card here!download VLCPLAYER>>http://www.videolan.org/vlc/download-windows.html install and right click on video file and select open with then choose VLCPLAYER and report back if the video plays..if it does its a system codec fubar.ALSO DO NOT use any thing higher than the 6.11 cats...and what OS are you using??????
ClarkColeman
10 (0.00/day)
That media player freezes instantly just like all the others.
Windows XP Home Edition, SP2 with all updates. Fresh install of OS does not help.
6,270 (0.92/day)
New York
Post list of all running processes plz.
