Airflow or static pressure fans for front intake? Recommendations
zfz
2 (0.00/day)
It was my understanding that practically speaking, static pressure fans are preferred over airflow fans, especially because there's very little realistic scenarios where a fan isn't up against something--whether it's the mesh front of the case, heatsink, rat's nest of cables, drives, etc. That's why Noctua users say the NF-S12A is irrelevant, even as an exhaust fan unless it's an actual hole where the exhaust exhausts out of as opposed to mesh (they probably recommend A12x25 which is a versatile fan). So do airflow fans still have a place?
I looked at some brief names and besides the popular the Noctua A12x25, there's also Phanteks T30 which outperforms Noctua by a little and is slightly cheaper. At the budget side of things, there's the Arctic P12, which people complain it has a humming noise at certain RPMs, including at RPMs people probably run the case fans at. I saw a Tech Buyer's Guru video on case fans and he concluded the Scythe Kaze Flex as the best case fan both for 120mm and for 140mm yet it is rarely mentioned compare to the rest other named fans. I assume that the Kaze Flex is an airflow fan and the rest are static pressure fans and most people talking of fans probably use them for radiators where they will certainly yield results.
So are static pressure fans preferable on basically all situations for a PC build and airflow fans are more of a marketing gimmick? The fact that they produce higher CFM when there is obstruction doesn't necessarily mean they don't also produce higher CFM where there is no obstruction and a HVAC engineer actually said static pressure fans are strictly better for performance in nearly all cases. I don't think static pressure fans are even louder if you noise-normalize the performance, so curious if running static pressure fans at low RPM is better than using airflow fans. I am looking at cases like Lian Li Lancool II Mesh, Phanteks P500A, and Fractal Design Torrent which are airflow-focused cases that can utilize quite a bit of case fans and am looking for fans that offer best noise-normalized performance.
3,951 (0.60/day)
Northern Ontario Canada
Processor Ryzen 5700x
Mouse Mionix Naos Pro
Software W10 22H2 Pro x64
Fans a lot of times are personal preference. Color, rgb, size, noise, etc.
Look for something with bearings over bushings, look for a 5yr + warranty, look for something readily available, and tolerable noise.
Fans with higher static pressure are used more with liquid cooling rads. But if you like a set of particular fans then give it a shot. When it comes to a PC the end result is pretty close to negligable and trivial.
Where you get most o f your cooling performance in a PC is from rpm, a 1500 rpm fan pushes way more air than a 500rpm fan all other things considered equal. You can look at the fan affinity laws for this.
5,598 (1.02/day)
Gougeland (NZ)
System Name Cumquat 2021
It mostly comes down to how much resistance is the fan going to have pullin air in through the front, cases that have just a mesh front panel will have the least resistance but when you start adding in dust filters your going to increase that airflow resistance and cut down actual airflow so go for medium speed (1500~1850rpm) static pressure or higher speed airflow (2000~3000rpm) fans and it also comes down to how much fan noise can you put up with
