Alphacool VPP655 Low/Medium/ or high Rpm?
FireFox
The Power Of Intel
7,507 (1.89/day)
Germany
Processor Intel i7 10700K
Cooling 2x Black Ice Nemesis GTX 480 - 1x Black Ice Nemesis GTX 420 - D5 VPP655P - 13x Corsair LL120 - LL140
Storage Samsung 970 EVO PLUS 500GB/1TB - WD Blue SN550 1TB - 2 X WD Blue 1TB - 3 X WD Black 1TB
Case Corsair Obsidian 1000D
Mouse Logitech G502 spectrum
Keyboard Virtuis Advanced Gaming Keyboard ( Batboard )
Software Windows 10 Enterprise/Windows 10 Pro/Windows 11 Pro
Hi everyone
I have this pump
The velocity of this pump can be adjustable from 1000rpm up to 5000rpm and I am
Wondering at how many rpm should a pump run?
Every advice will be really appreciate it..
Thanks
sneekypeet
not-so supermod
29,634 (4.33/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
Run three or four ranges of speed with some sort of a stress test and see if increasing the speed offers any benefit or if a lower speed is sufficient for best thermal performance. Every loop is different, so where I may find full speed is needed for efficiency, you may not need as much to get the best results. Sometimes too much pump speed can hurt thermals as well! ;)
FireFox
The Power Of Intel
7,507 (1.89/day)
Germany
does it matter the amount of radiators that I have?
43,026 (6.72/day)
i would say the more radiators the faster youd want the flow to run to make it through those rads
sneekypeet
not-so supermod
29,634 (4.33/day)
System Name EVA-01
^ what he said. I usually found that the res can play up at times too with too much speed as it will cause air to cycle through, not just fluid. As I said, try it out, if it works at full speed, have at it!
FireFox
The Power Of Intel
7,507 (1.89/day)
Germany
Should I use prime 95 to stress the system?
43,615 (6.46/day)
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
FireFox
The Power Of Intel
7,507 (1.89/day)
Germany
FireFox
The Power Of Intel
7,507 (1.89/day)
Germany
My theory was more radiators more faster the pump should it runs
43,026 (6.72/day)
Well you gotta be able to get fluid in those separate rads quick enough to gain a heat reduction
FireFox
The Power Of Intel
7,507 (1.89/day)
Germany
Test done, the pump was tested at 2000rpm, 3000rpm, 4000rpm and 5000rpm and I didn't notice any benefits temperatures were always the same 68 degrees at full load
sneekypeet
not-so supermod
29,634 (4.33/day)
System Name EVA-01
this is what I was saying, no need to push it that fast if its not needed. Could extend the life of the pump as well as less noise and vibration;)
FireFox
The Power Of Intel
7,507 (1.89/day)
Germany
Something to correct, i will leave it at 2000rpm because I saw that temperatures were 66 and rarely for a couple of seconds 68, for me it's still a little weird That at lower speed with 2 radiators i get 2 degrees less than at higher speeds:rolleyes:
sneekypeet
not-so supermod
29,634 (4.33/day)
System Name EVA-01
I have found that sometimes more speed from the pump will counteract the radiator....IE the water is passing to fast to be efficiently cooled.
2,785 (0.57/day)
New Zealand
System Name MoneySink
Processor 2600K @ 4.8
Motherboard P8Z77-V
Case NZXT Switch 810
Power Supply Seasonic X-1050
Software Win8.1 Pro
Probably a case of diminishing returns. Higher RPM means the pump generates more heat which it dumps into the coolant it is circulating. Typically a (12V) D5 uses ~13 to 35W depending on rotor speed. For a happy medium I might suggest a quick browse of one of the more comprehensive watercooling testbenches around (Martins Liquid Lab). The Koolance PMP-450 is just another rebranded Laing D5 (as is the Alphacool, as well as any number of Swiftech MCP655, EK, Danger Den, Phobya models etc.)
FireFox
The Power Of Intel
7,507 (1.89/day)
Germany
Thanks a lot for the link, I learned a couple of things of it...
FireFox
The Power Of Intel
7,507 (1.89/day)
Germany
l has spent more than EUR 600 for my entire setup watercooling and last week I ordered some additional components in order to watercool GPU too ( so far around 800 euro+) and that is why I try to get the best performance of my watercooling, before I decided to build a system of WC I was reading around and learning as much as possible, although I missed some points I still got what wanted and i am really happy with all the goals that I have achieved so far and each time I make an improvement to my watercooling system that's a big satisfaction for me..
sheltin
3 (0.00/day)
more water blocks you have more pressure (head pressure) you need so more rpm, most restrictive part of your water loops are your blocks!
I have 3 radiator's 's all 65mm thick (240,360,360) thicker the rad the slower the water travels through the rad! The more heat exchange you get! (1/4 coolant and 3/4 distilled water for me) but!! the slower the water passes through your water blocks (Cpu/Gpu's) the less heat transfer your get so higher temps so its a trade off if you have thin radiator's and lots of blocks
that's why my 980's are in parallel (not in series) less restriction after the Cpu!
they don't put out as much heat as my (4930k at 4.5Ghz) and they both still run 8 degrees cooler than the Cpu even though they are after the Cpu
I have done tests with my fans on manual (constant speed) and room well ventilated I stress tested both Gpu's and Cpu at same time (furmark&prime95) at 5000rpm pump speed until temps stopped climbing about 15/20 min I worked my way back down 500 rpm at a time stressed for 15min I saw no temps climb until I reached 3500 rpm I climbed 1 degree across my Gpu's! Nothing on Cpu...... this is where my previous statement comes in! the slower the water passes through your water blocks (Cpu/Gpu's) the less heat transfer your get so higher temps I started losing to much water flow through my Gpu's because they are in parallel they get half the flow of the Cpu I continued to drop the rpm's once I got to 2000 rpm my Cpu temps started rising!! any less than 2000 rpm is just plan stupid in my opinion for this pump!
I have settled for 2500 rpm on the pump its not noisy it efficient and I will get a lot of hour out of the pump!
at 5000 rpm the pump draws a lot of power the motherboard header never read true 5000 rpm but 4750 rpm it also dropped my 12v rail down to 11.8 volts something to be mined full about too I have a 1000w power supply so no problem there
Never use straight radiator coolant you will get bad temps believe me
any question just email me at: sheltin@live.com.au
Toothless
Tech, Games, and TPU!
9,689 (2.46/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Dude the thread is two years old.
14,179 (3.80/day)
Sunshine Coast
System Name H7 Flow 2024
Processor AMD 5800X3D
Cooling Custom liquid
Memory 32 GB DDR4
Video Card(s) Intel ARC A750
Storage Crucial P5 Plus 2TB.
Mouse Lenovo
Keyboard Eweadn Mechanical
Software W11 Pro 64 bit
@Knoxx29 do you still have this pump and how's it performing now after 2 years?
FireFox
The Power Of Intel
7,507 (1.89/day)
Germany
12,062 (2.59/day)
Gypsyland, UK
System Name HP Omen 17
Processor i7 7700HQ
Memory 16GB 2400Mhz DDR4
Video Card(s) GTX 1060
Power Supply 230W
Mouse Roccat Kone XTD+
FireFox
The Power Of Intel
7,507 (1.89/day)
Germany
Soon I'll build a Watercooled Machine and I will buy one of those once again, it's a great Pump.
