AMD EXPO Memory issue Suddenly After 7months usage
4,923 (0.79/day)
Multidimensional
System Name Intel NUC 12 Extreme
Processor Intel Core i7 12700 (E Cores Disabled)
Motherboard Intel NUC Module Motherboard
Cooling NUC Blower Cooler + 3 x 92mm Fans
Memory 64GB Corsair 3200Mhz CL22
Video Card(s) PowerColor RX 9070 16GB Reaper
Storage Silicon 512GB Gen4 SSD + 256GB SD Card
Display(s) Sony 4K Bravia X85J 43Inch TV 120Hz
Case Intel NUC 12 Extreme Mini ITX Case
Audio Device(s) Realtek Audio + Dolby Atmos
Power Supply SFX FSP 650 Gold Rated PSU
Mouse Logitech G203 Lightsync Mouse
Keyboard Red Dragon K552W RGB White KB.
VR HMD ( ◔ ʖ̯ ◔ )
Software Windows 10 Home 64bit
Benchmark Scores None. I also own a Apple Macbook Air M2
Alright TPU gang I'll get straight to the point.
I'm having trouble running my RAM (G-Skill Trident Z5 Neo 32GB 6000Mhz CL32 Kit) at it's advertised speed all of a sudden after 7months of use without issues, only long boot times since AMD 7000 series/Memory training.
Now I can get it running normally at that speed once activated in the BIOS & it works fine in windows but my main issue is not being able to restart my PC, I keep getting freezes/hang ups & it just sits there, the motherboards debug RAM light lights up orange which "indicates DRAM is not detected or fail" According to MSI's manual obviously, & the only thing I can do is manually shut down the PC & turn it back on again & it boots up fine into windows at 6000mhz speeds, but not being able to do a simple useful task like restarting a computer is quite annoying. I'll list the trouble shooting things I've tried to remedy it.
  1. Manually setting RAM speed @ 6000Mhz, timings, voltage, ect.
  2. Manually setting RAM speed @ 5600Mhz/5400Mhz/5200Mhz, auto timings & rated overclocked timings & voltage @ 1.35 - 1.4v
  3. Enabling Memory Context Restore & disabling
  4. Power cycling multiple times and reseating the RAM
  5. Updated the BIOS to the latest version (not a beta bios)
Btw this only started happening about 2 - 3 weeks ago, only thing I did was do a fresh install of windows. Help is appreciated.
44,202 (6.80/day)
Get some different ram and try it.
3,610 (1.17/day)
Processor 9800X3D
Cooling DeepCool AK620
Storage 4TB Samsung 990 Pro
Display(s) 48" LG OLED C4
Case Corsair 5000D Air
Power Supply Corsair HX1200
Mouse Razor Death Adder v3
Software win11
3,920 (1.73/day)
UK, Midlands
System Name Main PC
Processor 13700k
Cooling Noctua NH-D15S
Memory 32 Gig 3200CL14
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
You running at the supported SOC voltages?
17,815 (4.65/day)
Motherboard B650 Steel Legend
Cooling Frost Commander 140
Case NZXT H710
So you say it yourself, the PC works fine, but only as long as you shut down the PC, not a restart. Am I reading that correct? Try turning off fast boot in windows settings.
personally, I never restart or sleep. I always do full shut down and turn on. its never bothered me personally.
ir_cow
4,960 (0.82/day)
USA
CPU is probably on its way out
Maybe.... 6000 isn't bad, but we know know depending on the MB, some crazy high voltages were auto applied. So who really knows.
I would update the BIOS first and try again. nvm you already did. Next I would raise the VDDIO-mem voltage to 1.2 and see if that fixes it. Otherwise try another memory kit.
4,923 (0.79/day)
Multidimensional
VR HMD ( ◔ ʖ̯ ◔ )
I would but don't have a spare kit.
That doesn't spark confidence within me. Can you enlighten on why?
Yeah basically. I know it's not a huge deal but I would still like to be able to restart my PC from time to time for updates, safe mode, DDU usage ect. Plus it's just such an odd issue to have which has me baffled especially after 7 months of usage and no RAM/boot related issues, just long boot times which apparently is normal for AMD 7000 series.
Thanks I tried disabling Fast Boot within windows, applied 6000Mhz, saved & windows started up fine, restarted and it still hanged there unfortunately. Back at 4800Mhz & restarts fine.
I tend to leave it on Auto, and the auto voltage is 1.312v.
Yeah BIOS is updated to the latest version. Thanks I'll give that a shot, if it doesn't work It's not a big deal, might end up buying a newer RAM kit.
17,815 (4.65/day)
Case NZXT H710
report the issue to MSI and hope for a BIOS update someday.
EXPO has bugs and you have to deal with shit as an early adopter.
until then you will have to shut down and power on and live with it. /shrug
dgianstefani
TPU Proofreader
5,415 (2.03/day)
Swansea, Wales
Benchmark Scores Legendary
4,923 (0.79/day)
Multidimensional
VR HMD ( ◔ ʖ̯ ◔ )
3,920 (1.73/day)
UK, Midlands
System Name Main PC
Processor 13700k
Fingers crossed works out for you, I didnt reply again as you seem only slightly above the new safe voltage. Would be pretty unlucky if the cpu has actually degraded from that.
ir_cow
4,960 (0.82/day)
USA
Yeah give a boost to that voltage. I've seen a few motherboards drop the voltage to 1.0 or 1.1 after the meltdown snafu. Playing it Super safe, but that also makes some users 6000 kits not work. Just depends on the quality of your CPU IMC. This is NOT the SoC voltage btw, but both SoC and VDDIO-MEM are part of what makes memory work properly.
Good news if your memory and CPU is under warranty :)
Low quality post by eidairaman1
44,202 (6.80/day)
Disregard nguyen
3,606 (1.13/day)
Cooling Noctua NH-D15 Chromax
Memory 32GB DDR5 6000 CL30
Case Thermaltake Core X9
Mouse PMM P-305
Keyboard Wooting HE60
VR HMD Valve Index
Software Win 10
You are likely referring to the SOC issues that some motherboard vendors had. EXPO just sets some memory timings and memory voltage same as XMP. It's essentially a switch that sets some values so it in and of itself is not going to have the bugs.
To the OP, try these one at a time:
1) Reset the BIOS and then load EXPO profile
2) Switch RAM slots from A2 / B2 to A1 / B1 (if you have them in A1 / B1 switch instead to A2 / B2)
3) Disable fast boot and memory context restore
4) Remove the system's power cable and then the motherboard battery and keep out for at least 15 minutes. Effectively the same as a BIOS reset but useful is some cases as it sometimes fixes issues an BIOS reset cannot.
5) Run MemTest86 (ensure that EXPO is enabled for this).
You could also try breadboarding as a last resort.
In addition if you want to mess around with voltages like ir_cow mentions I recommend this video for educational purposes. It's an overclocking video but it'll give you an idea what everything you are tuning is doing. It's just for learning of course, you don't need to use his timings or frequency but the voltage numbers are definitely helpful for stability:
You stated that you updated to the latest non-BETA BIOS. You should update to the latest BIOS available regardless of if it's BETA or not as they cap the max allowed SOC voltage and come with some AGESA improvements.
When updating BIOS always make sure to reset to default settings before updating. Most motherboard manufacturers recommend this to avoid issues.
ir_cow
4,960 (0.82/day)
USA
Don't follow Buildzoid voltages. He is good at killing CPUs and using unsafe voltages. Doesn't really make people aware of that either.
To be fair to him he doesn't generally tell people to type in these voltages but they're on screen and he doesn't say anything about not doing that...sooo
3,920 (1.73/day)
UK, Midlands
System Name Main PC
Processor 13700k
I do respect him because the detail he goes into, we dont have to agree with him, but he makes an effort to explain what he knows. :)
ir_cow
4,960 (0.82/day)
USA
Oh he knows a lot of stuff no doubt but I think he rambles for an hour for 5 minutes of information that's actually relevant to what he's talking about.
3,606 (1.13/day)
Mouse PMM P-305
VR HMD Valve Index
Software Win 10
Oh for sure but it's useful for learning.
4,923 (0.79/day)
Multidimensional
VR HMD ( ◔ ʖ̯ ◔ )
Thanks a bunch, appreciate it. Yeah hopefully it hasn't.
Cheers for pointing out the difference between the SOC and VDDIO-MEM voltage settings, so many V settings I can't keep track of em.
Yup both mem & CPU under warranty no prob there :toast:
Appreciate all this useful info. I've tried number 1, 2 (kind of, using a mini itx motherboard so only 2 DIMM slots) , tried 3. I'll give 4 & 5 a go cheers.
Bios wise I didn't bother updating cause I didn't have any issues for the past 7 months of usage, figured I'd let others test out the new BIOS's and see the results Lol but yeah I do reset the bios settings everytime. Cheers
355 (0.48/day)
System Name Can it run Warhammer 3?
Processor 7800X3D @ 5Ghz
Cooling Enermax Liqmax III 360mm
Memory Teamgroup DDR5 CL30 6000Mhz 32GB
Video Card(s) Gigabyte 4090
Storage Silicon Power XS70, Corsair T700
Display(s) BenQ EX2710Q, BenQEX270M
Case NZXT H7 Flow
Audio Device(s) AudioTechnica M50xBT
Power Supply SuperFlower Leadex III 850W
What CPU and what Motherboard?
22,100 (3.43/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Case Thermaltake Core X31
Software Gentoo Linux x64
Disregard nguyen
Disregard eidairman1.
Disregard RTB, while your at it.
Seriously speaking doubt the CPU is on it's way out. That's pretty rare. Possible? Sure, but very rare. If you want to be certain, you can always check the lga pads for the telltale burn/bulge damage. If you are that unlucky, AMD will cover it.
3,606 (1.13/day)
Mouse PMM P-305
VR HMD Valve Index
Software Win 10
Yep, even though it's a very rare occurrence it couldn't hurt to be check.
To be fair there's usually no reason to update the BIOS but when something like this crops up might as well cover all the bases.
Speaking of, I did some digging up on Amazon and Newegg reviews of your motherboard (the one listed in your specs) and apparently you are definitely not the only one with booting issues when EXPO is enabled. Some users reported that they fixed their issue by replacing the CMOS battery (which makes sense given I've had this very issue on older systems I've fixed up in the past due to a bad CMOS battery as well). Can't say all the users reporting boot issues is down to the battery but it's worth a try to replace the battery.
ir_cow
4,960 (0.82/day)
USA
Here is the thing about CMOS, how is that related to XMP/EXPO? It's not really. If you had a bad battery the settings we reset to defaults every time you lost power, not cause issues when its enabled.
My question for @Lionheart is did you only start to have problems after updating the BIOS or beforehand?
Also to save a lot of time and headaches do what I said above and manually adjust the VDDIO_MEM (1.2V). While your at it, SoC (1.25V) as well. These are NOT damaging voltages, but probably more than you need for 6000 speed. Unless its dual-rank and that is a whole different ballgame. If you still get errors in memtest5. At least you know it isn't the motherboards fault with auto voltages.
Don't enable High-Efficiency Mode or Context Restore. Contrary to the name, Efficiency Mode actually is tweaking your memory sub-timings for more perf, which can lead to memory related problems if the voltages are not increased as well.
3,606 (1.13/day)
Mouse PMM P-305
VR HMD Valve Index
Software Win 10
A bad CMOS battery doesn't always cause the settings to reset but yes it's likely that said user was running into both a bad CMOS battery and a separate boot issue as boot issues with XMP / EXPO enabled seem to be the predominate reason for his motherboard's low rating reviews. It has a 3.7 rating on newegg and a 4.0 rating on Amazon: https://www.amazon.com/MSI-B650I-Mo...=1&filterByKeyword=boot&filterByStar=one_star
