Air cooler for Ryzen 5800X
79 (0.02/day)
Ukraine
Processor Ryzen 7 7700X
Motherboard Asus ROG Strix X670E-F Gaming WiFi
Memory F5-6000J3038F16GX2-FX5
Hello there, I'm thinking of buying a 5800X CPU, but I will need a cooler for it.
Everybody knows that coolers have troubles dealing with Ryzen 3000 & 5000 since those processors' cores are really small and they manage to get red-hot faster than they manage to pass the heat to the cooler. Moreover, they're located in a specific way which also makes them harder to cool.
I can buy a Noctua NH-D15, but is it worth it when it comes to cooling a 7 nm processor? I mean, it's not as efficient with it as it is with 14 nm processors because of the cores size.
I don't plan to manually overclock my CPU, but if my CPU cooler is able to also manage something like a 5900X - it will be a pleasant bonus, but it's not a must, especially if my CPU cooler won't be expensive. But again - I can spend the price of a Noctua NH-D15 if it's absolutely worth it.
So please help me choose. Thank you for your time.
486 (0.16/day)
Processor Intel i7 4770k
Motherboard ASUS Sabertooth Z87
Cooling BeQuiet! Shadow Rock 3
Memory Patriot Viper 3 RedD 16 GB @ 1866 MHz
Video Card(s) XFX RX 480 GTR 8GB
Storage 1x SSD Samsung EVO 250 GB 1x HDD Seagate Barracuda 3 TB 1x HDD Seagate Barracuda 4 TB
Display(s) AOC Q27G2U QHD, Dell S2415H FHD
Case Cooler Master HAF XM
Audio Device(s) Magnat LZR 980, Razer BlackShark V2, Altec Lansing 251
Power Supply Corsair AX860
Mouse Razer DeathAdder V2
Keyboard Razer Huntsman Tournament Edition
Have you considered Arctic Freezer II 240 mm AIO? It costs the same but it's going to do a better job at cooling, it also performs better than most of other AIOs at same sizes. I found it for $100 on Amazon, same as NH-D15. You have to be careful about fitment though, it probably has the thickest radiator of all AIOs (38 mm thick). I'd suggest an AIO over air cooling for 5800X because of its 105W TDP. Also pretty sure it can keep 5900X cool as well.
834 (0.44/day)
Maryland, USA
Processor Ryzen 5 5600X
Motherboard MSI MPG X570S Carbon Max Wifi
Cooling CPU: bequiet! Dark Rock 4. Case fans: 2x bequiet Silent Wings 3 140s, 2x Silent Wings 3 120s
Memory 2 x 8 GB Patriot Viper Steel DDR4-4400 C19
Video Card(s) Sapphire NITRO+ RX 5700 XT
Storage 2TB Mushkin Pilot-E M.2, 1 TB SK Hynix P31 M.2, 1 TB Inland Professional, 500 GB Samsung 860 Evo
Display(s) MSI Optix MAG271CQR 1440p 144Hz, MSI Optix MAG241C 1080p 144Hz
Case Lian Li Lancool III
Audio Device(s) Philips SHP9500, V-Moda BoomPro, Sybasonic Better Connectivity USB DAC/Amp
Power Supply EVGA SuperNOVA G3 80+ Gold 750W
Mouse Glorious Model D Wireless
Keyboard Custom Qwertykeys Navy QK80: Sarokeys Strawberry Wine switches, GMK CYL DMG3 keycaps
What is worth it for you can't be decided by us. You could spend less money and get something not as good as the NH-D15, but it might come at the cost of higher thermals and noise levels. What are you using the system for? If it's workstation-focused and you're planning on hammering it with sustained multicore workloads all the time, than opting for a more expensive cooler is probably the way to go. If you're just building a gaming rig, you could probably get away with something a little more budget-friendly since you're likely not putting as much load on the CPU. It's worth noting that AMD's boost algorithms take advantage of cooler temperatures. The cooler your CPU is, the higher it will try and push the frequency.
I agree with Night. The Arctic Liquid Freezer line is a great bang for the buck option when compared to other AIOs. In terms of pure cooling potential, an AIO takes longer to reach steady state and keeps temperatures lower than air coolers. However, that tends to come at the cost of greater potential for failure (leak, fluid evaporation, air in the pump, etc.), whereas with air coolers, all you really have to worry about is the fan failing, which is easily replaceable for a lot less money.
We don't know what case you have, what your motherboard clearances look like, how tall your RAM is, etc., so it's difficult to make a recommendation.
Fill out your system specs here to make everyone's life a little easier: https://www.techpowerup.com/forums/account/specs
540 (0.12/day)
Processor AMD Ryzen R7 5800x
Motherboard B550i Aorus Pro AX
Cooling Custom Cooling
Memory 32Gb Patriot Viper 3600 RGB
Video Card(s) MSI RTX 3080 Ventus Trio OC
Storage Samsung 960 EVO
Display(s) Specterpro 34uw100
Case SSUPD Meshlicious
Power Supply Cooler Master V750 Gold SFX
Keyboard Ducky One 2
VR HMD Quest 2
Software Windows 11 64bit
I'm using the 5800x and an ID-Cooling SE234 and it gets to 90C at auto. By default, these processors really like to be cool and boost until they get to 90C then throttle the clocks from there. I just fiddled with Curve Optimizer and the PPT/EDC to make it decent.
I cant compare it to an AIO since I cant fit one in my case but I guess it will be heaps better.
SL2
2,495 (0.36/day)
If you want to save some money without getting lower performance you should check out Zalman CNPS20X. $20 lower in the US, €15 lower in europe.
GN is trying to downplay it due to some old beef they've got going on with Zalman (who is the one to blame), but the numbers don't lie (even though GN's verdict basically does). It's high performing cooler.
3,023 (2.04/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~2000 Video Games
you can basically put everything you want on it.
the problem is not the amount of heat. it's the insane density and awful heat transfer from the cores.
the mass of a heatsink is almost irrelevant. (my 5800X runs at 85°C with a 360 AIO and a small 120mm tower cooler)
but just don't buy any asetek AIO for a Ryzen CPU (convex coldplate and IHS makes barely any contact)
CoolIt AIOs are pretty decent or a NH D15. (for headroom with overclocking. a 5800X can pull almost 200W)
167 (0.11/day)
USA
Processor 5800x3D
Motherboard x570 Extreme 4
Cooling Deepcool AK620 Digital
Memory 2x16 Steel Viper 3600 Mhz
Video Card(s) 4070 SUPER FE
Storage 500 GB WD SN750 / 870 Evo 500 GB / Kingston 480 GB SSD
Display(s) Alienware 34 aw3418dw / ROG Swift pg27q
Case Corsair 3000D
Power Supply Seasonic V3 1000w
Mouse Model O
Keyboard GMMK Pro w/ SP Magic Girls
Software WIndows 10 Pro
Shadow Rock 3 is rated for 190w and is half the price of the D15. Check it out!
1,814 (0.33/day)
Azalea City
System Name Main
Processor Ryzen 5950x
Motherboard B550 PG Velocita
Cooling Water
Memory Ballistix
Video Card(s) RX 6900XT
Display(s) MAG401QR
Case QUBE 500
Audio Device(s) Logitech Z623
Power Supply LEADEX V 1KW
Mouse Cooler Master MM710
Keyboard Huntsman Elite
Software 11 Pro
I run my wife's 5800x with an old Cooler Master TPC-612. With stock mobo settings it turbos up to 4.85GHz and runs about 70C during AVX FPU stress tests in a crowded Phanteks P400A. During her 4K Vahalla game it runs around 50C. She's getting a 360 AIO this week so we'll see if it improves, but I doubt it.
79 (0.02/day)
Ukraine
That's exactly why I want an air cooler.
Although it's not that much about money saving for me in this particular case (I can spend those 100 US dollars if needed), AFAIK air coolers can be more or less equal at their mediocrity when it comes to handling a 7nm processor, so if it's only about 1-2°C (at full load) and I can save some bucks - it's not the worst of ideas not to pay for an expensive cooler. I mean, it's more about price-to-performance for me and I don't want that much to overpay for only a slight win.
As for how I use my PC - it's for entertainment, including games. And since I'm not an overclocker, I will be OK with AMD's auto-overclocking features (what are they called - PB2? XFR2?).
1,203 (0.27/day)
Denmark
Processor R9 5950x/i5 6400
Video Card(s) 7900XTX/6900XT
Case Custom builds
Audio Device(s) -
I used the Noctua D15-SE before my artic 360 setup - but if you have the space - the Noctua D15 is great and will performe at par with the small AIO
AsRock
TPU addict
19,191 (2.97/day)
UK\USA
Cooling D15
A lot of cooler for around $60 ( Funa2 )
Don't get me wrong the NH D15 is a worthy cooler and able to keep my 3900X under 90c using Cinebench continuously running ( ambient being 31-33c ) it will give you a possible headache which is how close to the video card it be, how ever there is the Noctua NH-D15S version which leans further way from the GPU but only has one fan for about the same price.
freeagent
9,912 (4.21/day)
Winnipeg, Canada
Processor AMD R9 9900X
Cooling Thermalright Frozen Edge 360, 3x TL-B12 V2
Memory 2x16GB Lexar Ares @ 6000 26-36-36-68 1.45v
Storage WD SN850 1TB, SN850X 2TB, 3x SN770 1TB
Display(s) LG 50UP7100
Case Asus ProArt PA602
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
The new Frost Commander 140 from Thermalright is worth considering imo. Its got a silly name but it is a serious cooler. It outperforms my Le Grand Macho RT which directly compares to D15 in the TPU review, except I was using a TY-143 on mine. I don't think there any reviews on it yet, and I got mine from Aliexpress. I also own a True Spirit 140 Power, and I will never use both of those coolers on my 5600X again..
834 (0.44/day)
Maryland, USA
Agreed. Maybe I'll get an AIO one day just to give them a try but with so many of them being significantly more expensive for only a couple degrees cooler, it's often just not worth it when adding that on to the limited lifespan. Not to mention my 2600 doesn't need an AIO by any means - the Dark Rock 4 I have on there now is more than enough.
I'd take note of @weekendgeek's comment. Looks like the NH-D15 is only just keeping the multicore temps in check, and that's after dropping down to a 95W TDP mode. Granted, you won't be hitting the CPU like that when gaming, but I would guess that letting PBO and all that do their thing at 125W you'd be seeing higher than the reported 55-65C temps while gaming. Obviously there are other factors that come into play like case airflow, CPU cooler fan speed, ambient temp, etc. That said, you mgiht be able to get away with one of the midrange coolers like the Mugen 5, Shadow Rock 3, etc.
1,641 (0.98/day)
Do note that the Fuma 2's fans max out at rather low RPMs - while they're great for being silent it does mean that you lose the on-demand extra performance should you need/want that. Otherwise it is a great dual stack cooler. Something to keep in mind.
834 (0.44/day)
Maryland, USA
Thank you. I see a lot of people recommending the FUMA 2 without mentioning this caveat. However, given that OP isn't going to be overclocking and will likely be hanging around or sitting below the advertised 125W TDP of the 5800X, the FUMA 2 should be adequate.
You can see here the FUMA 2's fans are running at 1170 RPM and are maxed out (product page specs both fans at max 1200 RPM), while the NH-D15 still has approximately 500 RPM of headroom to play with (NF-A15s top out at 1500 RPM) to further increase performance. Granted, this is on a ~200W heat load which the 5800X shouldn't be anywhere near left to its own devices.
freeagent
9,912 (4.21/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
All cooling reviews should be taken with a grain of salt. You may get better results, or you may get worse. It depends on your setup and environment.
1,641 (0.98/day)
Actually the 5800X would probably behave the same if not worse since it still has higher thermal density than a 200W OC on a 3950X.
Deleted member 205776
5800X is the hottest running chip in the entire Zen 3 lineup, so good cooling is preferred.
If you want to go air cooling, a NH-D15 performs about the same as a 360mm AIO. Also comes with a tube of NT-H1 paste, 6 year warranty, free socket mount upgrades, quiet fan, and quality customer support. I'd say the premium is worth it, talking from experience. I can't recommend the Fuma 2 here as, while it is a great value for money cooler performing as good as the NH-D15 sometimes, once you start putting it on hotter and hotter chips, it starts to lose performance due to its size limitations.
If you want to go AIO, I can only recommend Arctic's Liquid Freezer II 280mm/360mm. Arctic recently extended the warranty to 6 years, and the radiator is 38mm thick as opposed to 25mm of most AIOs. The fans on it are also super good and quiet, and it is great value for money.
Of course, make sure you have clearance for either, and that your case is ventilated properly.
1,641 (0.98/day)
Yeah, no.
The biggest bottleneck of the FUMA 2 are by far its slow fans. The tower, while small doesnt contribute all that much to it. You can clearly see it performing quite competitively during noise-normalised tests. However, once you try to jam up the RPM you'll find that there's no headroom left so you're stuck at the 1,200 RPM cap there.
9,781 (2.17/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
i really like my new Noctua NH-U12A . its dead silent, & very capable. i can OC my 11700k over 5Ghz & it manages to stay under 75c
Yeah, no.
Guess I must've remembered it wrong, all I recall is the Fuma 2 not performing well on hotter chips.
3,039 (0.53/day)
MN
System Name Personal / HTPC
I'm rocking a Noctua NH-U9S with my 5900x.
When I'm transcoding the temps flirt with 90C. When heavy gaming the temps sit around 80C.
freeagent
9,912 (4.21/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
My last two coolers are great with older style CPUs.. and they do ok with 7nm but the CPU can still get pretty hot when overclocking. This new one handles it no problem.. If guys are worried about 125w over 8 cores, try 130w through 6 :D
Its the same cores, more power, less cores.. I know how hot these can get :laugh:
834 (0.44/day)
Maryland, USA
Yeah, they're agreeing with you, just pointing out that it's the low speed of the fans that are the issue, not the smaller tower size.
100% fan speed at ~200W instead of noise-normalized like I shared earlier:
NH-D15 runs 5C cooler. Whether that increase in noise (up to 44 dBa vs. the 34 dBa of the FUMA 2) and price is worth it is up to the buyer.
221 (0.10/day)
System Name Violet
Processor AMD Ryzen 5800X
Motherboard ASRock x570 Phantom Gaming X
Cooling Be quiet! Dark Rock Pro 4
Memory G.Skill Flare x 32GB 3400Mhz
Video Card(s) MSI 6900XT Gaming X Trio
Storage Western Digital WD Black SN750 1TB
Display(s) 3440x1440
Case Lian Li LANCOOL II MESH Performance
Mouse EVGA X15
Keyboard Corsair K95 RGB
Software Windows 10 64bit
An 5800x here with a Dark Rock Pro 4 and is not going to pass 77C with cinebench R20/23.
With gaming it is ~56C. All stock out of the box.
