AsRock
TPU addict
- Jun 23, 2007
- 19,086 (3.00/day)
- UK\USA
Well i thought i give this a try as the last time i tried it was back when Lucid? did it around intel Ivy lake and later, back then i got all kinds of issue's like the ones you get with laptops and such were the GPU would not kick in on demand. all so i believe they tried charging people too for newer drivers and basically gave up bothering.
So i thought i give it a shot again as you can do this with the new AM5 platform even though there did not seem at 1st glance a reason too, how ever i like to see some people with AM5 and the newer RX79XX series and using multi monitor to try this see if you can get around the higher power usages.
I did not expect it to work as well as it does tbh and thought it be worth a little time investigating as it seems like no ones really bothering. As i am using a 6950XT power usages are reported in adrenalin is 5w which is about 2w difference (5w).
How ever checking my UPS while the system is idle the system idles around 90w which is about 30-37w less (normally about 117-127).
I have tried a bunch of games and had the odd quirk but starting to seem very plausible.
Power usage of GPU seems to be the GPU usage, as if it was not my UPS would pick up on what looks like extra usage.
