AIO cooler 120mm
120 (0.75/day)
System Name [ JUNE_2024 ]
Processor LGA1700 i5-12600K / 3.7Ghz / 10 cores
Motherboard Asus Prime Z790M plus D4
Cooling Abysm Snow 4 Duo120mm
Memory Kingston Fury Beast 2x16Gb DDR4-3600
Video Card(s) Asus RTX 4070 Dual white 12Gb
Storage M2 Corsair MP600 CoreXT 1Tb
Display(s) Hisense 32" TV @ 1080 / 60Hz
Case Cooler Master Q300L black
Audio Device(s) Sennheiser HD 599 SE
Power Supply Corsair RM 750w Modular white
what is the best AIO water cooler 120mm under 60€ ???
it must be white kit and no RGB on the fan !!!
12,337 (5.79/day)
Midlands, UK
System Name Nebulon B
Cooling be quiet! Dark Rock 4
Mouse Logitech MX Master 2S
Keyboard Logitech G413 SE
Forget a 120 mm AIO, they're all rubbish. A good tower that costs half the price runs miles around all of them.
9,034 (3.32/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
Just get a 240mm from Thermalright. It will probably be cheaper too than what you are looking to pay.
dgianstefani
TPU Proofreader
5,004 (1.99/day)
Swansea, Wales
System Name Silent
Processor Ryzen 7800X3D @ 5.15ghz BCLK OC, TG AM5 High Performance Heatspreader
Memory 32 GB Dominator Platinum 6150 MT 26-36-36-48, 56.6ns AIDA, 2050 FCLK, 160 ns tRFC, active cooled
Case Sliger SM570 CNC Aluminium 13-Litre, 3D printed feet, custom front, LINKUP Ultra PCIe 4.0 x16 white
Power Supply SF750 Plat, full transparent custom cables, Sentinel Pro 1500 Online Double Conversion UPS w/Noctua
Mouse Razer Viper Pro V2 8 KHz Mercury White w/Tiger Ice Skates & Pulsar Supergrip tape
Benchmark Scores Legendary
3,493 (1.84/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 220W PPT limit, 80C temp limit, CO -6-14, +50MHz (up to 5.0GHz)
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3667MT/s 1.42V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (375W current) PowerLimit, 1060mV, Adrenalin v24.10.1
Case None... naked on desk
Software Windows 11 Home 64bit (v24H2, OSBuild 26100.2161), upgraded from Win10 to Win11 on Jan 2024
You either go for a 240/280mm or an air tower.
For under 60€ you better go air.
For AIOs on a budget with nice performance you can look for ArcticLiquid III 240/280mm (nonRGB).
In my region those cost 65~75€.
9,034 (3.32/day)
Cooling In Win SR36
Absolutely do not buy a 120 mm AIO, or even an AIO at all for a 12600K.
Get a Thermalright or a Noctua tower cooler.
If the OP is looking for an AIO why would you recommend an Air cooler. Then you put Noctua who may have performance but are not cheap. His case may be too small for the Peerless as well.
This is 40 Euros when converted and White to boot. It comes with the fans pre installed and has one of the easiest mounting procedures as well.
Toothless
Tech, Games, and TPU!
9,573 (2.46/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x32 Corsair Dominator
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
But OP is looking for a 120mm and you linked a 240mm. What if they can't fit the 240?
An air cooler would work better than a 120 AIO and be cheaper.
120 (0.75/day)
im worried of the heat from radiator onto gpu exposed chip... do all gpu have this aproximity problem with cooler?
the gap is less that my pinky finger !!!
i mentioned 120mm to mount at the rear mesh of the case because the top mesh of case is not deep enough for thickness of radiator + fan, im afraid... plus, the dust gravity?
- got 2 fans on the front of case pushing in fresh air to all components.
Toothless
9,573 (2.46/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
i mentioned 120mm to mount at the rear of the case because the top of case is not deep enough for thickness of radiator + fan... (lot of space for pump on the cpu) got 2 fans on the front of case pushing in fresh air to all components... and no, my case does not allow to turn my GPU 90 degrees and let it vent from side panel of plexiglass.
Your GPU will be 100% fine as is.
120 (0.75/day)
:D its pretty / looks cool to see the guts of the GPU when not covered, but why do they exposed electronics on that specific spot, knowing air-cooler towers exist LOL :laugh:
...and mine is not a RTX Ti model, so no Titanium plate here to protect chip :(
Fail Tom Hiddleston GIF
dgianstefani
TPU Proofreader
5,004 (1.99/day)
Swansea, Wales
System Name Silent
No GPU has a titanium plate...
And that isn't the chip, it's some surface mounted components on the backside of the PCB.
Literal non issue.
Toothless
9,573 (2.46/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
As dgianstefani said, the chip is on the other side being cooled properly. This is a non-issue completely.
Pretty sure if this was an issue then hundreds of cards would be fried by that little spot not getting air. Your card and next card or even a 4090 do not need cooling on the back of the core.
120 (0.75/day)
thank you guys to apease my worry.
9,034 (3.32/day)
Cooling In Win SR36
I looked up the case the OP has and it supports 240 Rads on the front. As it only supports 120mm fans I was worried about the size of the Air cooler that was also recommended.
1,520 (2.32/day)
France
System Name KLM
Motherboard B-650E-E Strix
Video Card(s) 4070-ti PNY
Case 4000D Airflow
Power Supply Shift 1000
Mouse 502 Hero
Keyboard K68
Software EMDB
Benchmark Scores 0>1000
Toothless
9,573 (2.46/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
Thermalright has a shorter dual tower air cooler that would work too. OP also already has a tower air cooler installed.
3,493 (1.84/day)
Those are capacitors for the GPU voltage feed to handle transients. Believe me, those components are getting cooled from CPU air tower or whatever air is going around there. The GPU on the other side is heating them up way more than the air on that side.
120 (0.75/day)
thanks so no AIO needed, ok!
topic closed
freeagent
8,456 (3.76/day)
Winnipeg, Canada
Processor AMD R7 5800X3D
Display(s) LG 50UP7100
Case Fractal Torrent Compact
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
Only because there is no offset built in. I have a couple of older coolers that are like that.. pretty tight.
1,965 (0.62/day)
Processor Intel i5 8400
Storage 1TB 980 Pro
Software W11 Pro
Top mounted 150mm fan on my low profile cooler sits against the gpu backplate. So far as I'm concerned that is somewhere between ideal and inconsequential.
