AMD 630 running too hot?
exow2
100 (0.02/day)
Processor AMD Athlon II X4 630 2.8ghz
Motherboard Asus M3A78-EM
Memory 4GB Kingston DDR2 800mhz
Video Card(s) Nvidia Geforce 8800GT
Storage 640Gb 7200RPM 32MB Cache Western Digital
Power Supply 400W NZXT
Software Windows 7 Ultimate
Hey guys, I'm having some issues with my athlon II X4 630 2.8ghz and the heat. Apparently (says core temp) my cpu while playing Battlefield Bad Company 2 reaches 65C! I read some articles about the 630 and the max temp is 71C. This is making me nervous as I don't want to run down the life of my cpu drastically as I game quite often. The rest of my system specs are in the drop down menu, and fyi I have 2 120mm fans in the case, as well as just the stock fan on my cpu. Thanks for any opinions:).:rockout:
43,629 (6.36/day)
Memory 64GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Case Fractal Design North
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
What voltage is it set at? Also, does the cooler seem firmly secured to the CPU?
theonedub
habe fidem
8,026 (1.37/day)
Northern CA, USA
System Name Erakith || AsRock NUCS
Processor AMD ThreadRipper 2990WX ES (32c/64t 3.5ghz@1.02v) || Intel i7 1360P Raptor Lake-P
Motherboard MSI X399 MEG Creation || AsRock OE
Cooling EK Supremacy TR4 Full Nickel, D5 w/ EK Top, 2X EK-CoolStream XTX 360 & Photon 270 Res || OE
Memory 32GB (4x8GB) Corsair Vengeance PRO RGB DDR4 3000|| 2x16GB Corsair DDR4
Video Card(s) Vega 64 EK FC|| Intel Iris Xe
Storage 250gb WD Black NVMe & (2) 2TB Intel 660p NVMe || 2TB Corsair MP600 Pro
Display(s) 34" Dell Ultrasharp U3415W
Power Supply Corsair HX1000
Software Windows 10 Pro x64 || WIndows 11 Pro x64
When I had my 630 I was able to get it to the mid 3ghz range on an OE Phenom cooler with temps at 53C @ 100% OCCT. 65 and 71 is much hotter than I would care to run one of those chips. Def make sure the voltage is set correctlt as E mentioned.
exow2
100 (0.02/day)
It's on default voltage, I havn't played with at all yet as I havn't bought a heat sinc. And yes the fan seems pretty secure but I'll shut down and double check just in case.
43,629 (6.36/day)
Check CPU-Z to make sure the board isn't automatically raising your voltage for some reason.
exow2
100 (0.02/day)
Right now the only time the temp really rises is when I game on Battlefield to be honest. Right now as I'm righting this the temp is 35C :confused:
theonedub
habe fidem
8,026 (1.37/day)
Northern CA, USA
Someone before forgot to lock the heatsink down by flipping the 'switch'- I can't help but ask, have you done that correctly as well? Thats just really hot for stock clocks even for a stock hsf.
exow2
100 (0.02/day)
Here's the cpu-z info at the moment, I'll boot up Battlefield and check if the voltage changes at all also.
471 (0.08/day)
System Name AMD Black Dragon
Processor AMD Phenom II X4 940 Black Edition
Motherboard Gigabyte MA790X-UD4P
Memory 4GB OCZ PC2-6400 Platinum (2x2GB)
Video Card(s) ATi Radeon HD4870 512MB GDDR5 w AC Twin Turbo
Storage Crucial C300 64GB SSD, 500GB and 2TB Drives
Display(s) Samsung 2494hm, Dell (Samsung?) 1907FP
Case Lancool (Lian-Li on a budget) K7
Audio Device(s) Onboard Realtek ALC889A, M-Audio Fast Tracks
Power Supply OCZ Mod-X-Stream Pro 600W
Software Windows 7 Home Premium x64, XP Pro
Yeah that's pretty hot for a Athlon II even with the stock cooler. Do you have the latest BIOS on your mobo? Perhaps try an update if you don't.
exow2
100 (0.02/day)
Nope, I even double checked and I did flip that lever down to lock the fan in place. It's very secure so I cant see that as being the issue. I'm a noob but im not that big of a noob XD.
exow2
100 (0.02/day)
Actaully that's a good idea, since I never downloaded the drivers from my CD since they are only compatable with xp for some reason, and I'm running win 7. Should I try to find some patched drivers for my mobo and get the latest bios drivers..? How would I check though first to ensure I don't have the latest BIOS already?
43,629 (6.36/day)
I had that board and all the drivers are listed on Asus' website. http://support.asus.com/download/download.aspx?SLanguage=en-us Did you ever install your SB/NB/USB drivers from AMD? You need those too.
exow2
100 (0.02/day)
Looked through every section on the site and my mobo wasn't listed, I have the M3A78-EM. You sure she's on there..?
EDIT: Also, looking at cpu-z I noticed that my voltages were flying around from being at 1.1 to up to 1.4 then back down again etc, is this normal?
theonedub
habe fidem
8,026 (1.37/day)
Northern CA, USA
Yeah Cool n Quiet will auto adjust your Vcore as it adjusts your clocks for power savings.
I think my 630 only needed 1.3xx (just slightly above default) to get to its ~3.4ish OC. Maybe your board is like my OLD GB board where the default over volts the CPU. I had to go in the bios and reselect normal before it used 1.3xx instead of 1.45. Check it out.
43,629 (6.36/day)
Positive. It's on the same page I linked you to.
After you select your motherboard, it will ask what O/S you use. Select the correct O/S. Then it will list everything.
exow2
100 (0.02/day)
http://i403.photobucket.com/albums/pp112/erocker414/help1.jpg
Thanks, must of missed it before I've found it now. So what I'll do is download the latest bios updates correct? I'll probably do this sometime tonight since apparently I can't lose power during this procedure and its raining outside;)
43,629 (6.36/day)
You need a USB stick formatted with FAT. In the bios there is an ezflash option. With your USB stick inserted with the bios file on it, it should work.
OneMoar
There is Always Moar
8,834 (1.61/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
cool and quiet / installing southbridge drivers will not help you here
remove the cooler clean is and reapply some AC5 or other good thermal paste
AMD specs the maximum temp for the chip @ 70C
also post a screenshot of cpu-z /WHILE under load ( have a feeling you're board IS infact using 1.42v for the chip instead of the 1.36 OR 1.38 volts it REALLY needs like mine)
if the above fails
you can try this
bios setup > voltages > cpu voltage to -0.25 V then step it down one at a time untill the machine is no longer stable and then bump it up one notch from that
HELLSPAWNPR
104 (0.02/day)
Hatillo, Puerto Rico
System Name HELLSING
Processor AMD X4 630 @ 3.6ghz
Motherboard Asus Crosshair IV
Cooling 5 x Coolermaster 120mm / 2x Zalman92mm/ 2x Enermax Vegas 120mm
Memory 4GB ADATA X series 9+9+9+24
Video Card(s) 2 X Powercolor ATI 5850 CF OC 850/1050
Storage 80 GB WD Raptor/ 500GB segate & WD 160GB SATA
Display(s) Viewsonic 22 inch WS
Case Chieftec
Power Supply Corsair GS800
Software Wndows 7 Ultimate
is the case well ventilated ? i have my 630 OC at 3.6Ghz 1.4v temps 39c and during the day since the weather in Puerto Rico this week been uper 90s been at 50c -55c
9,253 (1.56/day)
Montreal, Canada
System Name Homelabs
WAYYYYYY to hot for stock.. I got 55 MAX with OCCT or IBT etc... at an overclock to 3.1ghz... (though it was below stock voltage)
You should try to undervolt your CPU and see if that makes a drastic improvement... I could get 1.1V with stock clock, so try 1.22V in BIOS on stock clock to see if that helps
exow2
100 (0.02/day)
if the above fails
you can try this
Alright, I don't have any good cooling paste on hand but come monday I'll buy a good brand and do as you said. I posted that screenshot of the pc under load and while playing BFBC2 it went up to a whopping 65C..I'm getting a little nervous here as it seems like it's just getting worse and worse:eek:. Take a look at CPU-Z and tell me what you think please
9,253 (1.56/day)
Montreal, Canada
1.4xx V is too much I believe that is your problem, that means in BIOS, it is close to 1.5V...
Go ahead and put your voltage at 1.3V (thats around stock voltage) manually right now and see if that works well
exow2
100 (0.02/day)
Alright but I'm not sure on what you guys are talking about to lower the voltage. All I'm getting are options to raise the voltage, nothing to lower it in my BIOS. Example: giving me options to up the voltage +50mv, +100mv, or plus 150mv. Help please :p
9,253 (1.56/day)
Montreal, Canada
Ah, you'll need Erocker's help here, since I do not have experience with your mobo
exow2
100 (0.02/day)
N-ster was explaining to me that my voltage in the BIOS was much too high. Could you maybe help me in my BIOS since I don't have much experience to lower my CPU voltage to about 1.3? It would be greaaaaaaaaaaaatly appreciated:toast:
