aio cpu temp keeps spiking
400 (0.22/day)
to start I have a 3600 and my aio is ml240 RGB v2 by cooler master I have a slight overclock to 4.2 GHz and I noticed when like on chrome my MSI afterburner max temp is 65 is that ok also it spikes while gaming whatever temp then slowly goes down then spikes
400 (0.22/day)
ok and when streaming at 1080p 60 fps with uncapped in game fps with max graphics I get like 80 should I be worried btw I use x264
3,896 (1.93/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 220W PPT limit, 85C temp limit, CO -8~14, +50MHz (up to 5.0GHz)
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3600MT/s 1.38V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~467W (382W current) PowerLimit, 1060mV, Adrenalin v24.12.1
Case None... naked on desk
Software Windows 11 Home 64bit (v24H2, OSBuild 26100.3037), upgraded from Win10 to Win11 on Jan 2024
How much voltage for that 4.2GHz?
400 (0.22/day)
i never changed the voltage
i just set clock to 4200
my friend did it not me but he didn't touch the volts
3,896 (1.93/day)
If you like download HWiNFO and open sensors window in full view. Minimize it to systray an leave it there for a few hours and use you PC. Then post a screen shot here.
Like this
3,896 (1.93/day)
Not that, the sensors window. You must close this, re-open HWiNFO and select sensors only mode. Enlarge the window and use blue arrows to the bottom to expand colums and to show as many sensors as possible.
4,535 (0.81/day)
Denmark
System Name The work PC /2700x/5950x
Processor 3900X stock/ 2700x stock/ 5950x 4200 MHz fixed @ 1,056-1,08V
Motherboard Gigabyte AORUS Master X570/2xMSI X470 M7 AC
Cooling Custom WC XSPC RX480, Laing DDC, XSPC Laing DDC Top V3 and EK Velocity/NH15/NH-U12S SE
Memory 32 GB Viper 3600/14 /16 GB Trident Z F4-4000C18D-16GTZSW 3600 /32 GB G Skill Flare CL14 3400
Video Card(s) 2070 Super X MSI/GTX 970 MSI/ GTX 970 MSI
Storage 1 TB SSD+500 GB NVMe / 500 GB SSD/ 2 TB 990 Pro
Display(s) Dell UltraSharp U2518D/2408WFP
Case Corsair 800D / Lian test bench/NZXT 500
Power Supply AX 850 Titanium/AX 860i/AX 760
Software Dual boot/Win 10 / Linux / Win 10+Linux
@Zach_01 I will leave this to you but just point out the RAM speed is 2133 :D.
3,896 (1.93/day)
Look closer down below...
Says, Clock memory: 1800MHz
What you saw is the type 2133 nonXMP profile.
Here is mine:
4,535 (0.81/day)
Denmark
Right you are. I opend HWINFO once in the non-sensor mode so....
3,896 (1.93/day)
As I thought...
The voltage is on a fix setting around 1.35V
See the:
"CPU Core Voltage (SVI2 TFN)" in the middle where the red dot is.
It may be too much for certain work loads.
If you want my opinion, to OC this CPU is not worth the trouble and the risk. Just for 5% more clock on allcore load.
Anyway (ON topic), the temp spiking thing is normal for the "CPU (Tctl/Tdie)" sensor value. All ZEN2 have this behaviour OCed or not. This sensor reports always the highest point inside the cores aka: the Hotspot. All ZEN have dozens of temp sensors inside each CCD and the Tctl/Tdie report always switching to report the highest sensor.
The "CPU CCD1 (Tdie)" value is a report of 1 specific sensor on a specific place inside the cores. Its more steady than Tctl/Tdie. Past generations of AMD CPUs report only 1 temp and that was a CPU CCD (Tdie) equivalent.
This jumpy Tctl/Tdie (hotspot) report was firstly introduced by AMD on ZEN2 and RDNA1 GPUs.
sneekypeet
not-so supermod
29,698 (4.29/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
This thread is confusing AF.
Title says CPU spikes, OP says his card temp. Continues discussing card temps while everyone is trying to help with a non-existent CPU temp issue.
4,535 (0.81/day)
Denmark
I think that you got it wrong. x264 and GPU? MSI shows CPU temps as well FYI.
sneekypeet
not-so supermod
29,698 (4.29/day)
System Name EVA-01
4,535 (0.81/day)
Denmark
See my edit. OP didn't use or didn't know how to use HWINFO before now.
sneekypeet
not-so supermod
29,698 (4.29/day)
System Name EVA-01
Hw info shows 70c, I just think OP is confusing everyone. I know it will show CPU, but you also assume he knows how to work that but not HWINFO? These apps are not rocket science.
Deleted member 193596
do you have all latest chipest drivers installed and the ryzen power plan on balanced?
then will appear a slider which can be put to maximum energy saving (has no influence on performance but the vcore stays at around 1.1v even under light load without aggressive core waking for opening a browser)
4,535 (0.81/day)
Denmark
Sure, OP needs to perform a standard test to obtain a value that we can evaluate. But as @Zach_01 wrote OP should drop the OC and live with the fact that a 3600 will spike.
834 (0.44/day)
Maryland, USA
Processor Ryzen 5 5600X
Motherboard MSI MPG X570S Carbon Max Wifi
Cooling CPU: bequiet! Dark Rock 4. Case fans: 2x bequiet Silent Wings 3 140s, 2x Silent Wings 3 120s
Memory 2 x 8 GB Patriot Viper Steel DDR4-4400 C19
Video Card(s) Sapphire NITRO+ RX 5700 XT
Storage 2TB Mushkin Pilot-E M.2, 1 TB SK Hynix P31 M.2, 1 TB Inland Professional, 500 GB Samsung 860 Evo
Display(s) MSI Optix MAG271CQR 1440p 144Hz, MSI Optix MAG241C 1080p 144Hz
Case Lian Li Lancool III
Audio Device(s) Philips SHP9500, V-Moda BoomPro, Sybasonic Better Connectivity USB DAC/Amp
Power Supply EVGA SuperNOVA G3 80+ Gold 750W
Mouse Glorious Model D Wireless
Keyboard Custom Qwertykeys Navy QK80: Sarokeys Strawberry Wine switches, GMK CYL DMG3 keycaps
Good catch, I think OP is confusing his CPU and GPU temps.
As @sneekypeet mentioned, max temp for CPU is shown as 70C in hwinfo. MSI Afterburner is measuring GPU temps. Depending on what 5700 XT model he has, it's not unheard of for it to hit 80C while gaming with uncapped FPS and streaming.
4,535 (0.81/day)
Denmark
Please "experts" open MSI Afterburner and see that it does CPU as well.
sneekypeet
not-so supermod
29,698 (4.29/day)
System Name EVA-01
Don't misunderstand me, I'm not saying anyone is wrong, just that things are not lining up, and without an AB screen shot in the OP, we are all left guessing still.
1,203 (0.27/day)
Denmark
Processor R9 5950x/i5 6400
Video Card(s) 7900XTX/6900XT
Case Custom builds
Audio Device(s) -
Just did af MSI B450 Mortar Max build with Artic Liquid Freezer II 360 build in the Lian Li Lancool - with an 3600x and a Gigabyte Gaming OC 2070 super. it never went above 65 c - did a 8 ours burn in with the CPU-z stress test and the cores never came belove 4225MHz. During gaming and test it was impressive silent. It was set to 1900MHz Infinity fabric and 3800MHz memory, CL 14 timings, with PBO enabled.
