Air Cooler for i7-10700k
Serial42
1 (0.00/day)
I don't know which air cooler to choose for my new build. The i7-10700k will be stock (no OC).
I love Noctua and I wanted to head on NH-U12S chromax, but I'm afraid it is too low. The higher range will be NH-D15S chromax.
I'm just worried that by its size it hides the rest of the setup because I have not RGB fans.I wanted to stay sober with a black build and only have a few RGB elements (motherboard, graphic card, RAM).
The rest of the build :
Motherboard : ASUS ROG STRIX Z490-E Gaming Graphic card : MSI RTX 3080 SUPRIM X 10G Memory : Corsair DOMINATOR® PLATINUM RGB 16GB (2 x 8GB) DDR4 DRAM 3600MHz C18 SSD : Samsung 970 EVO Plus NVMe M.2 SSD 1TB PSU: : Corsair RM850x Fans : 3 x NF-A14 PWM chromax Case : Fractal Design Meshify 2 Clear TG Black
I chose this motherboard for its style and its RGB elements, but if I have to put a big air cooler, it will be a mess :/
2,292 (1.22/day)
System Name GrandadsBadAss
Display(s) Acer XG270HU
Keyboard Roccat Vulcan Aimo
Software Win 10/11pro
For a stock clocked 10700k itll be fine.
18,584 (2.65/day)
System Name AlderLake
Deleted member 202104
I run a 10850k on stock clocks, but power limits removed. The NH-U12S with a second fan added keeps it at 50-60c during gaming, and it will touch 80c on multiple Cinebench multi-core runs.
Unless you're planning on running 100% CPU load 24/7 in a hot room, it should be just fine with a 10700k.
8,101 (1.33/day)
Hillsboro, OR
System Name Main/DC
Processor i7-3770K/i7-2600K
Audio Device(s) on board
Welcome to TPU!
Then why pay for a "K"?
Other coolers to consider:
be quiet! Pure Rock 2
Scythe Fuma 2
You might even want to step up to the 10900K (Newegg)
Welcome to TPU!
Scythe Fuma 2
Or save another $45 (BestBuy)
9,781 (2.16/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Mouse Logitech G502 spectrum
i grabbed a noctua NH-U12S chromax for $60 on amazon a while back. its a great HSF, & its almost as good at cooling as the h110GTXi it replaced. its overkill if youre just running stock, but you'll be able to re-install it on future builds as long as they are compatible.
498 (0.25/day)
For stock I would just get something like an artic freezer 34 for $30 to 35 bucks. Good balance of cooling and low fan noise.
