AM4 mobo upgrade to B550 Tomahawk
30 (0.05/day)
Hola! So I am running R5 5600 ( non x ) on Asus Prime B450M-A2 mobo and I am thinking is it worth to upgrade my mobo to MSI B550 Tomahawk ( costs only 127€ wifi version atm ) and will I benefit?
I want to upgrade as I played a bit with Ryzen Master and would like to play further more, but I am afraid I will fry my curent mobo lol.
I am thinking of using this system AM4 for at least 5 years more, and upgrading gpu and cpu ( X3D ) later.
My set up:
R5 5600 + Thermalright Burst Assassin 120SE
Asus Prime B450M-A2
6600xt xfx ( 2 fan version )
32GB Corsair rgb pro 3600mhz c18
Adata s20g nvme
3 ssd ( 1tb, 500gb and 240gb )
Corsair CV650 psu ( soon recieving be quiet straight power 1kw )
With slight oc with ryzen master i am achieving 4.4ghz boost, in warzone temps didnt go past 67C.
Thanks !
238 (0.14/day)
My set up:
Asus Prime B450M-A2
Adata s20g nvme
Thanks !
What makes you think that you will fry your board? The 5600 is a low power chip.
I would personally call this a waste of money upgrade. Use that 127 Euro on other components.
xu^
1,139 (0.18/day)
Lancs,UK
System Name Mr_average ( hoping 1 day to upgrade to Mr_above_average )
Processor AMD Ryzen 7 7700x
Motherboard Asrock B650 Steel Legend Wi-fi
Cooling Deepcool AS-500 Plus - White | 6 Lian Li ST120mm case fans - White
Memory 32gb Corsair Vengeance RGB 2x16gb 6000mhz DDR5 - White
Video Card(s) Asus Dual GeForce RTX 4070 12GB OC
Storage 512gb Sabrent Nvme | 4tb Samsung SSD | 2tb WD Blue SSD| 1tb Crucial P3 Nvme| 1tb WD Blue HDD = 8.5tb
Display(s) D1: LG Ultragear GL850-B 27" 1440p 144hz | D2: Asus Tuf - VG249 24" 1080p 144hz
Case Lian Li Lancool 2 Mesh RGB - White
Audio Device(s) Creative Gigaworks T20 Series II | Steelseries Arctis 3 Headset - White
Power Supply Corsair TX650M Semi Modular 80+ Gold
Mouse Razer Basilisk V3
Keyboard Razer Huntsman V2
My set up:
Asus Prime B450M-A2
Adata s20g nvme
Thanks !
i asked this very question a few months ago, i was on a B450 Tomahawk Max with a 5700x , i was asking if was worth it, for PCI-4 support ( b450 is gen 3) for GPU and NVME etc
to cut a long story short , no its not worth it, u wont really see any diff over what u have, so I waited a couple months and went for a platform upgrade to AM5 , Motherboard,CPU and Ram
9,499 (3.42/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
I would only do that if the board is giving gremlins.
Toothless
Tech, Games, and TPU!
9,675 (2.45/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Save the money and if the 5700x3d is supported then just get that. x3D chips barely pull power and will be fine.
967 (0.42/day)
Uttar Pradesh, India
Processor AMD R7 1700X @ 4100Mhz
Motherboard MSI B450M MORTAR MAX (MS-7B89)
Cooling Phanteks PH-TC14PE
Memory Crucial Technology 16GB DR (DDR4-3600) - C9BLM:045M:E BL16G36C16U4W.M16FE1 X2 @ CL14
Video Card(s) XFX RX480 GTR 8GB @ 1408Mhz (AMD Auto OC)
Storage Samsung SSD 850 EVO 250GB
Display(s) Acer KG271 1080p @ 81Hz
Power Supply SuperFlower Leadex II 750W 80+ Gold
Keyboard Redragon Devarajas RGB
Software Microsoft Windows 10 (10.0) Professional 64-bit
Benchmark Scores https://valid.x86.fr/mvvj3a
This would be my advice as well. Sell the 5600 put the funds from that + motherboard budget together with that and get the 5700X3D.
42,984 (6.72/day)
30 (0.05/day)
My mobo has a heatsink on VRM but that heatsink is very small lol. This is the mobo I have: https://www.asus.com/us/motherboards-components/motherboards/prime/prime-b450m-a-ii/
So ya’ll sayin just squeze every last bit of power from what I have and skip on mobo upgrade and rather upgrade CPU/GPU instead?
as far as I understand pcie 4.0 is not worth and not a huge difference irl?
thanks, I’ll probably skip on mobo upgrade lol.
