AM4 Motherboard Suggestions
Durvelle27
6,797 (1.49/day)
Memphis, TN
System Name Black Prometheus
Processor |AMD Ryzen 7 1700
Video Card(s) ASUS DirectCU II R9 290 4GB
Mouse Logitech Trackman
Keyboard Logitech K350
Software Windows 10 EDU x64
Hey fellow TPUers,
Might be a little conufusing but I'm trying to figure out what would be a good AM4 motherboard. Yes I currently have a MSI B350M Gaming Pro but now I want to SLI my 1080Ti but my current board only has one full PCIe 3.0 x16 slot. I'm really keen to ASUS, Gigabyte, and MSI boards. Doesn't matter if B350 or X370 as both chipsets offer Overclocking. Any suggestions would be greatly appreciated from fellow Ryzen owners.
Little skeptical of ASUS AM4 as I heard the BIOs hasn't been that great
2,355 (0.46/day)
Right where I want to be
System Name Miami
Processor Ryzen 3800X
Motherboard Asus Crosshair VII Formula
Cooling Ek Velocity/ 2x 280mm Radiators/ Alphacool fullcover
Memory F4-3600C16Q-32GTZNC
Video Card(s) XFX 6900 XT Speedster 0
Storage 1TB WD M.2 SSD/ 2TB WD SN750/ 4TB WD Black HDD
Display(s) DELL AW3420DW / HP ZR24w
Case Lian Li O11 Dynamic XL
Audio Device(s) EVGA Nu Audio
Power Supply Seasonic Prime Gold 1000W+750W
Mouse Corsair Scimitar/Glorious Model O-
Keyboard Corsair K95 Platinum
They were horrid at first, don't get me wrong don't mean they were outright bad but when looking at the other AM4 boards they were clearly lacking a certain level of polish, but since have come quite a way. I'm not finding myself constantly complaining about anything anymore and instead just little things I nitpick about.
866 (0.23/day)
Processor ryzen 5 5600x
Motherboard AB350m Pro4
Cooling custom loop
Memory TEAMGROUP T-Force TXKD416G3600HC18ADC01 16gbs XMP
Video Card(s) HP GTX1650 super 4gb
Storage MZVLB256HBHQ-000H1 PM981a (256GB)/3TB HDD
Display(s) Nitro XF243Y Pbmiiprx
Case Rosewill CULLINAN
Power Supply Corsair 750w
Mouse Best Buy Insignia
Keyboard Best Buy Insignia
Software Win 10 pro
asrock did an extremely good job with their am4 boards. heres one on sale
https://www.newegg.com/Product/Prod...57774&cm_re=asrock_am4-_-13-157-774-_-Product
its x370 but has plenty of room between the pcie slots so your sli setup can breath. b350 was always meant for mainstream non enthusiast use. x370 is more of what yoy are looking at with the setup you want. b350 was only supposed to be used with 1 graphics card tho it can run 2.
970 (0.18/day)
Granby, Qc. Canada
System Name Loose nuts & bolts
Processor FX-8350 - EK Supreme HF full nickel
Motherboard ASUS Sabertooth 990FX R2.0
Cooling Water EK goodness all around 2xBlack Ice X-280
Memory 2 x8G HyperX Fury 1600 @ 9-9-9-24-1T
Video Card(s) 2 x XFX RX 480 w/EK-FC RX 480 nickel+Acetal
Storage Samsung 850 Evo + 2xWD Black 500GB in RAID0
Display(s) Crossover 27" 2560x1440 110Hz OC
Case Cooler Master HAF XB EVO
Audio Device(s) on board
Power Supply Corsair HX850
Software Win 10 Enterprise x64
Hey fellow TPUers,
If you want to SLI, no choice but to go with X370. B350 chipset only supports AMD X-Fire.
I would consider the Asrock's X370 Taichi, you should read Dave's review
the54thvoid
Super Intoxicated Moderator
13,120 (2.39/day)
Memory 32GB Kingston Fury
Case Asus Prime AP201
Audio Device(s) On Board
Software W10
^^ What they said. The Taichi seems to be the better of the early released boards. Though to be fair, the 1403 (most recent BIOS) for the Asus Crosshair 6 has proven stable now on the memory front. It's still not as 'easy' as a plug and play to run at the memory's tested settings but you just need to run through the DOCP (XMP) profiles. I'm stable now at 3.822Ghz clock on all 8 cores (1700X) and memory sitting nicely at 3200, 14 timings. Air cooled as well on CPU so it's not bad at all.
Durvelle27
6,797 (1.49/day)
Memphis, TN
That's one sexy board for sure but that price tag
Durvelle27
6,797 (1.49/day)
Memphis, TN
Anyone have experience with the ASRock X370 Killer, Gaming K4 or Gaming X
866 (0.23/day)
Cooling custom loop
Software Win 10 pro
my brother owns the asrock x370 killer/sli and it works marvelously.
edit: the gaming k4 is essentially the same board, just a different audio chip and lan. both are moot points in my opinion as the onses on the killer sli are already really good.
cdawall
where the hell are my stars
27,680 (4.11/day)
Houston
System Name All the cores
Processor 2990WX
Motherboard Asrock X399M
Cooling CPU-XSPC RayStorm Neo, 2x240mm+360mm, D5PWM+140mL, GPU-2x360mm, 2xbyski, D4+D5+100mL
Memory 4x16GB G.Skill 3600
Video Card(s) (2) EVGA SC BLACK 1080Ti's
Storage 2x Samsung SM951 512GB, Samsung PM961 512GB
Display(s) Dell UP2414Q 3840X2160@60hz
Case Caselabs Mercury S5+pedestal
Power Supply Seasonic Prime 1200w
Mouse Thermaltake Theron, Steam controller
Keyboard Keychron K8
Software W10P
Durvelle27
6,797 (1.49/day)
Memphis, TN
Crosshair
Too expensive honestly as the features will go to waste and the extra Overclocking features won't really do much since mine tops out at 4GHz
866 (0.23/day)
Cooling custom loop
Software Win 10 pro
the asrock gaming k4 will meet your needs or the killer/sli
cdawall
27,680 (4.11/day)
Houston
Processor 2990WX
Software W10P
In that case just grabs msi sli plus. I have done a couple builds with it at the shop zero issues.
10,847 (1.74/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Memory 64GB DDR5 6400 1:1 CL30-36-36-76 FCLK 2200
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Keyboard 65% HE Keyboard
i like my asus - had a gb before... the asus has a scheduler/performance bias function that really adds performance to the chip pretty much across the board.
Also in FarCry 4 i get WAY higher framerates and less stuttering with it on.... (usually get 10.4-10.5 with superpi but had a bunch of stuff open).
only issues is the voltage control is iffy depending on what your chip wants, and also there is no bank group swap setting (all the others are there in the 0805 bios).
Durvelle27
6,797 (1.49/day)
Memphis, TN
Man so many options under $150 that look decent
Thanks for the recommendation. I'll check it out
What's the exact model
10,847 (1.74/day)
Austin Texas
Case Jonsbo Z20
Audio Device(s) Yes
Asus prime X370-PRO but all the asus boards have the setting, i have a B350 that does the same and Crosshair VI does it as well
300 (0.08/day)
Delhi India
Processor Ryzen 7 5700X
Motherboard ASRock B550M Steel legend
Cooling Corsair Hydro H100x + 3x120MM fans
Memory 32 GB Crucial 3600Mhz CL16
Video Card(s) Asrock 6600XT 8GB
Storage Samsung 970 EVO Plus 1TB Nvme + WD Black 750 SE 1TB Nvme+2TB HDD + 480GB Crucial MX500 SSD
Display(s) Acer Nitro IPS 27 inch 144 Hz - 1440P
Case Antec
Power Supply Corsair 600X
Mouse Logitech mx 518
Keyboard Logitech G300s
Just bought a ASUS ROG STRIX B350-F GAMING. it's costly than most B350 boards, but i think it has the same VRM as the Asus prime X370-PRO and looks good in all black.
10,847 (1.74/day)
Austin Texas
Case Jonsbo Z20
Audio Device(s) Yes
try out the performance bias setting... it's gold
300 (0.08/day)
Delhi India
Case Antec
Durvelle27
6,797 (1.49/day)
Memphis, TN
Man you guys got me torn between the Prime X370-Pro, ASRock, and MSI Pro
Durvelle27
6,797 (1.49/day)
Memphis, TN
So I ended up deciding to get the MSI X370 Gaming Pro Carbon
Hopefully it fairs well
444 (0.06/day)
West Chester, Oh
System Name N7
Processor AMD Ryzen 3600
Motherboard Asrock B450 Gaming-ITX
Cooling Custom loop
Memory Gskill F4-3600C16D-16GTZNC
Video Card(s) PowerColor RX6900XT Red Dragon
Storage Intel 545s 256gb, Samsung 840 series 250gb, WD Blue 1tb ssd
Display(s) AOC Q3279VWFD8 1440p
Case Enthoo Evolv mAtx
Audio Device(s) onboard, Steelseries Arctis 3
Power Supply Seasonic GX750
Mouse Corsair M65 Pro
Keyboard HyperX Alloy FPS Pro
Software Windows 10 64 bit
Benchmark Scores Firestrike 21626 Time Spy 8907
My x370 Pro Carbon has been great so far. I've had it a couple months. The first few BIOS revisions were crap but they've ironed out a lot of the issues.
Durvelle27
6,797 (1.49/day)
Memphis, TN
That's great to hear
Dave_K
22 (0.01/day)
It does not
