AMD FX 4350: My first FX build!
1,150 (0.48/day)
Upstate NY
System Name Dual Socket HP z820 Workstation
Processor Twin Intel Xeon E5 2673 v2 OEM processors (thats a total of 16C/32T)
Motherboard HP Dual Socket Motherboard
Cooling Stock HP liquid cooling
Memory 64GB Registered ECC memory kit (octal channel memory on this rig)
Video Card(s) MSI RX 5700 XT Gaming X 8GB
Storage 2 x 512GB SSD in raid 0
Display(s) Acer 23" 75Hz Gaming monitors 1080P x2
Case Brushed Aluminium
Audio Device(s) Integrated (5.1)
Power Supply HP 1125W Stock PSU
Mouse gaming mouse
Keyboard Dell
Just pulled the trigger on a FX 4350 CPU from eBay for a total cost of $40.00.
This is a quad core "piledriver" chip that runs stock at 4.2Ghz with turbo up to 4.3Ghz!!
I selected this chip in the hopes that it may be binned slightly better due to the higher turbo frequency. It also has a full 8MB of Level 3 cache. At 125W It's also less taxing on my motherboard/power supply than an 8xxx series chip, so perhaps we can lean on it a little harder.
So the specs for the rest of this build include:
-80GB Intel Sata III SSD 3500 Series
-8GB KIT of DDR3 7-8-7-20 Corsair XMS3
-Fractal Designs Celsius S36 Liquid Cooler
-CoolerMaster Sileo - quiet, soundproof case
-Nvidia 2GB Video Card
-Biostar TA970 mainboard
-Antec NeoPower 650W blue power supply.
CPU should be here within the week, and we will jump right into it.
My general goal is 5.0Ghz with liquid cooling!
Pictures and updates to follow!
5,731 (1.07/day)
West Midlands. UK.
System Name Ryzen Reynolds
Cooling Raijintek Leto Pro
Power Supply Corsair VS 550w
Mouse Zalman ZM-M401R
Keyboard Razor Lycosa
You'd have been better off with an 8320/50 even at stock the extra threads would be more usefull than a 5ghz oc which I don't think you'll get out of that chip in all honesty and it probably wouldn't have cost you too much more.
11,878 (2.20/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
seams like a strange time to go FX to be honest but with decent cooling 5Ghz should be within reach my 8350 got as high as 5.5 but not for long since the heat output was extreme , you should'nt have as much of an issue there, good luck.
1,150 (0.48/day)
Upstate NY
Mouse gaming mouse
Keyboard Dell
My system does not meet the minimum hardware requirements to power an 8320/50. I would need a better power supply and better motherboard if I wanted to overclock, so I simply chose a quad core chip to try my luck at.
I don't need the extra threads -- a quad core will be sufficient for my OC purposes.
I only needed to purchase the CPU in order to complete this upgrade. The other parts are from a decommissioned 960T system that I have laying around. So total cost for this upgrade is just one CPU @ $40.00
2,249 (1.02/day)
south wales uk
System Name 1.FortySe7en VR rig 2. intel teliscope rig 3.MSI GP72MVR Leopard Pro .E-52699, Xeon play thing
Processor 1.3900x @stock 2. i7 7700k @5. 3. i7 7700hq
Motherboard 1.aorus x570 ultra 2. z270 Maximus IX Hero,4 MR9A PRO ATX X99
Cooling 1.Hard tube loop, cpu and gpu 2. Hard loop cpu and gpu 4 360 AIO
Memory 1.Gskill neo @3600 32gb 2.hyperxfury 32gb @3000 3. 16gb hyperx @2400 4 64GB 2133 in quad channel
Video Card(s) 1.GIGABYTE RTX 3080 WaterForce WB 2. Aorus RTX2080 3. 1060 3gb. 4 Arc 770LE 16 gb
Storage 1 M.2 500gb , 2 3tb HDs 2. 256gb ssd, 3tbHD 3. 256 m.2. 1tb ssd 4. 2gb ssd
Display(s) 1.LG 50" UHD , 2 MSI Optix MAG342C UWHD. 3.17" 120 hz display 4. Acer Preditor 144hz 32inch.z
Case 1. Thermaltake P5 2. Thermaltake P3 4. some cheapo case that should not be named.
Audio Device(s) 1 Onboard 2 Onboard 3 Onboard 4. onboard.
Power Supply 1.seasonic gx 850w 2. seasonic gx 750w. 4 RM850w
VR HMD rift and rift S and Quest 2.
Software 1. win11 pro 2. win11 pro 3, win11 home 4 win11 pro
Benchmark Scores 1.7821 cb20 ,cb15 3442 1c 204 cpu-z 1c 539 12c 8847 2. 1106 cb 3.cb 970
on the brightside you will not need any heating on in your pc room @5ghz :). goodluck with your build i have a softspot for FX chips with all there qwirks. charl.
cdawall
where the hell are my stars
27,680 (4.12/day)
Houston
System Name All the cores
Processor 2990WX
Motherboard Asrock X399M
Cooling CPU-XSPC RayStorm Neo, 2x240mm+360mm, D5PWM+140mL, GPU-2x360mm, 2xbyski, D4+D5+100mL
Memory 4x16GB G.Skill 3600
Video Card(s) (2) EVGA SC BLACK 1080Ti's
Storage 2x Samsung SM951 512GB, Samsung PM961 512GB
Display(s) Dell UP2414Q 3840X2160@60hz
Case Caselabs Mercury S5+pedestal
Power Supply Seasonic Prime 1200w
Mouse Thermaltake Theron, Steam controller
Keyboard Keychron K8
Software W10P
381 (0.10/day)
Processor Amd 2400g/Amd 3800x
Display(s) 50" LG 4k hdr
Case scratch build
With all the bashing FX cpus got, it's nice to see folks still find use for them today .Have fun ,cheers.
2,860 (0.65/day)
System Name BoX-Server | 775PC
Processor I3 3.5GHZ (3150) | Modded Xeon E5450 (OC @3.60)
Motherboard ASRock B85M-ITX | ASUS P5Q-EM
Cooling OEZM HSK | 120MM Heatsink (2-FANs)
Memory 8GB DDR3 (2x4GB) | 8GB DDR2 (4x2GB)
Video Card(s) Onboard | NVIDIA Quadro K2200 4GB
Storage 120GB SSD 1TB WD | 120GB SSD 1TB Seagate 500GB HDD <<
Display(s) DELL 17" LCD 1280x1024 | ASUS 24" LCD IPS
Case CoolerMaster 110 | DIYPC N1e-SPORT
Power Supply EVGA 550WATT | Rosewill 530WATT
Mouse Input-Director| RoseWill FUSION C40
Keyboard Input-Director | RoseWill FUSION
Software WiN1124H2/WiN11ET
Aww the OLD FX days :pimp: A cpu @4.2GHZ stock the joy some peeps had o_O
Low quality post by dj-electric
5,478 (1.05/day)
Not meaning to offend, but why in the fuck would someone want this "quad" core CPU these days? even for 40$ its a pretty horrible deal IMO.
Do you pre-own a compatible board and memory for it? I'd go for a 2nd hand true quadcore or sixcore, like a 1000T-series CPU
Low quality post by theFOoL
2,860 (0.65/day)
D-electric,
Shut the *Front Door Up! It's the passion for some :pimp:
853 (0.33/day)
Asia
Processor Intel Core i5 4590
Cooling Intel Stock Cooler
Power Supply Corsair VS450
Mouse A4Tech N-70FX
Though it is not hot as a intels new 8 core cpu.
5,478 (1.05/day)
Passion of doing... what, exactly? take C2D-like IPC equipped 6 year old budget-at-the-time CPUs and doing... what exactly? a short OC session to squeeze about 20-25% more performance out of it so they can do... .... what exactly?
5,557 (1.02/day)
Gougeland (NZ)
System Name Cumquat 2021
And a better mobo as the 970's were never the greatest for OC'ing because they had weak VRM's so if you think you're going to get 5GHz outta the FX4350 think again it may work but it wont be long before the VRM succumbs to heat exhaustion and dies
2,860 (0.65/day)
Yeah sorry OP but Athlonite is right. The voltage required is just unreal
dj-electric, like me in my 775 build. I have a Xeon on a 775 Board and it works though I bought the cpu from Aliexpress. Only on the right chipsets will work with it. I do this for a passion. Like most do. I know a person who has a Socket A AMD Build for fun
Hopefully this new MB coming tomorrow will allow OC on the cpu unlike the current MB has no good voltage control of OC
2,731 (0.68/day)
Alabama
Processor Ryzen 2600
Memory C.R.S.
Video Card(s) GTX 970
Software Linux Peppermint 10
Whatever he wants to do with it.
If that's what he wants, let him have at it - It's his money, time and whatever else to use or waste as he sees fit.
I also do builds like that all the way back to Socket A at times because I too enjoy it because it's a hobby in my case and probrably is for him as well.
2,249 (1.02/day)
south wales uk
if i could be so bold its not the point of why hes having a 4 core FX , it because he can, like some people have cats and some have dogs or birds or fish its down to choice and need and in some cases what we find in the back of a cuboard and want to make whole again and of course theres those odd fellas who have theadripppers :). charl.
2,860 (0.65/day)
Yeah like that Youtuber LGR
hat
Enthusiast
21,747 (3.29/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
This guy has developed a reputation recently for pushing older hardware to the limit. It doesn't seem to be about getting the best possible performance available today with new hardware... he just enjoys tinkering with stuff.
I wish I could have a Bulldozer chip myself. An 8000 series chip would be a nice drop in upgrade for my Athlon II x4 system, but the board won't take Bulldozer chips... so buying Bulldozer means buying a motherboard as well... and I can't be paying for a board and CPU just to get a Bulldozer chip.
5,478 (1.05/day)
There's a huge freaking difference there. This for me hits the bullseye. Having a barely-tweakable CPU in a non-tweak friendly environment gives no fun in playing with this stuff.
42,510 (6.67/day)
What motherboard you have?
By the way *3** are Piledriver, *1** are bulldozer...
Hope you are blessed with a chip that will do 5.0.
My 8350 does it on Water, check my sig rig specs
  • Like
Reactions: hat
hat
Enthusiast
21,747 (3.29/day)
Ohio
Think he was asking me. It's the GA-770T-USB3
The CPU support list only lists the FX-4130 with a curious N/A under BIOS version... :kookoo:
42,510 (6.67/day)
  • Like
Reactions: hat
2,860 (0.65/day)
Yeah I've seen companies release beta but course they forget to update it thus leave users in the dark and ask "Is it Safe"?
hat
Enthusiast
21,747 (3.29/day)
Ohio
1.0... but the support list seems the same across both revisions. :/
