- Jul 26, 2013
- 438 (0.10/day)
- Midlands, UK
System Name | Electra III |
Processor | AMD Ryzen 5 3600 @ 4.40 GHz (1.3 V) |
Motherboard | ASUS PRIME X570-PRO with BIOS 5003 |
Cooling | Cooler Master Hyper 212 EVO V1 + 4× ARCTIC P12 PWM |
Memory | 32 GiB Kingston FURY Renegade RGB (DDR4-3600 16-20-20-39) |
Video Card(s) | PowerColor Fighter RX 6700 XT with Adrenalin 24.7.1 |
Storage | 1 TiB Samsung 970 EVO Plus + 4 TB WD Red Pro |
Display(s) | Dell G3223Q + Samsung U28R550Q + HP 22w |
Case | Fractal Design Focus G (Black) |
Audio Device(s) | Realtek HD Audio S1220A |
Power Supply | EVGA SuperNOVA G3 750 W |
Mouse | Logitech G502 X Lightspeed + Logitech MX Master 2S |
Keyboard | MSI VIGOR GK71 SONIC Blue |
Software | Windows 10 22H2 Pro x64 |
Benchmark Scores | CPU-Z = 542/4,479 — R15 = 212/1,741 — R20 = 510/3,980 — PM 10 = 2,784/19,911 — GB 5 = 1,316/7,564 |
Board and CPU:
ASUS PRIME X570-PRO (BIOS 4602)
AMD Ryzen 5 3600
Original Memory:
16 GiB Corsair Vengeance RGB PRO DDR4-3200 (2 × 8 GiB)
8 Gb Hynix CJR, A0 ver 5.32
16-18-18-36-54 (XMP)
CMW16GX4M2C3200C16
Thaiphoon screenshot
eBay Memory:
32 GiB Kingston HyperX Fury RGB DDR4-3600 (2 × 16 GiB)
16 Gb Hynix AJR, A3
18-22-22-39-55 (XMP)
HX436C18FB4AK2/32
Hi everyone, I hope you're all well.
I recently bought a memory upgrade for my computer from an eBay seller, and it would appear that at least one of the modules is causing issues. Based on my diagnostics so far, I've narrowed down the problematic module, but I'm getting mixed results, depending on which slot I use, and I'm trying to understand whether the board is the issue or not.
The listing stated that the memory was in perfect working order, and based on his past feedback and our interactions, he seems genuine enough. He has accepted my return request, but I'd like to get to the bottom of this before I send them back.
I've had the machine since August 2020 with the original configuration listed (also in my specs), including the Corsair memory set at XMP settings with no problems like this before.
Here's what's happening:
* ASUS recommends using slots A2 and B2 when only installing two modules.
I'm using a mixture of Windows Memory Diagnostic Tool and memtest to check for memory errors. For simplicity of understanding, I've found that both identify errors for the same configurations listed above.
The board is still within warranty as ASUS gives 3 years, but I don't think the board is the issue here, despite the mixed results. I don't have another DDR4 board to test with.
What do you guys think?
Thank you!
Edit: here are some photos/screenshots. I've also linked each of the memory kits to their respective Thaiphoon screenshots.
AMD Ryzen 5 3600
Original Memory:
CMW16GX4M2C3200C16
eBay Memory:
16 Gb Hynix AJR, A3
HX436C18FB4AK2/32
Memory | Slot(s) | Outcome |
Corsair; module A | A1 | DRAM LED |
Corsair; module A | A2 | No DRAM LED; no errors |
Corsair; module A | B1 | No DRAM LED; no errors |
Corsair; module A | B2 | No DRAM LED; no errors |
Corsair; both modules | A2 + B2 * | No DRAM LED; no errors |
Kingston; module A | A1 | DRAM LED |
Kingston; module A | A2 | No DRAM LED; no errors |
Kingston; module A | B1 | DRAM LED |
Kingston; module A | B2 | No DRAM LED, errors; MEMORY_MANAGEMENT BSoD while running memtest |
Kingston; module B | B1 | DRAM LED |
Kingston; both modules | A2 + B2 * | No DRAM LED; errors; UNEXPECTED_KERNEL_MODE_TRAP BSoD while playing BeamNG |
Thank you!
