Akasa Announces OTTO IP68-rated Fan
47,229 (7.55/day)
Akasa, a leading provider of active cooling solutions, has announced the newest additions to their line-up of fans, the OTTO series of IP68 rated 120 mm case fans! The OTTO fans take their name from the swift, swimming otters, with the sleek, water resistant fan blades producing a high airflow to help with removing heat and dust from a computer system.
The fans use auto-industry ergonomic design to help smooth out bumps and vibrations that the fans will endure - the patented anti-vibration structure provides a perfect cushion between the mechanical fan blades and the reinforced fibreglass polymer frame. With an IP-68 classification, the OTTO is practically made for heavy-duty and industrial applications, easily able to sustain the harsher conditions in these environments. The removable frame is ideal for the maintenance and ease of cleaning of the computer system, allowing the life-span to be extended with proper care.
The OTTO series features a three-phase motor located within the fan housing, which provides smoother shifts between the electromagnetic slots, lowering vibrations in the fan and increases its efficiency and longevity. The patented anti-vibration structure along with the included tool-free mounting pins can only mean the most silent operation from a fan—virtually no audible vibrations with Akasa's OTTO series!
Akasa's OTTO SC12 has a Sickle-flow blade design, which produces a finely-tuned P-Q curve for optimising static pressure. This allows more airflow in concentrated spaces, perfect for radiators found in AIO liquid cooling and tower heatsink cooling. Dust and dirt will be unable to settle within these heatsinks, which improves its efficiency and maintenance time.
Akasa's OTTO SF12 has a S-Flow design, which produces better results when put inside a PC case. The P-Q curve is more optimised for airflow, pushing more air through the blades makes it perfect for either an intake or exhaust fan for a PC case. This maximises the performance of the fans, and ensures a healthy airflow within the system without compromising performance.
Pricing and Availability
  • The OTTO SC12 (AK-FN109) and OTTO SF12 (AK-FN110) start at £24.95/€25.95 (prices may vary by reseller).
  • The OTTO SC12 and OTTO SF12 are available to order throughout the UK and Europe.
Mussels
Freshwater Moderator
58,413 (7.95/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
Alright fan nerds, give us the goods on these
INSTG8R
Vanguard Beta Tester
8,042 (1.10/day)
Canuck in Norway
Case TT Kandalf L.C.S.
Mouse G502 Hero
Keyboard G19s
VR HMD Oculus Quest 3
Software Win 11 Pro x64
Aww my Noctua Industrials are only IS2 rated….
Mussels
58,413 (7.95/day)
Oystralia
Wait IP68
Does that mean i can use these as propellers, and/or a watercooling build that's actually under water?
7,520 (1.47/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 41
Wait IP68
IP68 does not mean being submerged under water all the time, it can hold up to certain amount of time(given by the manufacturer).
Either way submerged builds are done in mineral oil not water, then it doesn't matter at all.
6,060 (2.89/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
Ah, transformer oil builds, the buzz of early 2000's.
7,520 (1.47/day)
Rīga, Latvia
Software FEDORA 41
4,931 (0.74/day)
Hong Kong
Processor Core i7-12700k
Motherboard Z690 Aero G D4
Storage Plextor M10P 2TB
Display(s) InnoCN 27M2V
Case Thermaltake Level 20 XT
Wait IP68
IP68 also means they are both dust and liquid resistant.
So these could be useful if someone decided to put a PC in the kitchen /bathroom or something. Might be useful for heavy smokers as well.
Should keep the nasty stuff from gunking up the bearing.
1,897 (0.46/day)
Plus removable frame. Makes cleaning a whole lot easier. As someone who has his PC in a living room with open kitchen combo i can confirm that the dust sticks much better and even air compressor is often not enough to remove the smallest particles. Much less compressed air cans that do nothing.
1,444 (0.29/day)
[Formerly] Khartoum, Sudan.
System Name 192.168.1.1~192.168.1.100
Processor AMD Ryzen5 5600G.
Motherboard Gigabyte B550m DS3H.
Cooling AMD Wraith Stealth.
Memory 16GB Crucial DDR4.
Video Card(s) Gigabyte GTX 1080 OC (Underclocked, underpowered).
Storage Samsung 980 NVME 500GB && Assortment of SSDs.
Display(s) ViewSonic VA2406-MH 75Hz
Case Bitfenix Nova Midi
Audio Device(s) On-Board.
Power Supply SeaSonic CORE GM-650.
Mouse Logitech G300s
Keyboard Kingston HyperX Alloy FPS.
VR HMD A pair of OP spectacles.
Software Ubuntu 24.04 LTS.
Benchmark Scores Me no know English. What bench mean? Bench like one sit on?
Lol! Submersion resistance in a computer case fan!
If water came anywhere near my computer, the last thing I'd worry about would be the bloody fans!
In addition to Ferrum Master's remark, there's also the question of: Why would you need a fan underwater, err, under oil?
If -for some reason- one needs to create currents in your tank, fans would be a bad choice. Their blades aren't designed to push dense/viscous liquids, but more importantly -since we're talking about packaged units here- their motors can't handle the increased power requirement. Heck! At [quickly checks Google] ~700% the density and ~4000% viscosity, I wonder if they'd spin at all!
1,302 (1.10/day)
Thailand
System Name Shoebox
Processor 3600x
Motherboard Msi b550m Mortar +WiFi
Cooling Cryorig m9
Memory Crucial Ballistix c16 B-die 2x8gb
Video Card(s) Powercolor rx570 4gb
Storage WD black sn750 256gb (OS), crucial mx500 1tb(storage),Hitatchi ?? 7200rpm 500gb(Temp files)
Display(s) Samsung 65" TU7100
Case Zzaw b3
Audio Device(s) Yamaha rx-v363
Power Supply Corsair sf750
Mouse Logitech g300s
Keyboard Custom Skyloong sk64s
Software Windows 11Pro
Hmm might be a good fan for my current idea floating around in my head of fitting a server rack between the treads of our stairs(coolest place on a very hot house)
Mussels
58,413 (7.95/day)
Oystralia
Get your logic out of my submarine PC build
2,342 (1.15/day)
Olympia, WA
System Name Sleepy Painter
Processor AMD Ryzen 5 3600
Video Card(s) MSI RX580 8GB
Case NZXT Gamma Classic Black
Audio Device(s) Asus Xonar D1
Mouse Logitech MX518 Legend
Keyboard Red Dragon K552
IP68 in simple layman's terms: you can install and use these as window fans or bathroom vent fans.
In industrial usage, I'd image they expect to see incidental low-temp steam, atomized water, or cnc-coolant droplet exposure, during manufacturing-cleaning-finishing.
