Ai Crystal
21 (0.57/day)
System Name Ai Crystal
Processor 9950x
Motherboard Asus ROG Strix X670E-E Gaming Wifi
Cooling EK Nucleus AIO black version 360mm
Memory G.skill TridentZ5 48GB 7600MHz 36-45-45-45
Video Card(s) MSI Gaming X Trio RTX 4090 @ 3155/12205MHz
Storage Crucial T700 1TB Nvme PCI-E 5, WD platters
Display(s) Acer Ultrawide 3440x1440 HDR400 FreeSync 144Hz
Case anidees Ai Crystal AR3 midtower
Audio Device(s) Logitech Z-2300, Logitech G332
Power Supply Superflower Leadex VIII XG 1300w Gold
Mouse Cooler Master Mastermouse MM520
Keyboard many, currently YUNZII YZ98 96%, Kailh Box Summer switches
Software Windows 11, Linux Mint
Benchmark Scores http://hwbot.org/user/neurotix
Here's my build log for the house's main rig, Ai Crystal. Usually kept on 24/7.
Primary use case scenario: Linux file server
Secondary use case scenarios, in order of importance:
- Folding rig (it costs around $40 a month to fold 24/7, and I had no clue when I got my 4090 how good it would be at folding)
- Graphic design rig using GIMP, which I can do while folding and having the file server online IF I turn my GPU OC off
- Benching rig in Windows for HWBOT
- Gaming rig, waiting on expansions for Forza Horizon 5
Until the end of 2022, the rig was running a ROG Crosshair VIII Hero, Ryzen 9 3900x, Arctic Liquid Freezer II 360mm AIO cooler, G.skill Flare X DDR4 3200 cas 14 @ 3800MHz 16-16-16-16-32-50 1T GDM on, and 2x EVGA FTW3 GTX 1080ti in HB SLI. Here is the full parts list for it now.
Ryzen R9 9950X, eclk overclock boost to 5850MHz
ASUS ROG Strix X670-E Gaming
G.skill TridentZ5 DDR5 7600MHz cas 36-45-45-45 1T GDM on
MSI Gaming X Trio RTX 4090 3135/12210MHz
EK Nucleus AIO CR360 Dark w/ Prolimatech PK3-Nano
Crucial T700 1TB PCI-E Gen 5 M.2 drive. 800GB for Windows, 200GB for Linux
WD Black 2TB
WD Blue 4TB
WD Blue 6TB
Case is anidees Ai Crystal AR3 Midtower
Fan and RGB controller is the anidees one that came with the case
Fans are 7x anidees AI AUREOLA v3 RGB fans
2x anidees RGB light strips, 2x Phanteks RGB light strips
Superflower Leadex VII Gold 1300w power supply
I think that's everything for the box.
Accessories:
Monitor Acer EI342CKR Pbmiippx Curved 3440x1440p 144Hz FreeSync HDR 400 (supposedly) Ultrawide
Logitech G332 Headset
Logitech Z2300 Circa 2007 2.1 THX certified speakers. 120w 8" subwoofer, two 40w Satellites
Cooler Master Mastermouse RGB
Utechsmart "RGB" large cloth mousepad (Amazon)
Kontrol Freek gaming lights for desk/monitor backlighting
Keyboards:
E-Yooso Z-88 modded, stock had Outemu Blue switches. Modded to Kailh Box Whites, WASD blue o-rings, blue and white PBT keycaps, stabilizers clipped and lubed, case packed with thin crafters foam to give it more weight, has Doraemon stickers (main board) It's RGB as well.
Glorious GMMK v2 fullsize, Kailh Box Jades, WASD blue o-rings, custom white plastidip and plastidip pearlizer layer on top, genuine Filco Sakura keycaps, stabilizers clipped and lubed, case packed with thin crafters foam, put a small flat metal weight inside.
Keychron K8 Pro Aluminum Black, Kailh Box Navy Switches, Blue O-Rings, custom Classic Muscle Car Plum Crazy plastidip, Great Wave Off Kanagawa keycaps
I have a couple more keyboards I've built/modded since I originally made this same post at ExtremeHW.net.
I think that's everything. Now for the gallery.
21 (0.57/day)
Processor 9950x
21 (0.57/day)
Processor 9950x
21 (0.57/day)
Processor 9950x
Also, bonus. Here's two pictures of my test bench for Hwbot I recently set up in the unfinished area of my basement:
