AM5 stucked on DRAM LED (TUF GAMING X670E-PLUS WIFI+9800x3D)
Tarkin94
5 (0.01/day)
When tweaking the 9800x3D (Actually even the 7800x3D), I occasionally found that my PC wouldn't restart when I went to reboot from the OS.
It just froze on the DRAM LED and that's where it stuck, I tried giving it time too but nothing happened even after 5-10 minutes, I couldn't even get into the BIOS. I thought it was instability doing it. But now for a test I have my PC in defaults, only EXPO is on in first mod and it did that too.
After googling, this is a pretty common problem with Asus boards. Anyone have any idea how to solve this? I've tried disabling power down and Context restore. Maybe a NitroPath function?
43,808 (6.79/day)
Update your motherboard bios first
ir_cow
4,784 (0.79/day)
USA
Yes. Update to the newest. This is very important. AMD has done so many AGEAS updates it's hard to keep track.
Tarkin94
5 (0.01/day)
Solved: monitoring software reboot workaround under tweakers paradise
43,808 (6.79/day)
