- Oct 9, 2007
- 47,189 (7.56/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
With the Eisbecher Aurora reservoir in combination with the VPP Apex pump, Alphacool presents another stylish reservoir/pump combination. The combination of the classy Eisbecher with the elegant, powerful VPP Apex D5 pump results in a setup that should not be missing in any performance-oriented water cooling system.
The tube of the reservoir is made of real glass. The digitally addressable RGB LEDs in the pump top provide brilliant illumination and beautiful light reflections. A special ambient highlight is the illuminated fountain effect of the riser tube. The Apex VPP is a powerful pump that is compatible with the most popular D5/VPP tops and reservoir tanks. With the 4-pin fan connector, the speed of the pump can be read and controlled by PWM signal. Power is supplied to the Apex VPP via the SATA connector. The maximum head of 4.25 m and the potential flow rate of 340 L/h are clear arguments for using the pump in combination with the Eisbecher Aurora reservoir.
The included mounting kit allows the Eisbecher Aurora Reservoir with VPP Apex pump to be placed freestanding in the case or mounted on a radiator as well as free fan locations. The fill volume of 180ml or 360ml is more than sufficient for any water loop.
Technical data of the reservoir:
Features of the pump:
- Capacity: 180ml / 360ml
- Material: acetal, glass
- Connection: 1x G1/4" inner thread In, 3x G1/4" inner thread Out
- Quantity of digital aRGB LEDs: 12
- Material: aluminium, synthetic material & ceramics
- Speed range: 2500 - 4500 RPM via 4-Pin PWM
- Maximum pumping head: 4,25 m
- Maximum flow rate: 340L/h
- Operating voltage: 8-13 V DC (SATA Power Management)
